Ballast Box - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-04-2012, 01:57 PM Thread Starter
Ballast Box
Any ideas for making a ballast box for a JD 400 with 3 pt. hitch?
Richard
JD 110: 38" deck,front blade,electric lift, wheel weights
JD 216: 48" deck, 39 snow thrower, wheel weights
JD 400 60" deck, Loader 20 rear 3 point hitch
FORD GLT H17 48"deck
Gill747 is offline
post #2 of 3 Old 04-04-2012, 02:56 PM
322 jd. with loader
sirbonzo's Avatar
Re: Ballast Box
here is what 1 person did on forum for theres.
JD Ballast Box tool shelf
good luck ,if you put in ballast box in search there is alot more of them in there
sirbonzo is offline
post #3 of 3 Old 04-06-2012, 11:24 PM
Re: Ballast Box
I had some fun for my 420 with 44 loader I built a hitch with an18$ draw bar from northern and some angle iron then a upright link of angle iron.
Then, now the funny stuff starts, I took it apart, put appropriate holes in a black Square type rubber garbage can cut down in hight and put the hitchback together in the garbage can. Then filled with quickcrete. 6 80 lb bags. I figure I am close to 500 lbs. picks it up no problem and wow can I move snow or dirt.
Works good, Need to get some JD stickers to mark it look better
My two cents
Yamadoo
yamadoo is offline
