Tire Fluid Capacity - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 07-31-2012, 06:11 AM Thread Starter
Tire Fluid Capacity
I want to fill my tires. I have 16x6.50x8 in the front. The rears are 24x12x12. How much fluid will these take?
Thanks
CMD-Ky is offline
post #2 of 13 Old 07-31-2012, 09:28 AM
JRJ
The owners manual
JRJ's Avatar
Re: Tire Fluid Capacity
The rear tires will take about 8 gallons each.
GT275
GT235
JRJ is offline
post #3 of 13 Old 07-31-2012, 12:52 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Here's the link you need.
http://www.tractorsmart.com/Farm_Tra...re_Ballast.htm
stladrill is offline
post #4 of 13 Old 07-31-2012, 10:23 PM
Robert Webb's Avatar
those measurements are not accurate if the tire is laying on it side with the bead broken and you are pouring the liquid between the bead and rim.
I have 26X12X12's on my 400 and I poured 14 gallons of antifreeze in each one.........ONE gallon at the time.
John Deere 430
John Deere 425 with 54" Deck and Power Flow and MC 519 Cart
John Deere 400 with 60" Deck and Power Flow
John Deere 112 H with 38" deck
John Deere 30 Hydraulic Tiller w/ 12" extension and 3 Pt setup
John Deere 21 Cart
John Deere 80 Cart (refurbished to be used)
John Deere 22 Cart (Greens mower trailer)
54" 4 way plow
Brinly 10" Sleeve hitch plow
Brinly 12" 3pt Plow X2
Brinly 4 gang Disc
Brinly Cultivator
5 JD 400 parts machines (2 are destined to be rebuilt)
Craftsman Lawn Cart (orphaned)
Its amazing how fast the collection grows when you aren't even trying....
Robert Webb is offline
post #5 of 13 Old 08-01-2012, 01:13 AM
Thanks
I was looking at my owners manual for this item yesterday. It said not to do this. "hard on transmission"(?) Doesn't make a lot of sense to me unless the sloshing around cycles shock into the trans.
szyg6h is offline
post #6 of 13 Old 08-01-2012, 08:01 AM
69project's Avatar
I guess it depends on what model of JD you have, but generally having fluid filled tires is considered one of the least stressful ways to add weight to your tractor. I know my manual for my 400 suggests having liquid ballast as a means of adding weight.
Robert, 14 gallons each, wow! I had rim guard added to mine and I think it was only 7 gallons or so each. You must have some serious traction now. I could use that kind of weight since I have loader.
69project is offline
post #7 of 13 Old 08-02-2012, 05:23 PM
The issue with filling tires full is lack of air and can't check pressure w/o removing and laying on side. Generally to top of rim is what is done so id the valve stem is at 12 oclock you can air up or down without spewing. Also leaves a decent volume of air so pressure stays more consistent.
1996 JD 455 2ws 450 tiller, 47" blower 54" blade, 54" mower
2006 JD 3720 with lots of goodies my favorite being my Harley rake followed closely by my Farmi skidding winch
2013 JD x750-AC w/60" HC deck
KennedyDiesel is offline
post #8 of 13 Old 08-07-2012, 09:41 PM
Yah, mine is the LA145, whippy machine!
szyg6h is offline
post #9 of 13 Old 08-08-2012, 08:13 PM
mbrun's Avatar
Thanks
on the 8 gallons, plus a little. I ended up with 92lbs of rim guard per 24x24-12 tire. That puts level just above the stem. I know, I can't check pressure without making it look like a CSI crime scene on my garage floor. Drys like blood too.
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #10 of 13 Old 04-11-2013, 06:19 PM
I've also got 26X12X12's and put approx 12 gallons (100 pounds) in each tire. I still have some air in there and the water is under pressure. Could not get the rest of the air out and was not sure how much pressure should be in there.
hurstrescue is offline
post #11 of 13 Old 05-08-2013, 07:05 AM
04zrx's Avatar
Very interesting: one of my rear tires was low on air and when I bought it the guy told me he put windshield washer fluid in the tires. I went to check the pressure and out came the fluid. Should I add enough air to get to the 10 psi that is recommended (that is what I did)?
1984 John Deere 420 (sold)
home made 3 pt.receiver hitch
2002 X585 with 45 FEL and 54C deck
extended weight bracket (8)
04zrx is offline
post #12 of 13 Old 05-08-2013, 11:27 AM
Position the valve stem at 12 oclock AND jack that side of the tractor up to make the stem as much of a high point as possible. Add some air first.
If the fluid still wants to come out you'll need to remove and lay on it's side to get the stem to be the highest point.
post #13 of 13 Old 05-08-2013, 12:23 PM
coalminer16's Avatar
Images: 23
Add air till you get the pressure you want. The fluid will settle in the valve stem so shooting some air in helps clear the stem. Rimgaurd can be sticky on the gauge/filler so I clean them up when done.
My front tires for the 332 gained 20 lb per tire. It was more of an experiement.
Another thing to consider is rim size doesn't mean you will all get the same fluid. I have two 332's with the same size rear rims but different tires. My Goodyear ag tires have 70 lbs in each tire and the 23 degree firestons which aren't as tall-have 50 lbs per tire.
first year 332 with H3 added X 2, JD 3 pt, JD factory delux seat with flip pan. 430 rear diff. 430 fender deck(have two that are mirror copies of themselves).
Attachments:JD 44 loader, JD 50 inch mowing deck, JD 48 replacement mowing deck JD 47 two stage snow blower, JD Hyd 30 tiller X 2 (one belly drive with 12" extension one rear PTO drive with extension-Jim Briney 3 point mounts), Gannon Earthcavator 42 inch 3 point mount, Cozy cab, JD 20 plow, Brinly 12 inch plow.
coalminer16 is offline
