X728 Hydraulic fluid - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 09-12-2010, 08:14 PM Thread Starter
etc02's Avatar
Images: 6
What is the proper way to check the transmission fluid? The way I read the OM, the dipstick should sit on top of the fill tube, without turning it at all, to measure the level.
Is this correct? Do I check with the trans hot or cold?
I just got it back from the dealer after having a 3PH installed, and it was at least a half court low
John Deere 2010 X728, Cat 1 3PH, Heavy Hitch, 54 inch deck with mulch kit, 47 inch snow blower
Sold: John Deere 420, 60 inch deck, 47 inch snow blower
etc02 is offline
post #2 of 11 Old 09-12-2010, 08:49 PM
Diesel Power
andyb's Avatar
Re: X728 Hydraulic fluid
Check it cold, with the dipstick on top of the tube.
Mine was low also after I has the rear PTO installed.
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
434 hours and counting
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is offline
post #3 of 11 Old 09-12-2010, 09:08 PM
Has anyone seen ChimChim?
Brett-JDX748's Avatar
On flat ground with a cold transmission, unscrew the dipstick and wipe it off. Then rest it on top of the fill tube, pull it and check the level. It's a bit difficult to see.
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline
post #4 of 11 Old 09-12-2010, 09:33 PM Thread Starter
etc02's Avatar
Images: 6
Thank you Andy and Brett
etc02 is offline
post #5 of 11 Old 09-13-2010, 05:31 AM
picframer's Avatar
Images: 7
Next to impossible to see, whipe the stick with chalk, something a service guy told me a year ago.....I use the same method as Brett and both were low a few hours after delivery, could have been they were not topped up after the PTO's were installed but in my case it effected the AWS and tore up some sod
A colllection of CUT's, excavators and GT's, just about every attachment going and a major amount of Stihl gear. We operate a Landscaping business.
Smiling every Day!!! Andy
picframer is offline
post #6 of 11 Old 09-13-2010, 06:07 AM
Mine was low as well Andy.
X748 Ultimate,
Photos
Former Fleet:
Photos
Photos
Photos
post #7 of 11 Old 09-13-2010, 09:13 AM
Have Dog - Will Travel
Jere39's Avatar
Not sure if this is a statistically significant sample, but, mine too was low from dealer on delivery. At the 50 hour drain and replace, I went to my dealer and asked for a new filter and 3 gallons and two quarts of HyGard. The parts counter guy wondered at such a large purchase of hydro and looked at his book and showed me it should only need six or seven quarts. I walked him over to the x728 on the display floor and opened the hood and showed him the capacity on the large decal under the hood. His response, "I guess I must have an old book".
Anyway, it appears my x728 was probably filled with 13 quarts on delivery rather than 13.5 quarts. It's filled right now.
And, fwiw, I agree with all the responses above on how to check it.
Good luck,
Jere39 is online now
post #8 of 11 Old 09-13-2010, 10:06 AM
POENY's Avatar
I think the capacity difference (~8 quarts vs. ~13 quarts) is from the change in frontends. My older 2007 has a shaft driven geared frontend that used gear oil. Newer (is it 2009 and later?) frontends are hydraulic drive units that share the same hydro fluid as the rearend and have a greater capacity need.
2007 John Deere X748 w/SEat - aka Herman
John Deere 54" Snowblower, 54" Snowblower chute rotation modification, WE - Weather Enclosure, lights, & propane heater,
54C MMM w/ Meg-Mo blades, HDAPs w/ Rim Guard, 4 Suitcase weights, Hitch w/ platform & 16 gallon sprayer, Johnny Bucket Sr
POENY is offline
post #9 of 11 Old 09-13-2010, 01:27 PM
Jere39's Avatar
I'm sure you are right. I found it odd that the JD dealer who knows me, and has all 30+ years of records of what I've bought and traded there, can look me up, but used an old capacities book laying on his counter to quote me an amount. My x728 is either a 2009 or 2010, I bought it last November.
Thanks
post #10 of 11 Old 09-13-2010, 02:54 PM Thread Starter
etc02's Avatar
Images: 6
Can you tell me more about wiping the dipstip with chalk. Do you put a line of chalk on the dipstick and then check the fluid level? I know the amount is minimal, but any concern with calcium carbonate (aka rock) in your hydraulic fluid??
etc02 is offline
post #11 of 11 Old 09-13-2010, 06:23 PM
Diesel Power
andyb's Avatar
After my 50 hour fluid change, I drove the tractor for several minutes after checking the fluid and the level was OK. I checked it again after mowing for over two hours and it was low. It must take a while for all of the air to work out of the system. My tractor had .4 hours on it when it was delivered, that might not be enough for the fluid level to stabilize.
3 point hitch
rear PTO
54" blade
62" deck
andyb is offline
