John Deere GT 245 Snow Thrower install PICS - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 12-03-2011, 06:53 PM Thread Starter
Hello fellow enthusiasts,
I recently bought a 42" thrower for my GT245 that I got about 2 months ago so I'm fairly new. And before you say RTFM, I don't have one the person who sold me is sending it soon.
Meanwhile back at the garage. I did find a "manual" for the thrower online but I'm still running into some problems. The pictures will help in my descriptions.
Problem number 1.
The riser bar that comes from the left side of the front thrower bolts onto the frame closely how it looks in the picture but I'm either missing the bracket the online manual shows or am I supposed to drill? The bar to the left of the black bar looks like that's what it might hook to but there is no way it would reach.
Side question, what is that small green bar for.
Problem number 2 isn't so much a problem as a question.
The bar coming from the bottom left and moving toward the camera is just kind of hanging out there and I have no idea where I am to put it. (Not the chute spinning bar but the one that is not connected to anything).
Problem number 3.
The bracket holding the chute spinning rod doesn't seem to be close enough to bolt onto anything, high or low. The final two pictures os just showing where it should go.
The guy that sold this dealt with all John Deere garden equipment and said it came from a 345 and it should fit no problem, but I might need to order something. He would reimburse me for any extra parts so I wont be out too much. Thank you guys very much for taking the time to help a stranger.
Firstand20 is offline
post #2 of 17 Old 12-03-2011, 09:44 PM
Re: John Deere GT 245 Snow Thrower install PICS
One question, does your GT have a foot pedal lift? Does not look like it does.
The set up you have is for a foot pedal lift. The bar you are showing in the picture is called a sway-bar, mounts from the blower to front of tractor. You will also need a support rod for your lift and chute. I bought a used 42'' blower that was set up for non lift pedal, and my GX had a foot pedal. Have all the right rods and brackets for your set up. Let me know.
Stever is offline
post #3 of 17 Old 12-04-2011, 09:37 AM
lahkota's Avatar
I hope these photos will help with your problems. Problem #3 bolts onto the bracket you already have on the deck lift handle. That handle also lifts the snowblower. I don't use the spout crank bracket anymore because I've converted mine to electric.
ID:	186551   Click image for larger version
ID:	186552   Click image for larger version
ID:	186553   Click image for larger version
ID:	186555   Click image for larger version
ID:	186556   Click image for larger version
lahkota is offline
post #4 of 17 Old 12-05-2011, 01:07 PM Thread Starter
Hey Steer I think I need the curvered big black bracket. I have the rod. Are you interested in parting with it.
post #5 of 17 Old 12-06-2011, 02:55 PM
StormWeeNY's Avatar
See if this helps. If you have a lift arm, and not a lift pedal - you will need part AM124701 Lever. This is part of the BM18977 Lift Arm package.
ID:	187237   Click image for larger version
ID:	187238   Click image for larger version
ID:	187239   Click image for larger version
StormWeeNY is offline
post #6 of 17 Old 12-06-2011, 03:01 PM
StormWeeNY's Avatar
BM18977 detail sheet for you ...
ID:	187243   Click image for larger version
post #7 of 17 Old 12-14-2013, 12:02 AM
First hand yes you have the same issue I have I bought a used blower for my 245 and I'm the opposite, I have the lever lift brackets and my tractor is pedal lift. I have been looking and they rant cheap so I will keep looking or try to make on my own.
Snofighter is offline
post #8 of 17 Old 12-14-2013, 06:35 AM
pctdavis's Avatar
Subscribing for when my parts come in to do the same thing next week.
Sent from the MTF Free App
Red meat is not bad for you. Green FUZZY meat is bad for you!
pctdavis is offline
post #9 of 17 Old 12-20-2013, 09:53 PM
pctdavis's Avatar
Hey, maybe you can answer a question for me. How far back from the blower are the holes for your lift clevis? For my BM18977 lift kit, the ones on my snow blower are too far back.
ID:	603586   Click image for larger version
pctdavis is offline
post #10 of 17 Old 12-20-2013, 10:01 PM
Jimbochap's Avatar
the holes you use for the yokes are the ones closest to the 2 vertical pulleys at the front of the blower.........you have the yokes where they would be if yo had a hydraulic lift.
JD 345 FOR SALE
SEND ME YOUR BEST OFFER FOR WHAT IS LEFT BELOW !
*48C" Deck
*44" Piranha Mulching/Rear
Discharge Mower Deck
*38" Front Thatcher
** Power Flow
**John Deere Mulch Kit For 48C Convertible Mower Deck - BM20007
***OTC Snow Cab
**2- JD Wheel Weights (#50 Plastic)
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #11 of 17 Old 12-20-2013, 10:06 PM
pctdavis's Avatar
There are no holes there. I could just line it up and drill them but a measurement would allow me to double check where I'm at. It came off a 285 I think so I'm not sure about hydro lift.
That front lift kit is an expensive bugger!
Sent from my DROID RAZR HD using MyTractorForum Free App mobile app
pctdavis is offline
post #12 of 17 Old 12-20-2013, 10:10 PM
Jimbochap's Avatar
What tractor do you have and what kind of lift for your mower? nd what model number on the blower?
JD 345 FOR SALE
*48C" Deck
*38" Front Thatcher
** Power Flow
***OTC Snow Cab
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
post #13 of 17 Old 12-20-2013, 10:22 PM
pctdavis's Avatar
I have a G100 (same frame as GT275). I have the M03251. John Deere matched me up with the BM18977 front lift kit. Everything I've seen said they should match up but I figure I'm going to need a little fabrication I guess. I'm still not quite sure how those back pins hook up yet either.
pctdavis is offline
post #14 of 17 Old 12-20-2013, 10:30 PM
Jimbochap's Avatar
Okay, can't help you with where those holes should be, I have a 3252 Blower which has a bent blower frame..........Back pins hook up to the studs that are under each side just below the foot rests.
Once you get that hooked up that should give you a good idea where those holes should be for the yokes but wait until someone else comes along that has that frame and maybe they can measure back from the end closest to the blower down that black frame and give you the exact place to put those holes.
JD 345 FOR SALE
*48C" Deck
*38" Front Thatcher
** Power Flow
***OTC Snow Cab
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
post #15 of 17 Old 12-21-2013, 03:58 AM
TJR345's Avatar
Images: 8
I bought a thrower off a GT model I have the mounting stuff.I can measure the frame where you need to mount the yokes. The yokes you have if they were on a 345 your in luck because they need to be shorter I'll measure them(345 4" yours 2 1/2) so you'll get the proper length.
2002 X595 with 62" deck and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow in the making
98 345 with 54" deck and powerflow
30" tiller,JD 18 cart, Front and rear thatcher
JD 40" spike aerator, Agifab 3 gang (9') aerator
42" JD Thrower,70 lb wheel weights,6 suit case weights
48" roller,JD T105 trimmer
15 gal. tow sprayer,175lb tow spreader
(2) JD JS63C walk-behind mowers
TJR345 is offline
