Need help with 455 Quick Hitch Adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 01-22-2011, 08:43 PM Thread Starter
455
455's Avatar
Hi All,
Needed a resource for an issue I'm having, found this forum, thought I'd give it a try. Have a JD455 with a JD Quick Hitch (4 way hydraulics) with a JD 54" blade.
During the last few days of plowing snow the left angling of the blade has been reducing a good amount with the right angling seeming to become more pronounced. Vertical hydraulics are working fine.
I have the original manuals for everything, but didn't readily find mention of how to correct this.
Thanks for any help any of you can offer. On a separate note, I think I'll be looking to purchase a snow thrower implement for the quick hitch next season. Any recommendations for where to purchase something used?
Thanks again!
455 is offline
post #2 of 8 Old 01-22-2011, 08:56 PM
Diesel Power
andyb's Avatar
Re: Need help with 455 Quick Hitch Adjustment
I had a quickhitch with a blade on a 445 and found that snow would pack and freeze around the angling cylinder limiting the travel of the blade. That shouldn't affect the angling to the right though. The only other thing I can think of is the diverter valve, or lockout valve, that limits hydraulic fluid flow to the cylinder that raises and lowers the mower deck. If it isn't closed all the way it could affect the speed of the angling cylinder.
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
434 hours and counting
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is offline
post #3 of 8 Old 01-22-2011, 09:07 PM
SonnyT's Avatar
Images: 26
If you need easy Picture help
Be sure to Register for Your State/!
RIP Sonny T.
1954-2015
SonnyT is offline
post #4 of 8 Old 01-22-2011, 09:27 PM
Admin
Mike X485's Avatar
Images: 8
455, Welcome to the forum. Need more info on whats going on with the blade. Is it not moving far enough to the left? Or not staying there?
JOHN DEERE X748
Mike X485 is online now
post #5 of 8 Old 01-22-2011, 11:07 PM
Way Out Here
Jfoi's Avatar
Originally Posted by 455 View Post
Hi All,
Thanks again!
The same thing happened to me last year... do not and i repeat do not force it. the line that is connected to the angling has a 90 degree elbow that broke cause i had the same thing happen... your best bet is to get a little heater and heat the snow up and let it melt. what happens is the snow gets compacted and it wont let it get to full angle
John Deere x320
48" xtra cutting system
44" front blade
John Deere 455
60" commercial belly mower
54" quiktach dozer blade
Jfoi is offline
post #6 of 8 Old 01-23-2011, 05:14 AM
USMC
slkpk's Avatar
Images: 21
Also check your hydraulic fittings on the cylinder as they may have loosed up and be catching on the frame. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #7 of 8 Old 01-23-2011, 12:52 PM
9K+ Poster
JDFANATIC's Avatar
Welcome to the forum! Good advice above.
Cheers
JDFANATIC
JDFANATIC is offline
post #8 of 8 Old 01-23-2011, 05:14 PM Thread Starter
455
455's Avatar
Thanks for your feedback everyone. Snow had frozen in the angling hydraulic relief. Removed it and all's well again. Luckily, the elbow hardware wasnt damaged. Got some before and after pics I'll upload later of this. Maybe that'll be helpful for someone else down the line!
455 is offline
