318 Losing power - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 30 Old 07-12-2011, 09:19 PM Thread Starter
318 Losing power
My brother gave me a 318 that was sitting idle in garage for 2 years with 38 inch mower deck installed on it for entire time (belts and all). The battery was dead and after replacing the battery the tractor ran smoothly without PTO being engaged.
The symptoms are this..
-Tractor loses power and almost dies if PTO is engaged (with deck installed)and driving uphill (especially if turning to right).
-PTO shuts down periodically when tractor loses power and switch needs to turned off then on again.
-Sometimes PTO won't engage , but if I put tractor in reverse slightly it will engage.
no strange noises or smells or smoke happening.
What I have done to fix is new fuel filter, oil and filter change, new plugs (all bought fron John Deere), new battery with 545 CCA (just brought it to shop and guy tested it and said it was fine), new battery wire leads, took off, cleaned and greased deck, set gap in clutch to .018 in., hydro oil and filter not changed, but fluid level O.K.
My brother said everything was running fine when he stopped using tractor two years ago and it had been maintained by John Deere mobile team up to that point.
I'm pretty much out of ideas at this point and would appreciate any advice or insights.
Could it still be the battery? It seems like the elsctrical system isn't giving enough juice to run the machine and PTO. Would a different battery with more CCA be an option?
Thanks for your help
mfabe is offline
post #2 of 30 Old 07-12-2011, 09:45 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: 318 Losing power
Sounds like you need to test the rectifier/regulator to make sure it is returning enough voltage to the battery to keep it charged.
Current Machine JD 322
PA318Guy is offline
post #3 of 30 Old 07-12-2011, 09:48 PM
The Magnificent
D-Dogg's Avatar
Sounds like you might have a few problems.
Possible intermittent seat switch, fuel delivery problems, possible grooved clutch disc(try 0.012" as gap), voltage regulator problems.
Try running through this list:
318 Baseline Maintenance Checklist
D-Dogg is offline
post #4 of 30 Old 07-22-2011, 09:20 PM Thread Starter
Thanks for your replys, D-Dogg and PA318Guy. I don't have tools to test voltage regulator but it looked a little corroded so I installed new one. Still losing power. I also set gap to .012" which did make things a little better. I have a little more power and its not stalling, but still not enough power to cut lawn. Think its a grooved clutch disk D-Dogg? I think fuel delivery is O.K. since tractor runs fine without PTO being engaged.
Thanks
mfabe is offline
post #5 of 30 Old 07-22-2011, 10:02 PM
deerhed
creekhed1's Avatar
Interested to see how this one turns out!
Good luck with the fix...hope it's an easy one!
Ingersoll 3012 w/ 38"Snowcaster.
SOLD:
Cub Cadet 2166 Cub Cadet 1554 Sabre 1538 John Deere GT275 with 42 Blower and 44" Plow John Deere 316 with 49 Blower
Ingersoll 3016 w/Hard Cab & Blower Case 224 Case 222 Case 222
Wheel Horse Lawn Ranger JohnDeere LX266
Simplicity Conquest John Deere GX345
John Deere 335 John Deere 345
John Deere 140H1 John Deere 140H3 w/Tiller
For Sale:
Cub Cadet 1525 Sabre 1742 HS
John Deere 316 Vid
Ingersoll 3016 Vid
creekhed1 is offline
post #6 of 30 Old 07-23-2011, 07:18 AM
my deere's Avatar
Have you checked the points? Make sure that they are clean and set properly. It sounds like a weak ignition. Does the charge light work? It should come on when the key is turned to on, and go off after it is started and running. knowing this would help diagnose the problem further.
my deere is offline
post #7 of 30 Old 07-23-2011, 07:40 AM
The Magnificent
D-Dogg's Avatar
Now that you have eliminated PTO gap, and the voltage regulator (hopefully you checked the output after installing the new), we need to address this power issue.
How does the tractor perform driving up hill wihtout the mower deck running? Better or about the same? Does the engine bog down, or the tractor simply slow down?
If better, let's attack the deck and mule drive first.
How do the spindles turn? They should spin very freely. Same with the mule drive pulleys. Is your belt routing correct? Is the belt the correct belt, rather than a narrower fan type FHP belt?
If the tractor is simply slowing down going uphill, then let's check the hyrdo linkages for slop as well as the brake adjustments (make sure you're not dragging the brake). You really should change the tranny fluid and filter as well.
Let's check the engine compression when hot. You may want to perform a valve adjustment also.
D-Dogg is offline
post #8 of 30 Old 07-23-2011, 11:37 AM
Verify that it's running on both cylinders.
rscurtis is offline
post #9 of 30 Old 07-23-2011, 03:18 PM
PA318Guy's Avatar
PA318Guy is offline
post #10 of 30 Old 07-24-2011, 08:35 AM Thread Starter
Deck checks out O.K., al is moving smoothly and tractor works great uphill without deck being engaged. Interesting thing about the cylinders. I don'y have equipment (or skill) to check if cylinders are working, I believe both are firing, but one spark plug is really fouled with fuel and when I unplug it during operation there is no noticable change to engine performance. Can it be a carb. problem?
mfabe is offline
post #11 of 30 Old 07-24-2011, 08:37 AM
The Magnificent
D-Dogg's Avatar
Nope, you have (hopefully only) a bad plug wire on that cylinder. Replace it and the fouled plug.
D-Dogg is offline
post #12 of 30 Old 07-24-2011, 10:50 AM
Switch the wires at the coil and see what happens. If the other cylinder starts running, you have a wire or coil problem. If nothing changes, there is a problem specific to that cylinder, such as a dropped valve seat, broken or disconnected valve spring, or at worst, a broken rod. Don't worry about the carb.- it's common to both cylinders.
rscurtis is offline
post #13 of 30 Old 07-24-2011, 02:56 PM Thread Starter
Switched wires at coil and tractor won't start.
mfabe is offline
post #14 of 30 Old 07-24-2011, 03:32 PM
The Magnificent
D-Dogg's Avatar
Did it start after you switched them back?
You switched the plug wires, right? Not the primary wires.
D-Dogg is offline
post #15 of 30 Old 07-24-2011, 03:34 PM
home-boy's Avatar
Broken rod?
I have seen 4 lately with broken rods. All start but have no power
JD 955 basket case
home-boy is offline
