anyone inerested in a 54c blade with hyd-angle - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 12-17-2010, 08:02 AM Thread Starter
sts25straight's Avatar
Images: 17
I'm picking up a second 54c blade. I have no idea why I need it,I hardly use the one I already have so I will sell the second blade. Before I list it on CL I was wondering if anyone here was interested in it. I know its one of those rare attachments and is worth a bit of money,so I thought maybe I would consider trading towards other John Deere items.
I will make a list of a few things that interest me.
1) 3-pt hitch for 140
2) 50 or 46 mower deck in good condition
3) power flow/ mcs
4) all steel Cozy Cab in good condition
5) 26/12/12 Tru-powers
6) good running 300,316k,317 tractor. Or other tractors ??
7) wheel weights. rear,front,starter weights
8) 80/50 cart
9) Cub 149
10) Brinly 3-pt plow
11) JD slab weights with front bracket
This blade has never been assembled (NOS).
Trade,partial trade/cash or I will trade and put up cash(for the right deal). And of course CASH.
Feel free to comment.
John M, Lodi.NY
79 314 Cozy cab/54 blade
73 140 H3
My snow duty videos
80 cart , Cozy cab,patio 54 blade, rear PTOs,Two 33 tillers, two sleeve hitch,2 10"Brinly plows.7-8 mower decks,54 center blade-HYD angle
sts25straight is offline
post #2 of 14 Old 12-17-2010, 08:13 AM
k91
Re: anyone inerested in a 54c blade with hyd-angle
What do you want a Cub for? Just kidding guys I think someone was looking for one on here. Maybe Glockem could add it to his collection
k91 is offline
post #3 of 14 Old 12-17-2010, 08:29 AM Thread Starter
Images: 17
I've always wanted a Cub 149,why....I don't know. lol I think Glockem already has a 54c blade.
John M, Lodi.NY
73 140 H3
My snow duty videos
post #4 of 14 Old 12-17-2010, 04:51 PM Thread Starter
Images: 17
I just picked up the blade. It has a few spots of surface rust where the paint has pealed off. The blade shows on sighs of use.All the hardware is there and has never bolted on a tractor. I believe this blade has sat in a garage, dissembled since it was bought new!
The paint needs to be touched up but other then that this 54c is perfect.
John M, Lodi.NY
73 140 H3
My snow duty videos
post #5 of 14 Old 12-17-2010, 07:26 PM
John Deere 316 Onan
SWIGIN's Avatar
Images: 3
I was wondering what makes a C blade different then any other one? And how many different 54'' blades are there and how do you tell what you have?
1988 316 Onan P218 with 50'' deck
770 hours
4 way 54'' snow blade
Custom trailer lifter run off rock bar
Stainless grab handles
Custom graphics
Original UNCRACKED seat....Finally cracked in 2015
318 H2 swap with hydro cooler
Loaded tires (16 gallons)
318 tail lights
318 brake pedals
www.egiautowraps.com
SWIGIN is offline
post #6 of 14 Old 12-17-2010, 07:30 PM
Wfburton159's Avatar
Images: 54
C is for center or the blade under the middle of the tractor.
2003 John Deere X485
647 tiller
54c deck with power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #7 of 14 Old 12-17-2010, 08:01 PM Thread Starter
Images: 17
here is a picture of my 73 140 with a 54c blade
ID:	134895   Click image for larger version
John M, Lodi.NY
73 140 H3
My snow duty videos
post #8 of 14 Old 12-17-2010, 11:18 PM
Tractor Nut
Hans-X585's Avatar
Sweet 140. I like all those wheel weights and ribbed front tires!
Hans-X585 is offline
post #9 of 14 Old 12-18-2010, 12:10 AM
Aksarben96's Avatar
Someones going to be a very lucky person to get that !
Such a shame 1000 miles to far and not enough green
1974 JD 140 H3 with Johnson 12A loader,48" mmm ,54" 4 way plow,precisefit spreader
1999 Ariens LT12,Agri-fab poly 10 cart,
Brinly poly roller,Husqvarna trailer 275
Troy-bilt Pony Tiller
1995Toro 824 powershift w/cab, John Deere 14sbs sp
1993 Snapper 5hp mulch convert. sp.
Nebraska Winter http://www.youtube.com/watch?v=xvqF768uDxM
Nebraska Green http://www.youtube.com/watch?v=OeNt_3a6OT8
Hail http://www.youtube.com/watch?v=3U79qL5fofQ
Aksarben96 is offline
post #10 of 14 Old 12-18-2010, 07:17 AM
I call it a grader blade b/c it's mounted between the two axles.
Nice!
timmy22 is offline
post #11 of 14 Old 12-18-2010, 03:00 PM Thread Starter
Images: 17
The 54c blade will be going to a fellow JD collector from this site. Thanks Foy, I'm sure you will enjoy it !
Thank you......John
John M, Lodi.NY
73 140 H3
My snow duty videos
post #12 of 14 Old 06-10-2015, 09:46 PM
What does something like this go for? I have been looking for one and/or the plow for my 316/318.
Jimb003 is offline
post #13 of 14 Old 06-10-2015, 10:21 PM
Wickedcoyote's Avatar
If it doesn't work out, I've been wanting one too.
Tractors:
1976 JD 300 w/48in. replacement deck
1980 JD 317 w/Johnson 10TC loader
1986 JD 316 w/48in. deck, 54in blade, & 30 Hyd. Tiller
2003 JD x595 w/62in deck, 3pt, 45 loader, 54 snowblower
Wickedcoyote is offline
post #14 of 14 Old 06-10-2015, 10:38 PM
Father Deerest
They aren't made to fit the open frame 316-318 without a lot of modifications. They will bolt up to the closed frame 120-140 and 300 up to a certain serial number on the 317. The problem is the later 317 has a pick up tube that comes straight out and will be crushed by the center blade frame so some folks cut a huge notch out to remedy the issue. I had to switch the p/u tube to that of a 300 brass 90deg and the top fitting to a flush to compression.
I have 2 54c blades. My let it go price right now would be $1000 for the hydraulic angle, if someone wants one bad enough they'll pay for it. Not holding my breath at that price but I would like to find a 140 H3 like what Mr.Beef found and dedicate it to grading and light lawn rolling.
Father Deerest is online now
