AG Tires on GX345 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 01-07-2006, 01:05 PM Thread Starter
greenhobby's Avatar
Images: 7
Question AG Tires on GX345
I am about to purchase a set of Carlisle Super Lugs and wheels for my GX. I intend on putting them on when using the Johnny Bucket and tiller (someday). The tractor comes with 24x12x12 rear tires. The tire dealer wants to sell me 23x10.5x12. My question is will this be sufficient? I was smurfing the net and found a website (Haynes hitches, I think) that shows this arrangement. The lug tire appears to be a bit taller tread than the turf tires. thoughts? How does one fill them with fluid?
http://hayes-ent.com/hitch/images/JDHitchSleeveR1.jpg
thanks in advance,
-greenhobby
"When a man's mind runs faster than his tractor , they both tire quickly"
My Stuff:
2004 GX345, 48C deck, snow thrower, front mount dethatcher, tow behind 60" aerator, JD 15 cart
Johnny Bucket Jr with height extension and tooth bar
2005 Cyclone Professional Power Rake
Echo PAS-260 Power Head with attachments
Husqvarna 45 Special 16" Chainsaw
Husqvarna 165 Backpack Blower
MacKissic Chipper/Shredder 12PT
greenhobby is offline
post #2 of 13 Old 01-07-2006, 01:11 PM
ducati996's Avatar
Re: AG Tires on GX345
Look on Carlisle mfg web site for a closer size tire to what you have....looks like you are going to small compared to what you have....if the dealer dosent have it stock, plenty on-line distributors do
Duc
ducati996 is offline
post #3 of 13 Old 01-07-2006, 01:13 PM
ducati996's Avatar
post #4 of 13 Old 01-07-2006, 01:43 PM
Tvern13's Avatar
Use this link check out what's available. I think you'll have to get the AT 101 tires to get the 24". If it was me I would get the 24" rather than the 23" if that's the diameter tire that originally came on the tractor.
http://shop.cedarrapidstire.com/
Tvern13 is offline
post #5 of 13 Old 01-07-2006, 01:54 PM
Splicer's Avatar
I just bought a set of 23x10.5x12 super lugs as an exact size change-out from my turf tires. Just to let you know, the super lugs, which appear larger are in fact SHORTER (not as tall) than the turf tires of the same size.
I would advise you staying with the same size you have now if at all possible.
Splicer is offline
post #6 of 13 Old 01-08-2006, 12:44 AM Thread Starter
greenhobby's Avatar
Images: 7
All, thanks for the feedback. I checked with Carlisle, and they don't sell a 24x12x12 in the Super Lug. They only make a 23x10.5x12 and then a 26x12x12. Their website is mismarked on the 26x12x12. Does anyone else have a favorite 24x12x12 lug tire that they recommend?
-greenhobby
My Stuff:
post #7 of 13 Old 01-08-2006, 02:14 AM
Images: 3
Greenhobby: You might want to look into the 'TITAN' brand AGs...they might make a 24x12x12 tire to fit your Deere.....or maybe check with your local JD dealer, and see what they can get for you.
I know this fine looking Federal Yellow machine will hurt you Deere guys eyes....but deal with it.... ROF
I took this pic as I was swapping 23x10.5x12 AGs (same size as the turfs they were replacing) onto my 1450 Cub Cadet.
It pretty well illustrates the improvement in traction the AGs will (and do) have over the turfs.
In this pic, both AGs are on, ready to work..
Cub Cadet: Plowin' the competition under since 1961
Wild Bill 83 is offline
post #8 of 13 Old 01-08-2006, 06:32 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
I would shop around for a closer size. Every time I have replaced turfs with AG's, the AG's have been a little smaller then the turfs removed. Bulth of them I had wished I have jumped UP a size.
Check out Tucker tire. they have a store on ebay. Real nice people, and GREAT to deal with. They have mostly off brand stuff, the the price is right. If you dont see what you need, call them and ask. They have done me well, and will go out of there way to make you happy.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #9 of 13 Old 02-02-2006, 12:19 AM
DeereMan's Avatar
Greenhobby,
You were looking at my 345 in your first post of this thread. I have 26x12x12 Carlisle Super Lugs mounted on 12x10.5 wheels JD part number AM101523 on my 345. No one manufactures a true lug tire in 24x12x12 I looked. Carlisle sells a 101 Chevron tire in 24x12x12 but it is not a true lug tire. The 10.5" wide wheel flattens out the tire tread for a better ground contact patch. A couple of notes, the mower deck does NOT fit with these tires mouted and these tires required me to add a 3/4" spacer under the rear deck mounts to clear the tires.
This is my 345 w/23x10.5x12 Super Lugs mounted on 12x8.5 wheels
This is my 345 w/26x12x12 Super Lugs mounted on 12x 10.5 wheels
1996 JD 345 w/custom electric sleeve hitch
1987 JD 332 w/3 point hitch and rear PTO
1987 JD 322 w/3 point hitch
1987 JD 318 w/3 point hitch
1980 JD 212H w/factory sleeve hitch
DeereMan is offline
post #10 of 13 Old 02-02-2006, 12:31 AM
Jim_WV's Avatar
Images: 13
Deereman, sure does'nt look like you got much leeway in clearance between the tires and frame
Jim_WV is offline
post #11 of 13 Old 02-02-2006, 01:43 AM
DeereMan's Avatar
I have about 3/8" clearance but since there is no suspension travel in the rear it does not make any difference. All I have to remember is not to put my hand down and grab the fender.
DeereMan is offline
post #12 of 13 Old 02-02-2006, 10:57 AM
chrpmaster's Avatar
OUCH! Been there done that!
Stupidity is exasperating. Willful ignorance is bulletproof.
I totally take back all those times I didn't want to nap when I was
younger
I think part of a best friend's job should be to immediately clear your
computer history when you die
chrpmaster is offline
post #13 of 13 Old 10-03-2007, 08:49 PM
10,000 +posts!
Your last pic looks sooooo good. nice machine you have there..
Team_Green is offline
