x300 can't get off the fly wheel cover, help! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 05-08-2011, 06:55 PM Thread Starter
Was going to get the x300 out for the first time this year to cut the grass. I opened up the hood and noticed that there is a lot of what looks like a mouse nest in the flywheel... I tried to unscrew the 3 hex screws with out any luck. I felt that I would strip the screws if I applied too much pressure. I put some PB Blaster on the screws as well and they did not budge.
Is that a special tool for this or some trick I don't know about to get them off?
Also I am guessing that it would be a dumb idea to start the tractor with this debris in it correct?
Thanks!
jsaw14 is offline
post #2 of 4 Old 05-09-2011, 05:37 PM
pawber's Avatar
Re: x300 can't get off the fly wheel cover, help!
The fan housing & screen bolts are listed as 52 in lbs.
Uh, you are not trying to tighten them are you. Hey,just thought I'd ask.
Paul B
09 JD X300/42X deck (321 hours)
02 JD 724D snowblower
had a JD 214 - 11 years
had a Bolens QT16 - 7 years (talk about a whiney transaxle)
had 2 Bolens 1050's - 21 years & 3 years
pawber is offline
post #3 of 4 Old 05-09-2011, 05:51 PM
JRJ
The owners manual
JRJ's Avatar
Remembr those screws/bolts turn counterclock wise to remove. You could get yourself a good chisel (not to big) and a small hammer and try tapping the screw/bolt out. If you haven't ever done it, you place the chisel blade on the screw/bolt head slanted so it would force the screw/bolt in a counterclock wise direction and then start tapping on the chisel end lightly. If I remember correctly you had put some PB Blasters on it yesterday, should be ready to come off now.
No special tool need, just a socket or nut driver.
Dick
GT275
GT235
JRJ is offline
post #4 of 4 Old 05-09-2011, 09:21 PM
Sidponcho's Avatar
had a nest in mine last Spring.....just put on some cool sunglasses, and fire it up!!!
Sidponcho is offline
