318 lock out valave - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 31 Old 10-22-2011, 10:41 AM Thread Starter
blown67's Avatar
318 lock out valave
Is there any other suppliers for the valve than deere? I just priced it on their website and its over 90 bucks with tax....... I saw one on ebay for about half that, but was wondering if anyone had a part number that would work from a place like Mcmaster Carr or Surplus Center.
blown67 is offline
post #2 of 31 Old 10-22-2011, 10:44 AM
The Magnificent
D-Dogg's Avatar
Re: 318 lock out valave
I got one from an EBay vendor for around $30 IIRC. Nothing special about it.
D-Dogg is offline
post #3 of 31 Old 10-22-2011, 11:34 AM
Still lovin' the 322!
PA318Guy's Avatar
I've also seen the aftermarket ones on eBay for around $30.00.
Current Machine JD 322
PA318Guy is offline
post #4 of 31 Old 10-22-2011, 03:48 PM
ggsteve's Avatar
Anyone have a link for these $30 ones? I keep seeing the one for about $43. Also, I need one for a 317. I'm assuming it would be the same?
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #5 of 31 Old 10-22-2011, 05:27 PM Thread Starter
blown67's Avatar
I was looking on the Mcaster Carr website and found these, rated for 2000 psi I think might do the trick. http://www.mcmaster.com/#flow-contro...valves/=eltn58 I think I can use one to do the flow control I need to slow down my angle cylinder and another to lockout the rockshaft, both together are cheaper than 1 on eBay and Mcaster Carr's stuff is usually very good quality.
blown67 is offline
post #6 of 31 Old 10-22-2011, 06:28 PM
PA318Guy's Avatar
ggsteve, went through eBay and could not find the cheaper one! The 42.99 is the cheapest one I see now!
PA318Guy is offline
post #7 of 31 Old 10-22-2011, 07:10 PM
ggsteve's Avatar
Yeah, that seems pretty reasonable, especially since it comes with the extra fitting that's probably $5 anyway. I'll probably rise to the bait on that one soon.
ggsteve
71 JD 140H1 80 Cart
72 JD 110 parts
Woods box blade
ggsteve is offline
post #8 of 31 Old 10-22-2011, 07:16 PM
Just John Deere
GotDeeres's Avatar
Images: 8
All you need is a 1/8" Parker Flow Control valve and a 1/8" Male to Female
45 degree adapter. I used to buy the valve from surplus center for less than $15.
Name:	Rear lockout Flow.JPG
GotDeeres
Just John Deere
425 Garden Tractor with 54C Deck
425 Garden Tractor with 60" Deck
455 Diesel with 60" Deck, 3 Point MCS
455 Diesel with 60" Deck, 3 Point and 540 PTO
455 Diesel with Buford Bucket Compact Loader
2210 CUT with Buford Bucket Compact Loader
John Deere TS Gator
GotDeeres is offline
post #9 of 31 Old 10-22-2011, 08:13 PM Thread Starter
blown67's Avatar
I checked Surpluscenter and couldnt find one, http://www.surpluscenter.com/sort.as...c&keyword=HAFC I looked threw all the flow control valves they carry, any chance you have a part number for that valve?
blown67 is offline
post #10 of 31 Old 10-22-2011, 08:38 PM
Just John Deere
GotDeeres's Avatar
Images: 8
Blown 67,
I have a couple in my shop. I will check the part number tomorrow. It is a Parker PF-200 I believe. Funny, but I can remember a part number, but keep forgetting my wife's name.
Just John Deere
John Deere TS Gator
post #11 of 31 Old 10-25-2011, 08:45 PM Thread Starter
blown67's Avatar
Well I went ahead and ordered 2 from Mcaster Carr, they were 20.39 each, and are the same ones being sold on eBay for 42.99 except these are steel and the eBay ones are brass, and this comes from the manufacturer of the valve: "Brass valves are ideal for water and have a brass needle. Steel valves are ideal for hydraulic oil and have a stainless steel needle". I bought 2, one for my rockshaft and another to slow down my angle cylinder on the blade, but I should have looked closer, the misfit cylinder on my blade has 1/4" NPT and not 1/8' NPT like the original cylinders have so either I need a couple reducing fittings or I have a spare...
blown67 is offline
post #12 of 31 Old 10-26-2011, 02:27 PM
Attachment 179395
GotDeeres
GotDeeres: how did you go about installing your remote shutoff valve? I have a JD 322 I'm wanting to install the valve on, and I'm having a problem with getting enough room to work with.
Mine is on so tight and there is so little room under there to get a long wrench on to work with.
I've decided to try a gas line wrench this weekend and see if that might help with the leverage. In between that time, I'm soaking the fitting with Seafoam Deep Creep, and I hope to put some freeze rust penetrant on the fitting this evening.
Any help would be greatly appreciated.
BTW, aux-hyd.com also has the remote shutoff valves for now. They even have the 1/4 turn valves - of which I purchased for my JD 322.
WC
__________________________________
In the shed:
1950 Farmall Cub
2000 Simplicity Landlord DLX w/ locking differential
1988 JD 322
"If you would fire a person for not showing up for work on a regular basis, then why don't you fire an invisible god for never showing up to work?"
windcatcher is offline
post #13 of 31 Old 10-26-2011, 03:50 PM
Dan33Klein's Avatar
[QUOTE=blown67;1918270]Well I went ahead and ordered 2 from Mcaster Carr, they were 20.39 each, and are the same ones being sold on eBay for 42.99 except these are steel and the eBay ones are brass, and this comes from the manufacturer of the valve: "Brass valves are ideal for water and have a brass needle. Steel valves are ideal for hydraulic oil and have a stainless steel needle". I bought 2, one for my rockshaft and another to slow down my angle cylinder on the blade, but I should have looked closer, the misfit cylinder on my blade has 1/4" NPT and not 1/8' NPT like the original cylinders have so either I need a couple reducing fittings or I have a spare...
WHY DO YOU WANT TO SLOW DOWN YOUR ANGLE CYLINDER?
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/12-john-deere-forum/178233-john-deere-214-restoration.html
http://www.mytractorforum.com/12-john-deere-forum/214280-three-more-restorations-under-my-belt-ready-winter-lots-off-pics.html
Dan33Klein is offline
post #14 of 31 Old 10-26-2011, 04:24 PM Thread Starter
blown67's Avatar
The angle cylinder that is on my blade is not an original setup, a previous owner put a smaller volume cylinder in place of the correct one, it will go from full angle to opposite full angle in less than 1 second flat, literally.
The flow control valves I bought are dual directional so I can dial down the flow to the cylinder to a speed that I am happy with.
And I may have jumped the gun saying the quality of Mcaster Carrs stuff, after I took the pic of the valve for this thread I saw the markings on the left hand side and looked at the threaded hole in the end and sure enough its oblong, but they are sending me a new one and are even giving me the bigger size I need for my misfit cylinder.
blown67 is offline
post #15 of 31 Old 10-26-2011, 04:37 PM
Dan33Klein's Avatar
I see now, id want the cylinder to go fast but not that fast, i am in the process of finding a lock cylinder for my 317 rockshaft so my blade angles faster. it goes slow for a second that speeds up. the 317 cylinder is hard to get to unlike the 318. so i believe it will be harder to rig up. im gonna swing by a hydro shop after work in a bit and see what they have, is the fittings off our rockshaft cylinders 1/4 or 3/8?
2014 Kubota 2370-1
LA243 FEL
54" MMM
Mini FEL
37A Blower RESTORED
http://www.mytractorforum.com/showthread.php?t=178233
http://www.mytractorforum.com/showthread.php?t=214280
