318 tail lights - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 33 Old 09-11-2010, 10:51 PM Thread Starter
enzminger's Avatar
318 tail lights
Anyone know where I can buy tail lights for a 318. I know John Deere can order them and evil bay has them for about $70 for the set. I haven't checked pricing from John Deere but evil bay price of $70 bucks seems a little steep to me.
enzminger is offline
post #2 of 33 Old 09-11-2010, 11:02 PM
Banned!
Smile Re: 318 tail lights
Check out this link, has to be something that you can use instead of paying 70 bucks for.
http://www.easternmarine.com/TRUCK-L...Marker-Lights/
Markcuda is offline
post #3 of 33 Old 09-11-2010, 11:04 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: 318 tail lights
enzminger, I have a second seat pan and I'm considering putting it to work and I'll be needing a set for it too. If I find a good source I'll PM you, if you find one PM me!
Current Machine JD 322
PA318Guy is offline
post #4 of 33 Old 09-11-2010, 11:10 PM Thread Starter
enzminger's Avatar
Re: 318 tail lights
Thanks. I will let you know if a find anything. I will call John Deere to see what they want just out of curiosity. I do know I will not spend $70. I will find a set of LED's if that's what original equipment will cost.
post #5 of 33 Old 09-11-2010, 11:16 PM
John Deere 316 Onan
SWIGIN's Avatar
Images: 3
Re: 318 tail lights
Please post here when you get a price from JD or when you find something aftermarket. I'm in need of some as well.
Thanks
1988 316 Onan P218 with 50'' deck
770 hours
4 way 54'' snow blade
Custom trailer lifter run off rock bar
Stainless grab handles
Custom graphics
Original UNCRACKED seat....Finally cracked in 2015
318 H2 swap with hydro cooler
Loaded tires (16 gallons)
318 tail lights
318 brake pedals
www.egiautowraps.com
SWIGIN is offline
post #6 of 33 Old 09-11-2010, 11:18 PM
The Magnificent
D-Dogg's Avatar
Re: 318 tail lights
Give JD a shot.
D-Dogg is offline
post #7 of 33 Old 09-11-2010, 11:41 PM Thread Starter
enzminger's Avatar
Re: 318 tail lights
Well, I found these in a few minutes of searching the web. They are LED's and dimensions of the light would work (according to my measuring skills).
http://www.iboats.com/LED-Oval-Boat-...view_id.164144
post #8 of 33 Old 09-11-2010, 11:49 PM
PA318Guy's Avatar
Re: 318 tail lights
Thanks! Might order a set, I don't need the 2nd pan to look that good. I'm setting it up for the cab and it'll only be on for the winter months!
PA318Guy is offline
post #9 of 33 Old 09-12-2010, 08:59 AM
Re: 318 tail lights
I may be all wet here, but, when you install LED lights to a regular 12 volts system and turn on the switch the 12 volts will blow the LED's in a flash of a second. You have to have resisters somewhere in between. Correct?
FD611V is offline
post #10 of 33 Old 09-12-2010, 09:41 AM
Banned!
If this is true, it is a new one on me.
Markcuda is offline
post #11 of 33 Old 09-12-2010, 10:28 AM Thread Starter
enzminger's Avatar
Re: 318 tail lights
I don't know. ?????
post #12 of 33 Old 09-12-2010, 10:31 AM Thread Starter
enzminger's Avatar
Re: 318 tail lights
If that is true, you would think whatever is needed would be supplied (resistors??). I know guys that have put LED's on tractors and they never said anything about it.
post #13 of 33 Old 09-12-2010, 10:36 AM
the "AWOL member"
pigsitter's Avatar
Re: 318 tail lights
As long as they are designed for a 12volt system there should be no problem at all.You can buy 12volt LED clearance lights most anywhere trailer lighting is sold
My favorite song
proud to be a member since 2005 and aggravating Ken in NJ since sometime shortly thereafter
Uh Oh! someone left the gate open, pig's gone walkabout again!!
Where is everybody?
pigsitter is offline
post #14 of 33 Old 09-12-2010, 10:36 AM
Re: 318 tail lights
I tried the LED's and they blew in a split second... Read below on why. The 12 volts system on a lawn/garden tractor probably is not setup for LED lights.
http://www.offroaders.com/tech/LED.htm
LED lights are fast becoming the light source of choice in many applications. There are good reasons for this. LED lights consume about 10th the power of a standard comparable light bulb making them much more efficient. LEDs also last much longer than standard light bulbs at approximately 100,000 hours. Recent advances have produced high light output LED lights that make them more desirable as a light source over the previous generation of LEDs that most people are used to seeing. Also LED manufacturing has produced mass quantities of LEDs at a very small cost per LED making LED much more affordable.
In the vehicle the LED (light emitting diode) is commonly used as an indicator for alerting you if a circuit is powered on. However you can't simply plug an LED into your 12 volt power supply in your vehicle and expect it to work. The common LED requires only 2 volts to work so the power supplying your LED needs to be reduced from 12 volts down to 2 volts. That is accomplished by using a resistor. Note: typical LEDs require 2V for each LED however some require 4V such as for blue and white LEDs.
In the diagram to the right, the "R" is a 470 or 560 ohm resistor, either will work for the common LED requiring 2 volts. You will need to acquire one resistor per LED. Resistors can usually be purchased in the same electronics stores as the LEDs themselves.
FD611V is offline
post #15 of 33 Old 09-12-2010, 10:40 AM
pawber's Avatar
Re: 318 tail lights
This set works with 9 - 16volts dc. I think all of the boat & truck clearance lights are for 12v dc systems.
Paul B
09 JD X300/42X deck (321 hours)
02 JD 724D snowblower
had a JD 214 - 11 years
had a Bolens QT16 - 7 years (talk about a whiney transaxle)
had 2 Bolens 1050's - 21 years & 3 years
pawber is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
