44" snowblower for X320 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 09-13-2010, 11:51 AM Thread Starter
X320's Avatar
Help 44" snowblower for X320
Hi guys,
I am looking for some feedback on this. I have a X320 and looking for a snowblower for it. Hard to find in Ontario and JD dealer asks $2100 for a new blower. Now I know I could go with a Bercomac, but they are not that much less in $$$. The only used one I found was this:
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ224589212
I found no other snowblowers for my tractor that fit without modification. I am not really a metal fabricator, so I am not good enough to make something work from another older model.
Now my questions:
1. Does a blower from a current L model JD tractor fit the X320? Maybe with very little work/mods? I know the X300s and the L models are not that much different.
2. What are you guys opinions about the blower on kijiji (see link)? Is it a good price? It does not come with the lift assist spring kit (required for my tractor) and no weights (even if you can see them on some pics).
I might have the option to send a truck down to pick it up (it's too far to drive for myself - over 7 hours one way). But would anybody buy this item without personally looking at it? I wanted to try to offer maybe $1300 for it.
I am very thankful for any feedback. I have been reading through this forum for a good year before deciding to buy my X320 and I am really happy about all the information that I found. I hope at some point I can be of help for others as much as this was of help for me.
Thank you all folks!!!
X320 is offline
post #2 of 13 Old 09-13-2010, 01:30 PM
Banned!
Smile Re: 44" snowblower for X320
They list for 1500 bucks, in the states.
That is the kind I am getting this fall.
In his ad, he says it is for a 700, it will not fit the 700 series select mowers.
Markcuda is offline
post #3 of 13 Old 09-13-2010, 03:07 PM Thread Starter
X320's Avatar
Hi Markcuda,
Do you mean $1500 NEW in the states? I should go shopping in NY State then for a new one?!
Thank you!
X320 is offline
post #4 of 13 Old 09-13-2010, 07:47 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Originally Posted by X320 View Post
Hi guys,
Now my questions:
Hi, first the price for the new one is right for us Canadian (I pay that in 2009)
The blower form the "L" series will not fit on the X300/X500 series, they only share the same housing, all the pulley and bracket are different.
About the one at KIjiji it look like in very good shape, you'll have to replace the 2 small pulley we see in the picture and probably the belt too (the belt $35.00 the pulley around 20.00 each)
If I where in your position I'll take the one at Kijiji, they are very well made blower and I see some in worst condition selling for the same price.
stladrill is offline
post #5 of 13 Old 09-13-2010, 08:00 PM
KATT's Avatar
First thing I thought of, when I saw the pics was you Stladrill and those pulleys you taught us about.
Why the belt I'm not replacing mine after 1 season ??
KATT is offline
post #6 of 13 Old 09-13-2010, 08:11 PM
stladrill's Avatar
Images: 6
Because if the pulley where starting to seize (they look rusty) the belt would have take a beating that's why I say "probably"
post #7 of 13 Old 09-14-2010, 01:12 AM
Banned!
Yes, they list for $1499
I got mine for $1450, tax included, bran new, 44 inch, I think I got a ok deal.
Markcuda is offline
post #8 of 13 Old 09-14-2010, 09:19 AM Thread Starter
X320's Avatar
At Markcuda: Maybe I should move back to the states, I always have the feeling Canadians get ripped off, but I don't want to start that discussion now. thank you for your feedback.
At stladrill: I did not know that if the pulleys look rusty that could be an issue that quick. I have to check in on that. Thank you.
I asked the seller for the serial, just to be save and am now thinking if I want to go and check it out or just have our truck pick it up next time he is down there. Feels strange to pay so much money without looking at it first.
Thank you for all your feedback!
X320 is offline
post #9 of 13 Old 09-27-2010, 10:13 AM Thread Starter
X320's Avatar
First of all, I got the blower including weights and chains. I am very happy with this purchase and I am sure it will do a great job on my driveway. I cannot wait for the first snow to come
Second, (at stladrill) the pictures (and you of course) were definitely right: The two small pulleys are seized up and need replacement or at least some work and the belt is pretty worn out. I will probably change the oil in the crank case as well since I am already on it and I will get spare shear pins for sure.
I read in another post that the chute adjustment cable can seize up, but that seems to be working fine. But the turn mechanism for the chute moves rough, so I figure I need to clean and grease it.
To get this thing working I also need to get the weight bracket to fit the weights onto my tractor and I need to get the spring assist lift kit. So at least another couple hundred to spend, but still better than the price for a new one.
I let you guys know how things are going, hopefully I will not run into any problems with the installation.
Thank you all for your advise and I will post some pics once I got everything figured out!
X320 is offline
post #10 of 13 Old 09-27-2010, 12:51 PM
mhussey's Avatar
I would not grease the bottom of the chute or the outer teeth. I did this last winter thinking it would help displace the water (from melting snow) and keep the chute from freezing up. What it did was cause the sand/dirt to stick to the grease and make a mess. Best thing to do (I've found) is remove the few bolts holding the chute to the blower head and wipe down both surfaces. When you are done using the blower, leave it in the up/lifted position. This will help the water run off the blower and not puddle and freeze under the plastic chute.
2010 John Deere X540:
54" MMM,47" Blower,44" Blade,56" Front Dethatcherator,
10P cart, and 42" Lawn Sweeper
Traded: 2006 John Deere 155C: 44" Blower-48" MMM
mhussey is offline
post #11 of 13 Old 11-11-2010, 11:49 AM Thread Starter
X320's Avatar
Hi guys,
thank you for all your help and advise. I got it all to work! Had to get the connection rod and a bunch of stuff to connect the lift assist spring to the blower. It ended up being $300 in parts in total with the pulleys and for simplicity I bought all bolts, nuts and washers from JD with the specialized stuff to not have to worry and finding the right ones. In any case, I got it to work. I also had to cut down the chains, they were from an X5XX with these HDAP tires and were way to long for my tires. All in all it took less than 2 hours to get it installed plus maybe 30 mins to get the chains figured out.
In the mean time I also bought a 17P poly cart through the internet and used it big time to haul gravel and wood. Great find too and a hundred bucks cheaper than new. Overall I got all I need and everything works great.
You guys are all awesome help for me, I hope I can return the favors at some point!
X320 is offline
post #12 of 13 Old 11-11-2010, 12:09 PM
stladrill's Avatar
Images: 6
I'm glad it work out good.
post #13 of 13 Old 11-11-2010, 04:22 PM
MXZRXP's Avatar
good for you, sounds real good, where are the pics??
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
