wiring 318 electric fuel pump - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 07-27-2011, 09:33 PM Thread Starter
jakenbake's Avatar
anyone have some advice on how to wire an electric fuel pump?
i was thinking with a relay going off the oil pressure switch. that way, whenever the pressure switch closes (when there is oil pressure) the pump turns on and whenever it opens (engine loses oil pressure) it turns off.
was also thinking a relay off the hour meter, but that might not be a good idea as it could easily flood the engine if the key was left "on" for some reason.
2001 JD 345
54" MMM
44" Piranha MMM
JD 48" Front Blade
1988 JD 855
70A Loader
7 Backhoe
60" MMM
503 Rotary Cutter
jakenbake is offline
post #2 of 8 Old 07-27-2011, 09:54 PM
Kansas John Deere's Avatar
Re: wiring 318 electric fuel pump
I am not sure if you jump from the oil sending unit will work. Usually the electric fuel pump need to have power to prime when you turn the key on.
Kansas John Deere is offline
post #3 of 8 Old 07-27-2011, 10:18 PM
John Snykus's Avatar
When I did my 318 I used the hour meter to power the relay. It worked fine and I only removed it after having to replace the stater and found that mice had chewed a hole in the vaccuum line to the fuel pump. It was on for over 1 year. Does draw some DC power.
Everyone should have some toys. Mine happen to be green.
John Snykus is offline
post #4 of 8 Old 07-27-2011, 10:37 PM
The Magnificent
D-Dogg's Avatar
Mine is wired to the positive side of the coil.
D-Dogg is offline
post #5 of 8 Old 07-28-2011, 06:43 AM Thread Starter
jakenbake's Avatar
thanks guys. agree on the priming, so maybe the hour meter is the way to go. d-dogg, is your's powered direct from the coil or is a relay used?
anyone have a wiring diagram of how these are wired in a 400?
2001 JD 345
54" MMM
44" Piranha MMM
JD 48" Front Blade
1988 JD 855
70A Loader
7 Backhoe
60" MMM
503 Rotary Cutter
post #6 of 8 Old 07-28-2011, 06:46 AM
The Magnificent
D-Dogg's Avatar
I use no relay, Jakenbake. My pump is tiny and not much of a draw. The PO did the conversion quite a while ago, and no troubles.
D-Dogg is offline
post #7 of 8 Old 07-28-2011, 06:46 AM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
Arrow Re: wiring 318 electric fuel pump
Tap into anywire that comes on when the key is turned to RUN.. I wouldn't do the Oil switch though as already suggested.. The key is on= the pump will run.. Sound right?
Can You see the Real me?
WNYTractorTinkerer is offline
post #8 of 8 Old 07-28-2011, 07:44 AM
Three of my friends
biker3777's Avatar
I tried the electric pump but did not care for it,I now use a vacuum pump from John Deere Gator 2 wheel drive,works fantastic.
Jim
Real Lawn Tractors are Green,Just can't have too many toys,and Free is not Cheap.
1965 Round Fender
216 fitted with model 31 tiller
91 Honda Goldwing that I REALLY like.
Wife of 55 yrs that tolorates me
biker3777 is offline
