John deere x304 idle problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 11-20-2010, 04:53 PM Thread Starter
My x304 idle's high then low and won't even out at low throttle.
I have installed the tune up kit oil, new air,oil and fuel filters and new spark plugs. It only has 60hrs on it.
If I push the lever to full throttle I can still hear a slightly unsteady idle.
Please Help Thanks!
Lalmeida617 is offline
post #2 of 20 Old 11-20-2010, 05:14 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Re: John deere x304 idle problem
Did it do that before you did the tune up on it?
stladrill is offline
post #3 of 20 Old 11-20-2010, 05:48 PM Thread Starter
No not that I recall.
post #4 of 20 Old 11-20-2010, 05:55 PM
stladrill's Avatar
Images: 6
Ok then
1. Make sure you install the fuel filter the right way.
2. You may have a defect spark plug.
3. Recheck all the work you done on it.
For the spark plug the easy way to determinate the defect one is to reinstall one used plug at the time.
post #5 of 20 Old 11-20-2010, 06:04 PM Thread Starter
Stladrill I will look at it tommarow at the spark plugs. When I changed the oil I was not sure if I should check the level with the oil cap locked on or just placed to the top of the dipstick tube.
post #6 of 20 Old 11-20-2010, 06:11 PM
stladrill's Avatar
Images: 6
The top of the dipstick tube (unscrew) after running the engine for few minutes.
I'm sure you will find the problem.
post #7 of 20 Old 11-20-2010, 06:17 PM Thread Starter
Could to much oil cause this?
post #8 of 20 Old 11-20-2010, 06:39 PM
stladrill's Avatar
Images: 6
How much more?????
post #9 of 20 Old 11-20-2010, 10:45 PM Thread Starter
Not even one extra line on the stick
post #10 of 20 Old 11-20-2010, 11:48 PM
stladrill's Avatar
Images: 6
No it is not what cause your problem, but I recommend to drain it a bit of oil.
post #11 of 20 Old 11-21-2010, 02:58 PM Thread Starter
Ok then
I checked the fuel filter and the arrow on it is pointing toward the carb (the fuel flow direction)
I replaced both spark plugs with the old ones.
And rechecked the oil level, it was on the money and the air cleaner and pre filter are clean.
I also checked the fuel pump vent and it doesn't seam dirty.
The tractor still idle's up and down
Could a small piece of dirt got into the carb when I changed the filter?
If so how do I get it out?
Should I pour some fuel system cleaner in the gas?
post #12 of 20 Old 11-21-2010, 05:33 PM
stladrill's Avatar
Images: 6
Did you check the gas cap vent? try to unscrew it, if your hear a vacuum noise is a sign that the vent is blocked.
post #13 of 20 Old 11-21-2010, 05:47 PM Thread Starter
I added fuel to the tractor while it was running and opening the cap did not change anything.
post #14 of 20 Old 11-21-2010, 06:00 PM
stladrill's Avatar
Images: 6
Did you still have a warranty on it?
I'm out of idea.
It's maybe a governor trouble???
post #15 of 20 Old 11-21-2010, 06:03 PM
Let us know which engine this uses and someone will come up with the procedure to clean the idle jet on the carburetor.
rscurtis is offline
