Emergency LED Strobe Lights - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 10-05-2010, 10:30 PM Thread Starter
Has anyone installed emergency LED strobe lights on their John Deere garden tractor? If so, pictures of where mounted would be welcome.
dinomax is offline
post #2 of 18 Old 10-05-2010, 10:38 PM
Danco's Avatar
Images: 15
Re: Emergency LED Strobe Lights
Check out this link.
Show your warning/beacon light
JD - 318
JD - 54" Hydraulic Angle Front Blade
Fabricated - 48" Front Scoop
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Suburban Snow Thrower
Sears Suburban Plow
Suburban Smile
Support MTF
Danco is offline
post #3 of 18 Old 10-10-2010, 03:38 PM
I built a mount for a high-speed rotating beacon (a Federal Signal Firebeam, model FB3MEF - 55 watt halogen lamp) to keep it above my head so it's visible when I'm plowing snow out in the street, especially when it's dark out. Here are several photos so y'all can see how it's done.
This is the overall view from the rear with the light flashing at the camera.
Notice the wire for the rotating beacon is fastened to the right tube and plugs into a connector in the tool box that I added.
The foam pipe insulation pieces on the vertical tubes are there to keep the seat from rubbing on the tubes when I lean back.
The vertical tubes are made from 1/2" EMT ("thinwall" electrical conduit). The tubes are connected to solid plugs at top and bottom by pins through holes in the tubes and the plugs. The plugs are welded to 3/4" angle stock. The lower angle is bolted to factory-made slots at the rear of the tractor. I used heat-shrink tubing to remove slop where the tubes go through the plastic fittings at the rear of the X500.
The upper angle bar is connected to the tubes in the same way as the bottom, but it has a plate welded on for the light to mount to (with a magnet) and I used small cotter pins for a semi-permanent connection.
This view is with the tubes disconnected and lifted to just above their mounted position so you can see the solid plugs which they connect to.
I added a new "cigarette lighter" socket in the rear of the tool box so that I didn't have to trip over the wire when plugging it in below the steering wheel. I also filed a notch into the edge of the tool box so that the wire has a place to go while the door is fully shut.
Now all I need is some snow to plow!
Skip Douglas - X500 (2006)
SkipD is online now
post #4 of 18 Old 10-10-2010, 09:14 PM
Snotrocket's Avatar
It's not a Deere but here's a video of my strobe/light setup on my Case.
http://www.youtube.com/watch?v=-G-yHf7n4Wg
Snotrocket is offline
post #5 of 18 Old 10-10-2010, 10:01 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Very nice set up.
You should post it here also. Show your warning/beacon light
stladrill is offline
post #6 of 18 Old 10-10-2010, 10:21 PM
HI54UNI's Avatar
Nice!
HI54UNI is offline
post #7 of 18 Old 10-10-2010, 11:51 PM
Danco's Avatar
Images: 15
I have a tool caddy on the rear of my tractor that conveniently holds a broom, rake, shovel or any other hand tool I might need while landscaping.
With snow getting closer each day, I started to prepare my equipment and tools for the season. While I donít plow the road, I do plow about 200 feet of driveway and keep the cul-de-sac clear. I wanted to be visible in low light and wanted something simple.
I purchased a battery operated 24 LED flashing beacon.
I mounted this to a 5í length of non-metallic PVC conduit, after I painted it black.
I used a rubber pluming coupler to secure the light to the conduit.
The unit easily slips into the tool caddy when needed. Itís high enough above the operators head to be seen without blinding the operator.
View My Video
JD - 318
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Suburban Plow
Suburban Smile
Support MTF
Danco is offline
post #8 of 18 Old 10-11-2010, 08:11 AM
Danco's Avatar
Images: 15
By The Way Ė Here are the dimensions for the beacon.
And, when I ordered the light, I selected the PVC flange base as an option.
JD - 318
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Suburban Plow
Suburban Smile
Support MTF
Danco is offline
post #9 of 18 Old 10-11-2010, 01:13 PM
MXZRXP's Avatar
wow, nice work in both cases!
that tool holder looks like a GREAT idea.
Curious, how do you prevent an inverted rake from spinning and cracking you in the head??
One of those would be a great addition for my summer needs...
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #10 of 18 Old 10-11-2010, 01:21 PM
POENY's Avatar
Good idea and a nice job putting it all together.
If you angle the blade all the way can you make it up the steps to plow the deck? It looks narrow for the 54" plow.
2007 John Deere X748 w/SEat - aka Herman
John Deere 54" Snowblower, 54" Snowblower chute rotation modification, WE - Weather Enclosure, lights, & propane heater,
54C MMM w/ Meg-Mo blades, HDAPs w/ Rim Guard, 4 Suitcase weights, Hitch w/ platform & 16 gallon sprayer, Johnny Bucket Sr
POENY is offline
post #11 of 18 Old 10-11-2010, 01:31 PM Thread Starter
Danco,
That is a very nice set up and it should work on my 325. Can I ask - where did you get the tool holder that you used as the base for your set up?
dinomax is offline
post #12 of 18 Old 10-11-2010, 07:49 PM
Danco's Avatar
Images: 15
Currently, itís fitted with a 48Ē plow converted to a scoop. You can see it better in this photo.
JD - 318
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Suburban Plow
Suburban Smile
Support MTF
Danco is offline
post #13 of 18 Old 10-11-2010, 08:00 PM
Danco's Avatar
Images: 15
Danco,
Follow this link to a previous post.
Tool Caddy: No frills - No cost
JD - 318
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Suburban Plow
Suburban Smile
Support MTF
Danco is offline
post #14 of 18 Old 10-12-2010, 12:02 AM
BobK's Avatar
Images: 9
What I had on my LT180.
It's an orange LED strobe.
It's held on magnetically.
LED's will either strobe or stay on.
$20.00 range at Lowe's. I think they are even cheaper at Harbor Freight.
Hard to tell in the pic, but it's pretty bright.
BobK is offline
post #15 of 18 Old 12-30-2010, 06:54 PM
Banned!
Thumbs up Re: Emergency LED Strobe Lights
These rear LED lights are catching on
Markcuda is offline
