I built a Mid Mount grader blade for my 140 - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 25 Old 01-18-2012, 11:11 AM
10,000 +posts!
Re: I built a Mid Mount grader blade for my 140
You did a fantastic job on that unit.. I would love something like that for my father. I can see him struggling with the 54 front blade on the 317.. Thanks for sharing your photos..
Team_Green is offline
post #17 of 25 Old 01-18-2012, 01:40 PM Thread Starter
sawbuckjohn's Avatar
Thanks for all the kind words. It's not so fantastic, but in my experience a belly grader is much more forgiving than a front mount, or even a boxblade, however it has its limitations. I see in the Pittsburgh, western PA. area CL and Pennswoods ads, a fella has a Wheel Horse mid mount and he is asking $425. If I couldn't build one, I'd consider paying that.., for awhile...,then figure something else out.
sawbuckjohn is offline
post #18 of 25 Old 01-18-2012, 06:37 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Originally Posted by dmorrill22 View Post
Hope you don't mind me posting them:
Awesome job on the blade!
Wow! Great job!
stladrill is offline
post #19 of 25 Old 01-18-2012, 08:31 PM
Nice job, I can see where it would be alot easier to control than a front mounted blade.
farmer69 is offline
post #20 of 25 Old 01-18-2012, 08:43 PM Thread Starter
Thanks, Yes they just kinda float along, my 140 does have a float position on the implement control, but that isn't what I mean. If the front tires go over some holes or rougher spots the blade takes them out and levels them before the critical back tires hit 'em. Unlike a front or rear blade.
post #21 of 25 Old 01-18-2012, 09:58 PM
JD318
scooter49's Avatar
Nice job.
scooter49 is offline
post #22 of 25 Old 01-28-2012, 06:46 PM Thread Starter
Originally Posted by Alan_Heist View Post
Looks good. Did you build it from scratch or adapt it from another use?
Another idea you might use for down-force... come off the side of your support bracket with a could of bolts, or even weld some plates on... when you need down-force, stand on them. This would be a way to custom vary the amount of down-force up to your weight. Just an idea to consider since space above and behind your blade might be limited to add weight.
EDIT: Wouldn't it look better in JD Green?
Hey Guys, a quick update-- I had a break in the weather the other day, and decided to try it out. I was well pleased with the performance. A concern is ground clearance in the "Carry" position, but if careful it's workable. On the down pressure question, I agree with Alan_Heist on the foot plate idea. I think it is the handiest way to vary the pressure. Standing on the blade it semi dangerous on the side closest to the rear tire, but I think the danger can be minimized if footplates/footrests(?) are welded to the top of the blade on each side. Good Thought! Also I'm considering JD Yellow
post #23 of 25 Old 01-28-2012, 10:28 PM
mbrun's Avatar
Very nice work! I can see that being very useful.
If you don't mind me asking. How thick is the blade material?
Thanks for all the pictures.
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #24 of 25 Old 01-28-2012, 10:50 PM Thread Starter
The blade steel is only 1/8", I think, but it isn't soft, as the new ones are. Plus I think that thickness isn't really critical as it is really a sluice or gutter for moving the gravel,dirt, whatever away. The work get's done by the cutting bit and the scarifiers. here is some friction, yes, but it'll take quite awhile to wear holes in it. Don't get me wrong, thicker would be better, but it's what I had. Would've been nice if I would've had an old Gravely blade or something, more weight also.
post #25 of 25 Old 01-29-2012, 12:23 PM
It's not easy being green
beabruin's Avatar
Very nicely done. It will look even better in JD Yellow.
1991-LX176 w/38"deck & dual-bagger, 38" blower, 42" blade aka Junior
1989-318 w/48" deck & 49 blower (new acquisition 2012) aka Senior
1989-170 w/38" deck & dual-bagger aka Vinnie
1970s-Model 80 Cart (newly acquired late 2011)
2006 V*Star 1100
2009 Toyota Tundra 'cuz Ford wouldn't/couldn't find the F150 I wanted
Stihl MS250C w/16" & 18" bars
Troy-Bilt CS 4325
beabruin is offline
