JD 445 fuel filter - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 05-03-2011, 10:24 PM Thread Starter
rcdebeau's Avatar
JD 445 fuel filter
OK, I have a new fuel filter for my 445. The manual says to "reach under platform (picture shows right side) and squeeze clips to disconnect". Well, have looked all over under the platform and can't find it. The manual makes it sound like it's right there in front of you. Also, I have the deck on...if I take the deck off will that allow me to get to where I need to go? I'm sure that it is probably right in front of me...I just can't seem to see it.
Thanks for any help!
rcdebeau is offline
post #2 of 11 Old 05-04-2011, 06:53 AM
OLD88's Avatar
Re: JD 445 fuel filter
You are better off taking deck off.Filter is located on right side foot well wall. Mine is attached with a clip that has a hex head screw holding it to frame. Hope this helps.
JD 445 1990
Kubota 1460
Kubota 2950 w/FEL shuttle shift
Kubota L225 72" bell mower
OLD88 is offline
post #3 of 11 Old 05-04-2011, 06:58 AM
69project's Avatar
Hmm, I replaced mine on my 425 yesterday. I realize your is a fuel injected motor and mine is a carb but its the same engine. My filter was on the right side by radiator. If you remove the right side panel, it is right there. I had no need to remove the deck. I would check that first prior to going to the hassle of dropping the deck.
69project is offline
post #4 of 11 Old 05-04-2011, 07:34 AM
Beech33's Avatar
The fuel filter for the DFI units is much larger and it has 2 flange tabs used to attach it to the tractor.
___________________
2005 X485 54C Deck, Gator Blades
1998 GT275 48" Deck, HDAP Front and Rear, X700 Seat
1988 10 Cart
1990 STX38 Yellow Deck
Beech33 is offline
post #5 of 11 Old 05-04-2011, 08:16 AM
bvp2000's Avatar
yep, JD did a nice job of hiding the 445 fuel filter. Definately easier access w/o the deck on.
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline
post #6 of 11 Old 05-04-2011, 10:15 AM
Quads's Avatar
You missed me by a day. I put my deck on yesterday, and had it been off, I'da gotten under it to take pics for you to see where they hide it.
Quads is offline
post #7 of 11 Old 05-04-2011, 01:29 PM
ksp
ksp's Avatar
Mine is on the inside of the right frame rail. I have a pit so with my deck off I drive over top of the pit and can get at it fairly easy. It is not in a easy place to get at as far as I am concerned for most people to replace.
1996 445, 42" Hyd tiller, 54" mower deck, 47" Snowblower DeckDolly.com
ksp is offline
post #8 of 11 Old 05-04-2011, 03:25 PM Thread Starter
rcdebeau's Avatar
Thanks for the tips guys. I should be able to get to it one way or the other, now that I know where it is.
rcdebeau is offline
post #9 of 11 Old 05-04-2011, 05:02 PM
Diesel Power
andyb's Avatar
It's such a pain to get to that my dealer said not to replace it on my 445 as long as it's running ok. Thanks JD.
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
434 hours and counting
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is offline
post #10 of 11 Old 05-04-2011, 07:44 PM
69project's Avatar
I don't know if I trust that advice. When I changed mine yesterday on my 425 it was extremely dirty.
post #11 of 11 Old 05-05-2011, 10:42 AM Thread Starter
rcdebeau's Avatar
Took the deck off this morning and found it, no problem. Manual says to access it from right side, but I found it much easier to crawl under from the left side, FWIW... 30 minutes had everything back together and ready to go.
69project, unfortunately, on the 445, the filter is a solid black plastic housing (about 6 inches), that unless you take a saw to it and cut it in half, you can't tell if it's dirty, clean, ....
Quads, regarding the rpm issue you helped with in my other thread...seems it is still there. However, if I back the throttle off just a tiny bit, (and I mean just enough to barely hear a difference in rpm/sound level) it seems to go away.
FYI, still glad I put in a new set of plugs and fuel filter!!!
rcdebeau is offline
