JD 445 seat on a 425? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 03-23-2011, 11:10 AM Thread Starter
I have a 1995 425 that has the shorter seat on it. I'd like to know if I could purchase a seat for a 445 (taller back seat) and put it on my 425. Is it a direct bolt up or does it take different mounting hardware?
98ramtough is offline
post #2 of 8 Old 03-23-2011, 12:03 PM
bvp2000's Avatar
Re: JD 445 seat on a 425?
There is a different mounting bracket, on the 445 and 455 there is just a cotter key to remove and then the seat pulls off, it has a couple of brackets on bottom for a rod to go thru. I don't believe the 425 has these, not that you couldn't replace the whole seat bracket though.
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline
post #3 of 8 Old 03-23-2011, 12:35 PM
Deere Guru
Dunkelstar's Avatar
Images: 39
Is the 445/455 seat that much better? I need a new 425 seat . . . and I've thought about the whole bracket and seat from a 445/455, but wasn't sure if it was really worth it.
1996 John Deere 455 AWS
1996 John Deere 425 - w/ upgraded tire size, rear PTO, and 3PT Hitch
#40 Loader, 54 and 48" MMM Deck, 46" Snow-Thrower, 54" Front Blade, Agri-Fab 3PT Core Aerator, Agri-Fab Chip-n-Vac, and #80 Cart
Dunkelstar is offline
post #4 of 8 Old 03-23-2011, 12:54 PM Thread Starter
It's got a higher back to it which I like. I like the seat on my 2305 a LOT better than my 425 due to the taller back on it. I might make you a great deal on a like new original 425 seat....
post #5 of 8 Old 03-23-2011, 12:58 PM
Deere Guru
Dunkelstar's Avatar
Images: 39
If you do move forward with the new seat setup, I would be very interested.
post #6 of 8 Old 03-23-2011, 09:40 PM
2001gagt's Avatar
You can just change your seat, did it on Dad's 425 when he had it. But if you what to upgrade the suspension don't get the one for the 445/455 way to much money get one for the x595 that is what I did. Only ting I could see between the two was the 455 suspension had bolts build into it and the x595 suspension just had the holes.
Link to what I did Seat upgrade on a 455
1997 John Deere 455
2001gagt is offline
post #7 of 8 Old 03-23-2011, 10:42 PM
98ramtough, I put the deluxe seat and suspension from an X748SE on my X748 and kept the original suspension. The deluxe suspension was put on when I bought the new tractor so the original suspension is new. I sold the original seat but have a seat from an X595 that has a crack or two but is still very usable.
If you have some interest send me a personal message.
Thanks,
Terry,
tweivoda is offline
post #8 of 8 Old 03-26-2011, 11:28 AM
Just John Deere
GotDeeres's Avatar
Images: 8
98ramtough,
I have a high back seat like the one on a 445, but it has a bolt pattern that should fit your 425. It came off a 322 that I bought but was installed using only 2 bolts. I never knew exactly what it was designed for, but it may fit. I will take a picture of the bolt pattern Monday and post it. I have two 455's with the high back seat and it is SOOOO... nice for my back.
GotDeeres
Just John Deere
425 Garden Tractor with 54C Deck
425 Garden Tractor with 60" Deck
455 Diesel with 60" Deck, 3 Point MCS
455 Diesel with 60" Deck, 3 Point and 540 PTO
455 Diesel with Buford Bucket Compact Loader
2210 CUT with Buford Bucket Compact Loader
John Deere TS Gator
GotDeeres is offline
