first post w/ x500 brush guard question ! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 03-12-2011, 12:59 PM Thread Starter
Question first post w/ x500 brush guard question !
Great site guys & gals ! Just installed my bucket holder, which looks nice, and will come in handy. Remember folks, it will hold your favorite beverage on ice also !! Also just installed the brush guard on my x500. Looks nice, but has anyone fabricated the bushings, so it does not rattle and jiggle ! I'm sure i will come up with something, but thought i'd check here for help ! Thanks in advance !
d.mehrl is offline
post #2 of 6 Old 03-12-2011, 08:54 PM
MTF Tractor Nut
wizzo's Avatar
Re: first post w/ x500 brush guard question !
Hmmmmm.... I don't have one installed (yet), but I didn't realize that the brush guard made noise or else someone would have come up with a fix for it by now.
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline
post #3 of 6 Old 03-13-2011, 12:13 AM
cleanmaxxbrian's Avatar
Yup...hated that rattle! Here is what I did...
Locate the lower bolt and remove it. You will find a spacer. Grind the spacer down so it is not as long. Now when you bolt it back together and tighten the nut, it will make the whole brush guard harder to fold forward. When you put the cross rod in, pull the guard all the way forward or back to hold it against the rod and it won't rattle now either! This takes out the slop and keeps it from making noise! As for how much to grind down...when you pull it apart, it will make sense to you. The spacer makes for the slop I did both sides.
The white nylon washer is to keep the pins from scratching the frame...
Brian Chang
2010 Select Series X540
Mulch kit, Gator blades, Stripe kit, 40" Tractor Shovel, Headlight upgrade, Custom tail lights, Brush Guard, Rim Guard, Wheel Spacers, Suitcase weights, Single Bucket holder, seat back pocket, Hitchin post, 10p cart, JD 42" sweeper, 25 gallon sprayer, JD 40" plug aerator and 40" spike Aerator/Spreader
1998 John Deere LT155 SOLD
cleanmaxxbrian is offline
post #4 of 6 Old 03-13-2011, 03:04 AM
KATT's Avatar
Good ideas Brian !!
Current 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
"11" X540 54" Deck
Some LX 188's and a few 100 series
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled ."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck.
Sold Rusty
KATT is offline
post #5 of 6 Old 03-13-2011, 12:17 PM Thread Starter
Thanks for the info brian. I actually had that same idea in mind after thinking on it for a bit. p.s. your x500 looks awsome !
d.mehrl is offline
post #6 of 6 Old 03-13-2011, 01:02 PM
Welcome to the forum D.mehrl
2010 JD 2520, 200CX Loader, 61" Bucket, 55" Front Mount Snow blower, JD 655 56" Tiller, Artillian QA Forks, Home made 3pt carry all
JD 165 (not running)
1956 AC WD-45, Forward facing rear mount snow blower, 2 mounted cultivators
2009 Cub Cadet 50" Zero turn mower
Troy Built Horse 8 hp Rear Tine Tiller
Craftsman 6 hp push mower
Chaddo is offline
