Hydraulic Valve - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 04-04-2012, 06:03 PM Thread Starter
Ehammond's Avatar
Hydraulic Valve
Is there a modification on my 455 that will allow me to use one hydraulic lever then the other without opening and closing the hydraulic valve in this picture? Want to build a lift for my dethatcher and also my tow type aerator and still use the hydraulics to operate mower deck at the same time.
Name:	Hydraulic Valve (Medium).jpg
John Deere 955 60" Deck
Westendorf FE Loader
John Deere 455 60" Deck
John Deere X740 60" Deck
Front Mounted JD Thatcher
4' Tow Type Plugger Aerator
King Kutter 5' Tiller
King Kutter 5' LS Box
12" 3PH Moldboard Plow
Ferris IS1000 21/48 Zero Turn Mower W/10' fold up mounted sprayer
Allis Chalmers 6060
Howse 10' Rotary Cutter
Ehammond is offline
post #2 of 15 Old 04-04-2012, 06:56 PM
MTF mile high club member
Diesel Powered's Avatar
Re: Hydraulic Valve
Are you wanting to use all three at the same time or just the deck plus one or the other?
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is online now
post #3 of 15 Old 04-04-2012, 07:03 PM
Cementhead's Avatar
Re: Hydraulic Valve
You should need no modification,if you have the valve in the open position the upper hyd handle will raise and lower the mower the lower handle will run the attachment you plan to use off the two hyd. ports that would normally be used to raise and lower a blade,snowblower,etc. I just cant remember which two ports. I can run down to the shop if need be my blade is still on the 425.
Cementhead is offline
post #4 of 15 Old 04-04-2012, 07:04 PM Thread Starter
Ehammond's Avatar
Re: Hydraulic Valve
Just the deck and one other.
Allis Chalmers 6060
Ehammond is offline
post #5 of 15 Old 04-04-2012, 07:06 PM Thread Starter
Ehammond's Avatar
Re: Hydraulic Valve
You don't have to make a special trip. Just let me know when you go.
Allis Chalmers 6060
Ehammond is offline
post #6 of 15 Old 04-04-2012, 07:15 PM
Re: Hydraulic Valve
In that case, just leave the valve open. Plug your accessory in the bottom two ports, then use the bottom lever to control it.
2011 JD X748
2004 JD 4410 TLB
post #7 of 15 Old 04-04-2012, 07:22 PM
Cementhead's Avatar
Re: Hydraulic Valve
The lower two ports are controlled by the lower hyd. lever.
post #8 of 15 Old 04-04-2012, 09:49 PM Thread Starter
Ehammond's Avatar
Re: Hydraulic Valve
Both front and rear?
Allis Chalmers 6060
Ehammond is offline
post #9 of 15 Old 04-04-2012, 11:10 PM
Re: Hydraulic Valve
I know there is an electric splitter that you can buy to control two functions off one valve..
deicepro is offline
post #10 of 15 Old 04-05-2012, 02:44 AM
Cementhead's Avatar
Re: Hydraulic Valve
Cant say for sure ,mine has no rear outlets but I believe they are the same.
post #11 of 15 Old 04-05-2012, 04:21 PM
Dan33Klein's Avatar
Re: Hydraulic Valve
he may be refering to rear left on a 3pt hitch...?
in that case its the rockshaft cylinder, top lever, the same cylinder controls your deck
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/12-john-deere-forum/178233-john-deere-214-restoration.html
http://www.mytractorforum.com/12-john-deere-forum/214280-three-more-restorations-under-my-belt-ready-winter-lots-off-pics.html
Dan33Klein is offline
post #12 of 15 Old 04-05-2012, 06:05 PM Thread Starter
Ehammond's Avatar
Re: Hydraulic Valve
What I have is 4 ports in front and 4 in rear, I'm wanting to set it up where the top lever will control my deck and the bottom lever control either a cylinder in front OR behind, which ever one I have it connected to.
Allis Chalmers 6060
Ehammond is offline
post #13 of 15 Old 04-05-2012, 06:40 PM
Likes Vintage JDs
UrbanTractor's Avatar
Re: Hydraulic Valve
It sounds like what you have right now, is a choice between using the four front, or the four rear. You choose which set by opening or closing that diverted valve. Is this correct?
If this is correct, you might need to re-plumb the diverter valve, so that it only closes off flow to two of the ports in front. But you might lose some other functionality by doing this.
UrbanTractor is offline
post #14 of 15 Old 04-05-2012, 07:39 PM
Cementhead's Avatar
Re: Hydraulic Valve
The only function the diverter-lockout has is to isolate the rockshaft cylinder.In other words when you shut the valve off there is no hyd. flow going to the lift cyl.The rear outlets on yours are just plumbed in to the same ones on the front and should function the same.Best bet would be to hook up a cylinder to them and see whats what if you have a cyl on a snowblower or blade you can steal to experement.
post #15 of 15 Old 04-05-2012, 08:28 PM Thread Starter
Ehammond's Avatar
Re: Hydraulic Valve
Here in Alabama we don't have a lot of snowblowers or blades. I want to build a hydraulic lift, like on another thread, for my dethatcher. I can dethatch and mow at the same time if the top lever will control the deck and the bottom lever will control the dethatcher connected to front port.
Allis Chalmers 6060
Ehammond is offline
