John Deere 165 Hydro,,, wont move !!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 03-24-2012, 01:02 PM Thread Starter
Hi, I just bought a very used 165 hydro, I jumped some safety sw. to get it to turn over and got her running. Kawasaki engine. sounds good. It wont move though. belt is spinning the pump pulley, the fan blades are all broken off, the fluid was high. I drained the pump(allen plug beneath) got about 1 1/2 pints, yet the fluid level on top remained. Is the pump shot? can they be rebuilt? or a used one? Thanks in advance, Mike
Bonneybear is offline
post #2 of 21 Old 03-24-2012, 01:16 PM
Banned!
Re: John Deere 165 Hydro,,, wont move !!!
Are you able to push the tractor around easy? if so check the free wheeling lever, knob below the seat.
John@Reliable is offline
post #3 of 21 Old 03-24-2012, 03:26 PM Thread Starter
yeah, it pushes super easy, I moved that twisty knob thing, but it didn't change anything, perhaps it's not releasing all the way. There's no gap between the stem on the valve and the push lever. What's that thing for anyway?
post #4 of 21 Old 03-24-2012, 04:33 PM
Banned!
That's for "free wheeling" ie: puts tranny in (N) so you can push it around easy, look under the tractor and move level to see if you can engage the shaft. Another long shot, with tractor running and in forward see if axle shaft is turning, could be a broken key between axle and wheel hub, but play with that free wheeling shaft first, Good Luck
P.S.
post #5 of 21 Old 03-24-2012, 05:44 PM
forkz
forkz's Avatar
Images: 33
my has a 165 the drive belt broke he removed the rear wheel to get to it got the belt on tractor would not move kept checking things and when he took the wheel off he lost a key replaced key and it moved fine had samething happen with a craftsman lt
country in her soul but she loves to rock n roll charlie daniels
forkz is offline
post #6 of 21 Old 03-24-2012, 06:15 PM Thread Starter
So, it could be a broken key in the axle? both sides or one? anyway to ck this to confirm this?
post #7 of 21 Old 03-24-2012, 07:06 PM
Banned!
read my last post for the quick answer
post #8 of 21 Old 03-24-2012, 09:03 PM
KATT's Avatar
If it didn't change anything, maybe the pin is stuck in ( in the freewheel position) the hydro can't be pushed easily if it is engaged.
Pin is out.Correct position for Hydro to work. IN is freewheel position.
KATT is offline
post #9 of 21 Old 03-24-2012, 10:39 PM Thread Starter
ok, I'll ck it out tomorrow, I'm pretty sure the "freewheeling pin" is out, I moved the lever back and forth and saw it go in and out, I wish I has a manual to see the components on the axle/hub assemblies though. Thanks for all you help so far. It would be great if this hydro /pump wasn't toast and just a keyway broken.
post #10 of 21 Old 03-24-2012, 10:50 PM
KATT's Avatar
Don't know if this helps. ( key out) The key must be on both axles to move. but it will be a miracle if you can get both wheels off, but if you can't then the keys are probably there.
KATT is offline
post #11 of 21 Old 03-24-2012, 11:09 PM
The Admin from... Nowhere
littletractorguy's Avatar
Images: 6
Hey Bonneybear,
Here's the parts diagram for the diff and rear axle on the 165, and the parts diagram for the rear wheels... Not as good as a manual, but possibly helpful... Its free, too, from the JD online parts catalog
Hope it helps you somewhat!
1 E50101 LOCK NUT 2 (SUB FOR M63277)
2 24H1224 WASHER 1 11/32" X 1" X 1/16"
3 M47318 LEVER 1
4 19H1791 CAP SCREW 2 1/4" X 1-1/4"
5 M41028 PIN 4
6 M83290 HOLDER 1
7 M47317 REINFORCEMENT 1
8 M84325 BRAKE DISK 1
9 M47316 PAD 2
10 M84323 WASHER 1
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
11 M41042 SPUR GEAR 1
12 M84321 SHAFT 1
13 M40378 WASHER 2
14 JD9807 NEEDLE BEARING 2
15 M84322 GASKET 1
16 AM38840 HOUSING 1
17 M84125 GASKET 1
18 15H623 PIPE PLUG 2 3/8"
19 AM38841 NEEDLE BEARING 1
20 M40375 SHAFT 1
21 M41044 SPUR GEAR 1
22 M40377 BUSHING 1
23 M40514 SNAP RING 2
24 M70160 BEVEL GEAR 2
25 M41747 CRADLE 1
26 JD9824 THRUST BEARING 4
27 12H302 LOCK WASHER 4 1/4"
28 19H2333 CAP SCREW 4 1/4" X 2-1/4", BRAKE
29 M84320 AXLE 1 374 MM (14-23/32") LONG
30 M41740 BUSHING 4
31 AM38845 HOUSING 1
32 M40676 SEAL 3
33 M41128 STRAP 2
34 M45981 RING GEAR 1
35 M70159 BEVEL GEAR 2
36 M40381 PIN 1
37 M41746 CRADLE 1
38 M70326 AXLE 1 333 MM (13-7/64") LONG
39 AM38844 HOUSING 1
40 AM38842 COVER 1
41 AM38843 NEEDLE BEARING 1
42 37H154 SCREW 10 1/4" X 1"
43 M83291 BRACKET 1
44 M80210 WASHER 2
45 AM102392 DIFFERENTIAL 1 (PEERLESS MODEL 1319-B)
46 19H1731 CAP SCREW 3 3/8" X 1"
47 12H310 LOCK WASHER 3 3/8"
48 26H26 SHAFT KEY 2 1/4" X 1-1/8"
1 AM30346 TIRE VALVE STEM 2 (INCLUDES CAP) (SUB AM30795)
2 W23122 SNAP RING 2 X (SUB FOR M40808)
M40514 SNAP RING 2 X X
3 AM101775 RIM 2 X
AM101778 RIM 2 X
AM101776 WHEEL 2 - 431847 X 8 X 7 (USES M81919 CAP)
AM104391 WHEEL 2 431848 - X 8 X 7 (USES M72752 CAP)
4 24H1448 WASHER 3 X 1-1/32" X 1-1/2" X 0.120", (L.H. ONLY)
M41361 WASHER 2 X X
5 M90065 CAP 2 X X
Cart KEY PART NO. PART NAME QTY SERIAL NO. 130 160 165 REMARKS
M81919 CAP 2 - 431847 X 1.62" I.D. - USE WITH AM101776 WHEEL
M72752 CAP 2 431848 - X 1.50" I.D. - USE WITH AM104391 WHEEL
6 M41361 WASHER AR X X
7 24H1746 WASHER AR X X 25/32" X 1-1/8" X 0.120"
24H1441 WASHER AR X 1-1/64" X 1-1/2" X 0.048"
8 M42183 CAP 1 X X X CHROME (PACKAGE OF TWO)
.. M80369 TIRE 2 X X (18X8.5-8) GOODYEAR, SOF-TRAC
.. M91456 TIRE 2 X X (18X8.5-8) TURF GARD (CARLISLE)
.. M78506 TIRE 2 X X (18X8.5-8) GOODYEAR SOF-TRAC RS (ROUND SHOULDER)
.. M82397 TIRE 2 X (18X6.5-8) GOODYEAR SOF-TRAC
.. M91455 TIRE 2 X (18X6.5-8) TURFGARD (CARLISLE)
.. M82713 INNERTUBE 2 R6.5 X 8 INDUSTRIAL COMBINATION FOR 18 X 8.5 X 8 AND 18 X 6.5 X 8 TIRES
post #12 of 21 Old 03-25-2012, 01:42 PM Thread Starter
Wow, thanks Katt and Little tractor guy, All of you guys have been so very helpful, I cant wait to tear into this and get it figured out. I'll keep you all posted... mike
post #13 of 21 Old 03-26-2012, 01:25 PM Thread Starter
Ok, after jacking it up and rolling each side, I figured the Right side was the culprit, I pulled the R, rear wheel, and sure enough the key was missing, or dissolved?, I drained the rest of the oil in the hydro, I'll get a key tomorrow and install it. What kind of oil goes in the hydro fill under the seat? sae 30 motor oil??? Thanks everyone for there help, I'll keep you posted. Mike
post #14 of 21 Old 03-26-2012, 07:12 PM
KATT's Avatar
I suspect since you could just take off the RR wheel, it had been off before and the PO forgot to put back the key. ??
KATT is offline
post #15 of 21 Old 03-26-2012, 10:30 PM Thread Starter
Really? do they get all frozen and seized on the axle? I guess I lucked out there. I just hope this sucker will move forward and reverse w/ this key..
