Trouble with John Deere 214-noisy transmission? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 07-09-2011, 08:10 PM Thread Starter
I have a JD 214 lawn tractor. Has a 4 speed transmission with the variable speed control lever. On an incline, when you are pulling in 3rd or 4th gear, it mades a loud roaring sound. The sound quits when going downhill or not in a hard pull. Trying to figure if it is a bad pulley bearing or something wrong with variable speed control or in the transaxle?? Have checked the transaxle and it full of gear oil. Has anyone run into this kind of problem before or have any ideas what to check to find the problem??
Thanks.
Kart 14
kart 14 is offline
post #2 of 8 Old 07-09-2011, 08:12 PM
SonnyT's Avatar
Images: 26
Re: Trouble with John Deere 214-noisy transmission?
I would check out the Vari-speed belts and all its components.
If you need easy Picture help
Be sure to Register for Your State!
RIP Sonny T.
1954-2015
SonnyT is offline
post #3 of 8 Old 07-09-2011, 08:41 PM
ggsteve's Avatar
Are you talking about a sound like a cross between a rusty hinge on a closing dumpster door and a tuba? My 214 always does that if I'm in 3rd or 4th and I advance the variator lever to full speed. I changed my gear oil but it still makes the noise.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
74 Concord (MTD) 990
ggsteve is online now
post #4 of 8 Old 07-09-2011, 09:36 PM
Certified Master Tinkerer
Herd of Deeres's Avatar
Rear end noise is a standard feature on 214. There are some gear oils that are supposed to help - read through my 214 thread is you want to see what others posted on my problem. Link in my signature.
Herd of Deeres is offline
post #5 of 8 Old 07-09-2011, 10:24 PM Thread Starter
Thanks. I guess the variable speed controls, belts, etc. will be the easies place to start.
kart 14 is offline
post #6 of 8 Old 07-09-2011, 10:37 PM
close enuff works for me
deereboy55's Avatar
My 210 whines also ,have heard several others ,that sounded the same.It;s the way they were built.. It has been discussed here before , most all the 200 series transmissions ,have a whine.
deereboy55 is offline
post #7 of 8 Old 07-09-2011, 10:39 PM Thread Starter
My sound is like a 1950's old-style straight tooth geared transmission. Thanks.
Kart 14
kart 14 is offline
post #8 of 8 Old 07-09-2011, 10:41 PM Thread Starter
Thanks for the come-back. Will check on variable speed control belts, etc. to start with.
Kart 14
kart 14 is offline
