Need some help Please. Mower wont engage - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 03-16-2012, 07:35 PM Thread Starter
So Im getting ready to do first start of the season.
My battery was dead.
To make a long story short the BLADES WILL ENGAGE WITH JUMPER CABLES.
When I remove the cables the blades wont engage but the motor still runs.
any suggestions?
Oh its a John Deere LA140 riding lawn mower
cichy1012 is offline
post #2 of 7 Old 03-16-2012, 07:50 PM
GANG GREEN GIZMOW KILLER!
RaisedByWolves's Avatar
Re: Need some help Please. Mower wont engage
Charge or replace your battery.
http://jd318techforum.proboards.com/index.cgi
http://houseofhomelite.proboards.com/index.cgi?
POWERKING "79" 2416
ECONOMY "64" JD
KUBOTA 4200
"68" JD 140 H-3
And a restored JD318
RaisedByWolves is offline
post #3 of 7 Old 03-16-2012, 07:57 PM Thread Starter
Weird although i can drive it, when i engage there is not enough juice from the batterty? And when Im hooked on the jumpers im getting a constant supply of current?
post #4 of 7 Old 03-16-2012, 08:13 PM
MXZRXP's Avatar
exactly...
driving it takes very little if any battery voltage, the clutch on the other hand takes big juce to run-
the clutch is just a large electro magnet and needs plenty of electrons to make it work...
now the Q is, is the source of the problem your battery or the charging system. Start the tractor and run it at WOT...
Check the voltage across the battery if it is between 13-14.5 Vdc then the battery is bad.
Less than 12.5 Vdc at the battery means your charging system is bad -- likely a voltage regulator.
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #5 of 7 Old 03-16-2012, 08:21 PM
new nut but loving it
deerenut's Avatar
Images: 11
It is the battery!... don't ask me how I know
The Deerenut's Herd
95' STX 46
94' LX176 with powerflo and bagger-Mrs. Nuts
70' 110 with model 39 deck
69' 110 with model 39 deck, Horn
69' 140 H-3 The green painted patio Pat.
Model 33 tiller two extentions
200 series Pincor generator
#10 cart
#7 cart
71' Model 68 (Holly's first machine)
She sold it... money in her college fund
91' 322 with 50" deck The Duck
92' 430 with 60" deck and 44 loader
deerenut is offline
post #6 of 7 Old 03-16-2012, 08:40 PM Thread Starter
Originally Posted by MXZRXP View Post
exactly...
where is the voltage regulator located?
post #7 of 7 Old 03-16-2012, 10:11 PM
ShelbyGT550's Avatar
Like was said, any Elect PTO needs juice to run, That juice is from the battery or the stator, Most times if the batt is really weak it will put all voltage to charging.
1996 John Deere 425 Main Summer Machine - 20HP Liquid Cooled Kawasaki - Hydrostatic Twin Pedals - 48" Deck
197? John Deere 400 H3 Main Winter Machine Down - Fixing odds & ends - 19.9HP Kohler 532- Hydrostatic - 3PT Hitch - Back Blade - Snow Blower - Cab - Weights - Chains
1974 Massey 12G - Backup Machine - Tecumseh 12HP - 4 Speed Variator - 42" Mower Deck - Snow Blower - Tiller - Cab
1996 Sears GT6000 - Backup Machine - Kohler Command 22HP Twin - 6 Speed Hi/Low - 42" Mower Deck - 42" Dual Stage Blower - Brush Guard - ATV Tires - Chains & Weights
1974 John Deere 112
(Parts)
197? John Deere 112 Electric Lift - Storage - 12HP Kohler K301- 4 Speed Manual - Turf Tires
Past Machines & To-do's - 1974 Snapper LT16 - 1989 Murray GT18/46 - 1970 Massey Ferguson 10 - 2004 John Deere LA100- WIP
ShelbyGT550 is offline
