JD 170 Snow Blower - How do you remove auger from blower housing? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 12-21-2010, 04:17 PM Thread Starter
I am breaking my JD170 blower down so I can remove the rust and repaint. The blower chute is going to get sand blasted, but I am going to wire wheel the blower housing because I would have to wait until the sandblasting place was doing an outside job.
I have everything removed except for the auger.
One on side of the auger there is the gear that drives the auger shaft. It had a set screw, but it is still stuck on there good.
There is also bearings assembleys on each side of the housing, one assembly is hiding behind the gear I just mentioned.
I am not sure what order I should be tackling this. I don't want to bugger up parts if there is a better procedure to break it all down.
Thanks!!!!
Freefall_Doug is offline
post #2 of 10 Old 12-21-2010, 06:00 PM
deerhed
creekhed1's Avatar
Re: JD 170 Snow Blower - How do you remove auger from blower housing?
I WAS gonna go the route you are describing but decided to "get in there" as best I could with an angle grinder and sandpaper with the auger still attached. In the end I painted it yellow and it turned out GREAT. Glad I passed on the dis/re-assembly...but if you are into it go for it (alas I have no real useful info here!).
Ingersoll 3012 w/ 38"Snowcaster.
SOLD:
Cub Cadet 2166 Cub Cadet 1554 Sabre 1538 John Deere GT275 with 42 Blower and 44" Plow John Deere 316 with 49 Blower
Ingersoll 3016 w/Hard Cab & Blower Case 224 Case 222 Case 222
Wheel Horse Lawn Ranger JohnDeere LX266
Simplicity Conquest John Deere GX345
John Deere 335 John Deere 345
John Deere 140H1 John Deere 140H3 w/Tiller
For Sale:
Cub Cadet 1525 Sabre 1742 HS
John Deere 316 Vid
Ingersoll 3016 Vid
creekhed1 is offline
post #3 of 10 Old 12-21-2010, 07:32 PM
KATT's Avatar
My buddy helped me take mine out.( well I mostly assisted) after unbolting the ends and shearbolt etc. there are 2 keyways to watch out for. Then we had to hit it with a sledge hammer ( busted a couple of 2X4's ) as cushions and used some " unclean words " the shaft finally moved !!
you need to support the auger as you remove the shaft.
Good luck and I feelit is a 2 man job at best !!!!!!
I'm sure you read my post and pics on my #38 reno
KATT is offline
post #4 of 10 Old 12-21-2010, 07:34 PM Thread Starter
Just fitting sandpaper in wouldn't work. To much rust due to PO sucking up gravel on his driveway.
I got it all apart now except for the cutting edge. The cutting edge bolts are spinning. Will need to grind the heads off.
I am leaning towards having everything blasted if I can find a place that has a big enough cabinet.
post #5 of 10 Old 12-21-2010, 07:37 PM Thread Starter
KATT yes I read your post but haven't reread it. It is a one man job with a 2 jaw gear puller, but you have to take your time!
post #6 of 10 Old 12-21-2010, 07:38 PM
KATT's Avatar
I had to grind ALL the heads off. the good news the PO never turned it around so I didn't have to buy a new one !!!!!
KATT is offline
post #7 of 10 Old 12-21-2010, 08:34 PM Thread Starter
Same here, I can reuse it. It will go back on this season, but I think plastic strip made of cutting board material might work well.
post #8 of 10 Old 12-21-2010, 08:49 PM
KATT's Avatar
Good idea don't know if you knew but the resto was for my Nephew.
He got all you see in the thread the restored 175 the restored #38 blower and the restored #38 mower. The good news his father my brother picked up the ( purchase) bills for nephews Christmas present. I supplied the labor and replacement parts as my contribution. and I keep Rusty for my trouble !!
I never got anything like that for any of MY Christmas'
KATT is offline
post #9 of 10 Old 12-22-2010, 06:44 AM
lahkota's Avatar
When I rebuilt the blower for my GT275 I ran into the same problem with the cutting edge bolts. I laid a board over top of a couple of bolt heads, clamped it down with a c-clamp, and was able to get the nuts off. Hope this helps, grinding off bolt heads ain't no fun.
lahkota is offline
post #10 of 10 Old 12-22-2010, 04:06 PM Thread Starter
I only needed to grind two. The other ones I notched with a cut off wheel and used a big screw driver to hold the bolts still.
Dropped all the parts off for sandblasting, they should be ready sometime next week
