Cheapest way to lift engine out of 318 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 03-03-2011, 08:27 AM Thread Starter
Fellas,
I'm planning to change the oil filter adapter. Apparently, I need to remove the engine to do so. I don't have an engine hoist.
Is it too heavy to lift?
What is the cheapest way to lift it?
Anyway I can change the filter adapter without removing the engine?
Thanks
ribs1 is offline
post #2 of 16 Old 03-03-2011, 08:30 AM
Lawn Boys Never Die
miller17636's Avatar
Re: Cheapest way to lift engine out of 318
I don't think it would need a lift to be removed. You and a strong friend should be able to handle it.
2010 John Deere x320
1988 John Deere 318, 47" 2 stage snow blower, quick hitch, Cozy Cab Series II, 51 broom
1987 John Deere 332, 44 loader
1986 John Deere 330
Lots of Lawn boys
miller17636 is online now
post #3 of 16 Old 03-03-2011, 08:30 AM
jakenbake's Avatar
might be able to take the mounting bolts off and tip it. not too heavy, like 150 lbs.
2001 JD 345
54" MMM
44" Piranha MMM
JD 48" Front Blade
1988 JD 855
70A Loader
7 Backhoe
60" MMM
503 Rotary Cutter
jakenbake is offline
post #4 of 16 Old 03-03-2011, 08:32 AM Thread Starter
Can the tins be removed without removing the engine?
Service manual says to remove engine.
Thanks
ribs1 is offline
post #5 of 16 Old 03-03-2011, 08:35 AM
Lawn Boys Never Die
Thanks
Yes tins can be removed without removing engine. Maybe try that first before yanking the engine out.
1986 John Deere 330
Lots of Lawn boys
post #6 of 16 Old 03-03-2011, 10:38 AM
If you have to pull the engine, you can use a come-along attached to the roof rafters in your garage. Run a 4x4 across two or more rafters, sling a chain over it, and attach the come-along to that. It's not ideal, but it's not bad in a pinch.
Reverend Blair is offline
post #7 of 16 Old 03-03-2011, 11:58 AM
jakenbake's Avatar
all can be removed except the one covering the flywheel
2001 JD 345
54" MMM
44" Piranha MMM
JD 48" Front Blade
1988 JD 855
70A Loader
7 Backhoe
60" MMM
503 Rotary Cutter
post #8 of 16 Old 03-03-2011, 03:03 PM
Junior Senior MTF Member
MTD Tradesman's Avatar
Images: 3
you could do it the redneck way and use a good, strong yet flexible tree limb lol lol
Owned in the past:
-1984 MTD Tradesman GT 18HP Briggs & Stratton, 46"
-1981 John Deere 214 14HP Kohler K321, 46" Deck
-1980's Lawn Boy 5HP, 22" Deck
-1990's Honda 6HP 26" Deck
Owned Now:
-2002 Craftsman LT100 17HP Briggs & Stratton, 42"
-1993 Wizard LT 18HP Briggs & Stratton, 42" Deck
-1986 Snapper Series 6 12HP Briggs & Stratton, 33"
-1968 Snapper Comet 26, 7HP Tecumseh, 26" Deck
-1963 Lawn Boy 3003 2-Cycle 3HP, 18" Deck
-1953 Briggs & Stratton 6S 1.5HP Engine
MTD Tradesman is offline
post #9 of 16 Old 03-03-2011, 05:37 PM
collegekid
collegekid's Avatar
I have yanked a few heavier engines out of mowers and I have always used the same method. I get myself and one of my roommates and we do it old school; with our own hands. It is cheap, effective, gets the job done, and you feel like a man afterwards. Just my 2 cents worth... good luck with your project
John Deere JS40 walk behind
John Deere 265- restart complete, restore in progress
John Deere 300- next in line behind the 265
Previous Equipment:
SCAG 48" belt driven walk behind
John Deere lx172
Craftsman POS
collegekid is offline
post #10 of 16 Old 03-03-2011, 05:42 PM
Still lovin' the 322!
PA318Guy's Avatar
It's the putting it back in that will be the issue. Unless you remove the shaft to the hydrostatic pump and put it in from underneath. If you're going under it, take the shaft off first before removing the engine and the engine will be much easier to take out and put back in. Good luck with your tins, I hope they will come off for you!
Current Machine JD 322
PA318Guy is offline
post #11 of 16 Old 03-03-2011, 05:50 PM
SonnyT's Avatar
Images: 26
Yep, when I was in College I was old school also on most everything. 8 of us lifted a VW and carried it up 10 steps to a Court Yard!
30 years later, I should have done a bunch the easy way instead of manhandling stuff!
RIP Sonny T.
1954-2015
SonnyT is offline
post #12 of 16 Old 03-03-2011, 06:06 PM
Considering the cost of Chiropractors, Doctors, physical therapy, time lost from the job and wound dressings. Along with dropped and broken engine, damage to tractor or other objects in the general vicinity as well as reprimands and sneers from SWMBO I'd guess the cheapest way would be to rent an engine hoist for a day or two.
Just my opinion of course.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #13 of 16 Old 03-03-2011, 06:08 PM
Justinh595's Avatar
I pull mine out with a $13 dollar come-along attached to a 2x4 truss in my garage. It can easily be pulled with 2 guys by hand. I do find it easier to work on hung up though because you can twist, turn and get under it easily.
*1991 John Deere 420 with 44 loader
*1991 John Deere 430
*1979 Ford 1900
Justinh595 is online now
post #14 of 16 Old 03-03-2011, 07:38 PM
Onan18's Avatar
I pull them out all the time by hand, by myself. They are not as bad as a CH26 fuel injected Kohler, that is one heavy son of a b!%($
Onan18 is offline
post #15 of 16 Old 03-03-2011, 08:15 PM
I replaced the gasket under the oil filter adapter on my 318 without pulling the engine. It can be done. It isn't easy, but certainly possible. I had all tins removed to do it.
In the pic below (from when I did a valve adjustment and carbon cleaning), you can see the oil filter (in lower left) and top bolt attaching the housing to the engine block. Remove the filter and then you can get to the lower bolt pretty easily.
1987 JD 318
Carlisle HD Field Trax (HDAP 24x12.00-12 and 16x6.50-8)
46" Mid-Mount Mower Deck with Power Flow
54" Blade with Power Angle
OEM Front Weight Bracket for 8 Suitcase Weights
Looking to buy a 49" single stage snow thrower
stevieb92 is offline
