Tiller belt routing 214 w/31 tiller...AGGREVATING! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 08-22-2011, 03:19 PM Thread Starter
Buy High, Sell Low
StWeiler's Avatar
So I can't find a single diagram online that shows the tiller (31) belt routing, and this being my first time trying to set up on the newly acquired 214 I'm finding myself getting downright irked at this. Typically I'm pretty savvy at figuring this sort of thing out...but this stupid new belt has me completely perplexed.
Do ya think the JD dealer would be willing to print me off a diagram if they have one? I did just spend $69 on the belt, so that certainly helps my persuasion.
1988 Wheel Horse 518H
48" Dozer Blade
48" SD Deck x2
StWeiler is offline
post #2 of 12 Old 08-22-2011, 03:37 PM
JimHenry's Avatar
Re: Tiller belt routing 214 w/31 tiller...AGGREVATING!
Did you twist the belt between the mule drive and the tiller 1/2 turn?
PM sent
JimHenry is offline
post #3 of 12 Old 08-22-2011, 03:50 PM
Too young to act this old
better before's Avatar
I just put pics up and explained this for someone recently. Like the last 2-4 days. Could have sworn it was you but it wasn't. Yeah, the mule drive hooks up on the frame just behind, below the engine. Uses mounts for the mower deck. Short belt from pto to mule drive and the long one goes all the way back to the tiller with the half turn like Jim said. Google 31 tiller and go to images. These were compatible with 110, 112, 210-216. It hooked to all of them the same. Is your rear lift installed?
better before is offline
post #4 of 12 Old 08-22-2011, 04:06 PM Thread Starter
Buy High, Sell Low
StWeiler's Avatar
Yep rear lift is installed, tiller is mounted just couldn't figure out the slack in the belt. I guess the 1/2 turn makes sense. I suppose it doesn't matter which direction you twist it...cw or ccw?
TIA
48" Dozer Blade
48" SD Deck x2
StWeiler is offline
post #5 of 12 Old 08-22-2011, 04:38 PM
JimHenry's Avatar
clockwise, looking back
JimHenry is offline
post #6 of 12 Old 08-22-2011, 05:50 PM
Tech Exchange Moderator
Sergeant's Avatar
StWeiler I sent You a PM with some Help It for the 110 & 112 Fender decks But the Mounting & Belt routing is the same
John Deere Models: 1025R TLB,X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is offline
post #7 of 12 Old 08-22-2011, 08:05 PM Thread Starter
Buy High, Sell Low
StWeiler's Avatar
Sweet Sergeant...that will definitely help a ton!
48" Dozer Blade
48" SD Deck x2
StWeiler is offline
post #8 of 12 Old 08-24-2011, 03:44 PM Thread Starter
Buy High, Sell Low
StWeiler's Avatar
I'm at a loss. Either I have something routed incorrectly or I"m skipping a step on getting this belt to route through to the mule. Suggestions? Sorry sun is directly overhead very difficult to get a decent photo.
48" Dozer Blade
48" SD Deck x2
StWeiler is offline
post #9 of 12 Old 08-24-2011, 03:51 PM
Not sure if you've seen this one, but here is a good diagram of the routing.
ericstromberg is offline
post #10 of 12 Old 08-24-2011, 04:25 PM
Make sure you have your tension pulleys on.
post #11 of 12 Old 08-25-2011, 08:24 AM Thread Starter
Buy High, Sell Low
StWeiler's Avatar
Where are those located?
48" Dozer Blade
48" SD Deck x2
StWeiler is offline
post #12 of 12 Old 08-25-2011, 10:05 AM
Look at eric's pic. right side, just in front of the mule drive. Have you run a mower deck on your tractor?
