How do I remove the steering wheel off my John Deere 160? Any help appreciated - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 04-15-2012, 01:26 PM Thread Starter
I have a 160 with that crappy wheel which has the rubber splitting, its about to fall off. I have another wheel but Im not sure how to replace. I removed the little hex nut and there is a large phillips head screen on the other side. Seems like aftermarket hack job. I cant budge it even after lubing it up. The plastic cover is off the top of the wheel but it looks like the wheel is welded to the column. Do I have to pull the whole column or am I missing something? Do the wheels just come off these things or do i need to remove the wheel with column?
thanks for any help and if you need pics I can take some with my phone and post them. Thanks
George
GeorgeL is offline
post #2 of 6 Old 04-15-2012, 01:50 PM
KATT's Avatar
Re: How do I remove the steering wheel off my John Deere 160? Any help appreciated
Rescuing another John Deere 180 Page 6 near bottom.
I had the same problem the nut and bolt have to come out of course, then you can try pounding up with a 2X4 .
After a week of PB Blaster and pounding for a couple of minutes after work and spreading it with a BIG screwdriver, and some BAD words it came off. But I suspect you will have to do what he did in that thread.
Current 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
"11" X540 54" Deck
Some LX 188's and a few 100 series
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled ."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck.
Sold Rusty
KATT is offline
post #3 of 6 Old 04-15-2012, 02:52 PM
Certified Master Tinkerer
Herd of Deeres's Avatar
I've used a 3-jaw puller, lots of PB Blaster and every curse word I know + a few I've made up and sometimes that will get the steering wheels off
Herd of Deeres is offline
post #4 of 6 Old 04-15-2012, 04:24 PM
MXZRXP's Avatar
not that it helps, but this is a problem with a whole lot of models and deere should make a better design!
it woudl be easy to do!
It should pop right off with a puller, the fact that even with a puller it needs some persuasion means poor design!
good luck! and wear gloves to protect those knuckels!!
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #5 of 6 Old 04-15-2012, 06:00 PM
JRJ
The owners manual
JRJ's Avatar
Agfter the nut is off an out of the opening get yourself a drift punch and attempt to drive the bolt out and then the wheel should come off.
GT275
GT235
JRJ is offline
post #6 of 6 Old 04-15-2012, 07:00 PM
I had to cut mine off with a die grinder/ cut off wheel. Took me all day. I put a gob of anti seize on the end before I put the new wheel on.
Jgj5150 is offline
