49 snow thrower mods? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 09-23-2012, 09:56 PM Thread Starter
Just wondering if there are some mods that I should do to the thrower I got for my 317??
bubsy is offline
post #2 of 5 Old 09-23-2012, 10:06 PM
Re: 49 snow thrower mods?
JD 400 Model 50 Thrower mods ??
Leinie is offline
post #3 of 5 Old 09-24-2012, 05:42 AM
Likes Vintage JDs
UrbanTractor's Avatar
As I understand it, these are the 3 primary things that many folks do to improve the Model 49 snowthrower:
1) Add the rubber flaps as described by Mxzrxp in This Thread;
2) Change the size of the auger drive sprocket to increase auger rotation speed; and
3) Swap the short chute for the tall one (if you don't already have it).
Another common mod, if your tractor has a spare pair of hydro outlets, is to convert the manual chute rotation to hydraulic, by bolting a hydro motor right to the wire drum. Also, I've seen where folks have increased chute rotation by adding wraps of wire to the chute base.
UrbanTractor is offline
post #4 of 5 Old 09-24-2012, 08:01 AM
grnspot110's Avatar
Images: 21
I use an electric actuator for spout control, car window motor for rotation control (third pic is the bracket for the motor). Drift cutters on both sides, make it easier to see where the ends of the blower are! And, don't forget the cab! ~~ grnspot
Name:	HPIM2234 (640x478).jpg
ID:	230446   Click image for larger version
Name:	HPIM2250 (Small).JPG
ID:	230447   Click image for larger version
Name:	HPIM2249 (Small).JPG
ID:	230448   Click image for larger version
Name:	HPIM2244 (640x478) (Small) (Small) (Copy).jpg
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is online now
post #5 of 5 Old 02-11-2013, 06:30 PM
Hi All
Just wanted to share my Pic of our 1986 318 taking on Nemo in Trumbull, CT. 34" of snow fell from Friday 2/8 to Saturday 2/9, Drifts of 5' and grater. I did the 2 Mods for our Model 49 Snowthrower/ Snow Thrower from MTF and played with the Engine RPM, adjusted the Govenor to just above 3'600 rpm. I changed my Driven Sprocket to a 34 Tooth sprocket
http://www.surpluscenter.com/sort.as...N=20&PageNo=11
and added the Rubber Wipers to the 2 Paddles on the Auger.
Awesome.
Timmy from Trumbull, CT
Name:	2012 Nemo 1986 318 49 Blower 013.jpg
ID:	247437   Click image for larger version
Name:	2012 Nemo 1986 318 49 Blower 012.jpg
french69ssrs is offline
