Quick Question - Reverse threads on mower deck blade bolts? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 02-19-2011, 01:20 PM Thread Starter
taltimus's Avatar
Are the bolts holding on the blades on my 54" deck (for a 445) reverse thread or normal? I've having one helluva time getting any of them off...
~Tim
-- 2000 John Deere 445 2WS
-- 54" deck
-- 54" blade
-- 40 Loader
-- Ruegg 0/1 Combo 3pt
-- Cat 1 Super Heavy Hitch
taltimus is offline
post #2 of 13 Old 02-19-2011, 01:33 PM
The Travelin' Mod
davidg's Avatar
Re: Quick Question - Reverse threads on mower deck blade bolts?
never dealt with a 445, but my L130 and my X500 are both regular thread. try tapping with a hammer as you attempt to turn them, they do tend to stick tight.
Check out our new HOMEPAGE
davidg is online now
post #3 of 13 Old 02-19-2011, 01:41 PM
4K Poster!!!!
8086bruce's Avatar
They do stick the last time I took mine off my old jd one was stuck so back I broke my ratchet.
John Deere X758
54HC deck
54" Quick hitch blade
47" Quick hitch blower with side plates
JD Weather Enclosure
8086bruce is offline
post #4 of 13 Old 02-19-2011, 04:28 PM Thread Starter
taltimus's Avatar
Yeah, I almost broke my 3/8 drive ratchet as well, it slipped out of the gearing, I thought it had broke... soooo, I went to Sears and bought myself a 1/2 drive flex/breaker bar and a set of 1/2 drive sockets. I still had to put a piece of 1" pipe over the handle to get the bolts loose.. yowsers!
Anyway, thanks for the info. I did get them all off, and without breaking anything :-)
~Tim
-- 54" deck
-- 54" blade
-- 40 Loader
taltimus is offline
post #5 of 13 Old 02-19-2011, 04:33 PM
Brockway
SARG's Avatar
I always use a box end wrench and a brass mallet.
SARG is offline
post #6 of 13 Old 02-19-2011, 04:46 PM
Me
TennesseeJim's Avatar
Try some PB Blaster from the auto parts store or hardware store. If you are still having trouble. Tap it lightly with a small hammer after soaking let it work it's way in.
That stuff really penetrates well................
TennesseeJim is offline
post #7 of 13 Old 02-19-2011, 04:51 PM
SonnyT's Avatar
Images: 26
They should all be standard thread or they would have a tendency to loosen when running.
RIP Sonny T.
1954-2015
SonnyT is offline
post #8 of 13 Old 02-19-2011, 06:29 PM
bvp2000's Avatar
Make sure you put in new bolts and coat them with anti sieze...I never reuse those bolts...
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline
post #9 of 13 Old 02-19-2011, 07:12 PM
I have a JD 445 the Treads are Right Hand, These are good size Bolts, if i remember right it takes a 15/16 socket, to make them come out with out so much trouble, put a little Never Seze on the threads before you reinstal the blades, what you need to do is get a short chain, like 1/4 in. about 3 or 4 ft. long, with a hook on one end, place the hook over the end of the blade and rap the chain around something to hold the blade, i put a 3/8 in. bolt through the chain end to keep the chain from slipping, now that you have the Blade where it wont turn, take a good 6 point socket on either a 1/2 impac or a 1/2 in braker bar with a short piece of pipe for a cheater bar, i have a piece of 1 in. pipe about 18in. long that i use, when you put the blades back on check in the owners manual they may have how much torque they need, if not just use the braker bar, but not the cheate bar, i bet the bolts were put in dry last time there were out, OR some one put them back on with a impac wrench and went WAY to TIGHT, I just went out to the shop and checked the Book, it calls for 83 FT. Lb of torque, i dont ever do that because i have worked of stuff enough to know, if you are not familar with things like this, best thing i can tell you to do is tighten them up about as tight as you would tighten the lug nut on a car tire, another Thing the heads of the bolts will ware, dont let them go to the point that your socket wont catch, i change my bolts about ever 3 years,
LakeRat1 is offline
post #10 of 13 Old 02-19-2011, 09:00 PM
Still lovin' the 322!
PA318Guy's Avatar
on the never sieze compound. Save a lot of headaches taking them off!
Current Machine JD 322
PA318Guy is offline
post #11 of 13 Old 02-19-2011, 09:02 PM
Impact gun...
Engine_Tech is offline
post #12 of 13 Old 02-19-2011, 09:56 PM
JD X728's Avatar
Welcome to the forum!
I like the sound of your post. Keep up the good work!
JD
JD X728 is offline
post #13 of 13 Old 02-19-2011, 09:59 PM
Originally Posted by Engine_Tech View Post
Impact gun...
My choice every time.
Reverend Blair is offline
