54" blade angle problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-31-2011, 07:49 PM Thread Starter
ccmdvl's Avatar
Question 54" blade angle problem
I had some dirt to move over the weekend and decided to use the 54" blade for the 425. If the load I was trying to push was off to one side (not in center) the blade would angle in that direction unless I kept adjusting the angle. I did not see any leaks. There was not a problem with raising/lowering.
If it makes any difference, when the mower deck is attached, it lowers if the machine is sitting for more than a few minutes (engine off). Not sure if this is normal, since I just picked up this machine over the winter.
Any suggestions?
Thanks you!
ccmdvl is offline
post #2 of 5 Old 05-31-2011, 08:10 PM
Deereman76's Avatar
Re: 54" blade angle problem
There should be a lockout valve directly under the SCV's (where the hydro lines hook up). That should be turned all the way in which will fix that problem, but the lockout must be fully open to let the mower deck arms move freely (for mowing).
Deereman
Owner of:
X485 AWS John Deere
X465 AWS John Deere
R70 John Deere
54C mower deck (2)
Deere 47" Quick Hitch Snowblower
Deere 54" Quick Hitch Blade
52" harrow
17P cart
48" thatcher
Tow behind spreader
Deereman76 is offline
post #3 of 5 Old 05-31-2011, 08:18 PM
Mike X485's Avatar
Images: 8
Deereman
What Deereman76 said.
JOHN DEERE X748
Mike X485 is online now
post #4 of 5 Old 05-31-2011, 08:21 PM
Still lovin' the 322!
PA318Guy's Avatar
The mower deck should slowly lower when the engine isn't running but it takes mine a day or two to drop all the way. The lockout valve is what you need though to hold the blade on an angle!
Current Machine JD 322
PA318Guy is offline
post #5 of 5 Old 05-31-2011, 08:49 PM Thread Starter
ccmdvl's Avatar
Very good, thank you. I will take a look when I get back to camp this weekend!
ccmdvl is offline
