Shear bolt size for 44" select series blower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 12-16-2010, 08:33 AM Thread Starter
The dealer never gave me the manual for my blower, so if anyone would let me know the size of the shear bolt for the 44" select series snow blower, that would be greatly appreciated.
Thanks.
kirscp is offline
post #2 of 14 Old 12-16-2010, 10:03 AM
Certified Master Tinkerer
Herd of Deeres's Avatar
Re: Shear bolt size for 44" select series blower
Try the John Deere Parts Catalog
Probably need to start with your tractor and work your way through accessories.
Herd of Deeres is offline
post #3 of 14 Old 12-16-2010, 03:40 PM Thread Starter
Thanks, it comes up with 19M7834 - SCREW - M6 X 45
kirscp is offline
post #4 of 14 Old 12-16-2010, 05:12 PM
Banned!
Smile Re: Shear bolt size for 44" select series blower
If you bought the blower new, the 4 shear bolts and nuts come with it.
Edit=here is a manual.
http://manuals.deere.com/cceomview/O...dex.html?tM=HO
Markcuda is offline
post #5 of 14 Old 12-16-2010, 07:08 PM
KATT's Avatar
from the owners manual look under Part Numbers last page.
1 for auger shear bolt , 1 for nut, 1 for impeller shear, 1 for nut
Current 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
"11" X540 54" Deck
Some LX 188's and a few 100 series
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled ."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck.
Sold Rusty
KATT is offline
post #6 of 14 Old 12-16-2010, 07:56 PM
jdaws's Avatar
Go to the hardware store and get some 6mm soft bolts and lock nuts.
jdaws is offline
post #7 of 14 Old 12-17-2010, 12:06 AM
10,000 +posts!
So would those "soft" bolts be scored properly to be used as a shear bolt? Shear bolts are just that, designed and machined with a weakened spot to give way long before any solid bolt will, and it will break in a manner where it will not damage either parts of the blower/auger. Hey, it's your stuff, It's just that I believe in using the proper safety valves on my equipment.
HydroHarold is offline
post #8 of 14 Old 12-17-2010, 12:18 AM
KATT's Avatar
Wait !! Mark and I gave him the on line manual and the page # for the right bolts WHY would you use anything else IMHO ??!!
KATT is offline
post #9 of 14 Old 12-17-2010, 12:22 AM
Banned!
Replacing Shear Bolts
IMPORTANT: Avoid damage! Replacement shear bolts must be same as original shear bolts on attachment:
Softer bolts can shear too easily.
Harder bolts may not shear and attachment can be damaged.
NOTE: Four spare M6x45 auger shear bolts and M6 nuts are provided in the bag of parts.
Markcuda is offline
post #10 of 14 Old 12-17-2010, 12:28 AM
KATT's Avatar
I keep the 4 in the tool holder next to the seat so they are with me, but even on my old #49 I only replaced 1 in 25 years. ( asphalt drive but I ran into the cement steps in a 3 foot blizzard oops !!) I didn't exactly say oops, but it did had a S in it !!
KATT is offline
post #11 of 14 Old 12-17-2010, 03:03 AM Thread Starter
My dealer was kind enough to assemble the blower and install it for me .... so I didn't get any bag of parts or the manual. The "shear" bolt that was currently in there was just a threaded bolt, threaded the entire way. I'm use to the shear bolts that are scored.
Thanks for the manual and I'll have to see if I can find the spare shear bolts.
kirscp is offline
post #12 of 14 Old 12-17-2010, 07:25 AM
Banned!
That is what my 4 bolts look like.
Markcuda is offline
post #13 of 14 Old 12-17-2010, 07:25 PM
KATT's Avatar
Mine Dealer did too and gave me the Manual and bolts and anything else in the plastic bag from JD. They were there from JD in the crate !!
Same bolts as mine Mark Those are the correct ones !!
"11" X540 54" Deck
Previous JD's
Sold Rusty
KATT is offline
post #14 of 14 Old 12-17-2010, 07:29 PM
jdaws's Avatar
I took one of the original bolts that came with my blower and matched it with bolts from the hardware store. The number on the bolt head indicates the hardness. I have been useing these for the last 2 years, have sheared several and they work fine.
jdaws is offline
