setting up deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 09-03-2012, 03:25 PM Thread Starter
whytryduramax's Avatar
setting up deck
I am trying to get my 60"inch deck on my 445 set up perfectly..i bought the John deere blade height gage and have the owners manual i understand most of it but the guage wheels it doesn't really say how they should be set any advice? I have very hilly terrien and lots of crest and valleys...thanks
whytryduramax is offline
post #2 of 14 Old 09-03-2012, 03:27 PM
MTF mile high club member
Diesel Powered's Avatar
Re: setting up deck
Bottom of the wheels should be half an inch or more from the ground.
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is offline
post #3 of 14 Old 09-03-2012, 06:11 PM
mbrun's Avatar
Re: setting up deck
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #4 of 14 Old 09-03-2012, 08:20 PM Thread Starter
Re: setting up deck
Gezz that close?
post #5 of 14 Old 09-03-2012, 11:53 PM
MXZRXP's Avatar
Re: setting up deck
Originally Posted by whytryduramax View Post
Gezz that close?
I would say 1/2 to 1" below the deck lip... (you can hang them lower if you cut your grass high like 3-4 inches...) if they are higher than the deck they will have no effect at all...
assuming flat ground they will never touch but should you get a high spot "in theory" the wheels will lift the deck and keep it from scalping the lawn...
works GREAT in theory but only works in practice in the right conditons...
lets say you have a high spot only a foot wide cenerted under the deck, the blades will just chop off the high spot keeping the anti-scalp wheels clean the good thing is no high spot the next time
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #6 of 14 Old 09-04-2012, 01:38 AM
Re: setting up deck
Gezz that close?
Well, many Deere deck manuals specify anywhere from 1/8" - 1/2" from the ground to the bottom of the wheels. I've never seen any reason to run 'em closer than half an inch; however, I have noticed the line between two passes being more obvious if you have some uneven/rolling terrain and the wheels are higher than half an inch (more noticeable with the wider decks.)
2011 JD X748
2004 JD 4410 TLB
post #7 of 14 Old 09-04-2012, 09:17 AM
Jopopsy's Avatar
Re: setting up deck
The pre-set locks you can choose on your gauge wheels make things confusing. At least for me they do. I'd like to set my wheels higher, but for the height I cut at either I'm at .25" or .75". Give or take.
I can't get the sweet spot w/o playing w/ my cut height. I cut w/ the knob set at 2.75 or so.
I have my 8 hour oil change coming up soon. Since I have to pull the deck off to do that job cleanly, I think I'll screw around w/ the cut height and try to get the gauge wheels up a little bit more. I find I have to work my lift pedal quite a lot when I'm going from grass to pavement/sidewalk.
2015 Snapper Pro S125xt w/ 52" Deck and Kawi Power
*Sold JD X500*
40" Brinly Dethatcher
40" Brinly Plug Aerator
Echo SRM-230
Stihl BG 86 Leaf Blower
Subaru SGX7500 Generator
Honda EU3000is Generator
Red Wing Boots
Jopopsy is offline
post #8 of 14 Old 09-04-2012, 01:12 PM Thread Starter
Re: setting up deck
Well ive been mowing with the wheels up a good 2 inches from the cement floor at cutting height
post #9 of 14 Old 09-04-2012, 01:15 PM Thread Starter
Re: setting up deck
Thanks diesel..i think you figured out why i am getting poor cut quailty
post #10 of 14 Old 09-04-2012, 01:55 PM
Dan33Klein's Avatar
Re: setting up deck
Drop em down a notch!
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/12-john-deere-forum/178233-john-deere-214-restoration.html
http://www.mytractorforum.com/12-john-deere-forum/214280-three-more-restorations-under-my-belt-ready-winter-lots-off-pics.html
Dan33Klein is offline
post #11 of 14 Old 09-04-2012, 06:39 PM
JRJ
The owners manual
JRJ's Avatar
Re: setting up deck
This isn't rocket science we are dealing with here.
Dick
GT275
GT235
JRJ is offline
post #12 of 14 Old 09-04-2012, 10:35 PM Thread Starter
Re: setting up deck
Maybe you should post in the rocket science forum then? Or do have a tip to add
post #13 of 14 Old 09-05-2012, 12:00 AM
Wfburton159's Avatar
Images: 54
Re: setting up deck
Yeah lower them down a lot. Mine are set 1/2" above surface and I cut around 3". My 60 inch deck is set up and cuts way better than my neighbors brand new x3. His lawn looks like the deck is set higher on one side than the other....not good.
2003 John Deere X485
647 tiller
54c deck with power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #14 of 14 Old 09-05-2012, 12:15 AM Thread Starter
Re: setting up deck
thanks for all the help
