445 Fuel Filter--Is There An Easy Way To Install? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 09-23-2011, 01:16 AM Thread Starter
John Deere 445
bridgeman's Avatar
After 280 hours, I'm finally getting around to installing a new fuel filter on the 445. Dealer where I bought the filter said it's located under the floorboard, next to the frame. I groped around a few times, and haven't found it yet. Murky picture and "explanation" in the owner's manual says to take off the right side engine cover to loosen the pressure-relief bolt, but I haven't found the filter (or the bolt) there either.
Have any other owners replaced theirs yet? Is there a quick (and easiest) way to do so? Do I have to remove the mower or rear wheel to get to (or at least, find) the filter? Or somehow turn the darn thing completely upside down? I'm rapidly approaching old geezerhood, and the knees don't bend well anymore.
Don't like to come across as a complete klutz, but I'm definitely in the running.
bridgeman is offline
post #2 of 10 Old 09-23-2011, 08:12 AM
Have Dog - Will Travel
Jere39's Avatar
Re: 445 Fuel Filter--Is There An Easy Way To Install?
I changed mine a couple years ago, and had no problem at all. I may have removed the snap on side panel, I often did that during any maintenance, including oil and filter changes. The filter was easy to find, and easy to change. It is possible that JD relocated the filter at some point in the build cycle. My 445 was a 1996 model. Unfortunately, I no longer have the tractor or I'd hop out and take a quick picture for you. There are plenty 445 represented by members here, you should get a picture soon.
Don;t give up, but you might want to invest in one of those rolling auto mechanic stools. I don't think even young knees appreciate too much concrete time.
Jere39 is offline
post #3 of 10 Old 09-23-2011, 01:41 PM
Diesel Power
andyb's Avatar
When I bought my 445 used (a '94 model), I replaced all the fluids and filters except the fuel filter. The dealer told me it was such a pain to get to that they didn't recommend changing it as long as it ran OK. It's not like an oil filter that has a bypass if it gets plugged, it just quits running from the lack of fuel. I had it for 9 years and never did change it, always careful to keep the fuel clean though.
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
434 hours and counting
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is offline
post #4 of 10 Old 09-23-2011, 02:20 PM
jwill1776's Avatar
I have a 425 and was going to tell you its easy, then I looked up the 445 diagram……
JD doesn’t even list a procedure in the tech manual for the 445 fuel filter, I’d guess take the seat pan off, unhook the fuel tank / remove it, and you “should” be able to see it on the inside of the frame rail.
John Deere 425 – 54” Deck
Ruegg Cat 0 / Cat 1 Combo 3-Point Hitch
Brinly Cultivator
Brinly 12" Single Bottom Plow
Brinly 60" Rear Blade
jwill1776 is offline
post #5 of 10 Old 09-29-2011, 11:34 PM Thread Starter
John Deere 445
bridgeman's Avatar
Thanx for the replies, guys. My 445's filter is not reachable or visible from the open right side panel. Since Johnny has always run like gang-busters (never spits or stalls, just goes zoom, gotta love fuel injection), my plan is to wait until I drop the mower deck this winter, then hoist the tractor's back end up in the air with a floor jack so I can get my fat gut under the thing. Removing/replacing the seat and floor panel is an option I hope to avoid, as it would surely take me the better part of a weekend.
post #6 of 10 Old 09-30-2011, 12:27 AM
Scott S
Images: 34
Judging from where mine is located, it is realy not that hrd to change. do not be worried about removing the rear fender pan it is not that hard, then the filter is right where it is easy to get to, plus you don't have to lay under the filter that will leak fuel when you disconnect it. good luck!
Trying to convince my wife the one with the most toys "WINS"
tbear9686 is offline
post #7 of 10 Old 09-30-2011, 01:32 AM
rcdebeau's Avatar
Check out this thread that I started a few months back on the same topic. I did have to take the mower deck off, but once I did that I was able to get under my tractor and find the fuel filter quite easily. 30 minutes later and the new filter was installed and everything back together. I did not have to remove the the fender or anything else for that matter. I did have a bit of fuel that leaked out while swapping filters, but nothing much that a couple rags couldn't handle.
Good luck!
JD 445 fuel filter
rcdebeau is offline
post #8 of 10 Old 09-30-2011, 09:27 AM
Deere Guru
Dunkelstar's Avatar
Images: 39
Seems odd JD placed the filter there on the 445.
The 425 is a breeze to change by removing the right side panel, why not locate it on the 445 in the same place?
1996 John Deere 455 AWS
1996 John Deere 425 - w/ upgraded tire size, rear PTO, and 3PT Hitch
#40 Loader, 54 and 48" MMM Deck, 46" Snow-Thrower, 54" Front Blade, Agri-Fab 3PT Core Aerator, Agri-Fab Chip-n-Vac, and #80 Cart
Dunkelstar is offline
post #9 of 10 Old 09-30-2011, 01:41 PM
The 445 filter is a high-pressure filter and is a lot bigger than the 425 filter so it's back there.
Be sure to bleed the pressure off the system with via the release screw on the throttle body. Turn it open a couple turns so the pressure goes into the return line, then snug it back up. That will take the pressure off the system.
Engine_Tech is offline
post #10 of 10 Old 10-02-2011, 09:48 PM
Wfburton159's Avatar
Images: 54
Let the pressure out of the system. Pull the deck off the tractor. Get on a creeper and get under it and change out the filter. Its right on the inside of the frame. Its way easier to drop the deck than pull the fender pan unless you have someone to help lift the fender pan off and on.
2003 John Deere X485
647 tiller
54c deck with power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
