Cab Heaters - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 09-02-2010, 07:57 PM Thread Starter
enzminger's Avatar
Cab Heaters
I am wondering if anyone out there uses an electric heater for inside their cab. I have a 345 which is liquid cooled but was told it would not have enough coolant circulation for that type of heat source. So, I have been looking for some type of small electric heater for inside my cab. Would an electric heater draw too many amps? Any input or opinions would be appreciated.
enzminger is offline
post #2 of 10 Old 09-02-2010, 09:25 PM
Re: Cab Heaters
There is a lot more heat available from the engine than you'll be able to get from any electric source. A typical home space heater (1500 watts) would require 125 amps at 12 V. Where are you going to get that on a tractor? You could probably find a small coolant powered unit, but it would have to be plumbed into the engines bypass loop, not into the radiator.
rscurtis is offline
post #3 of 10 Old 09-02-2010, 09:30 PM
9K+ Poster
JDFANATIC's Avatar
Re: Cab Heaters
Have you checked out this post: Homemade cab.
Cheers
JDFANATIC
JDFANATIC is offline
post #4 of 10 Old 09-02-2010, 09:32 PM
Has anyone seen ChimChim?
Brett-JDX748's Avatar
Re: Cab Heaters
Battery powered heaters are a joke. I had a purpose made one in my 425 cab, battery hard wired, drew 60 amps, I could fart and make more heat.
I am just finishing up a coolant powered system right now, I expect it will roast me out of the cab.
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline
post #5 of 10 Old 09-02-2010, 11:28 PM Thread Starter
enzminger's Avatar
Re: Cab Heaters
Thanks for the info. I was told my 345 would not circulate coolant enough to use a heater core. Does anyone know if this is true or has anyone tried it in a similar sized tractor??
post #6 of 10 Old 09-02-2010, 11:33 PM
Re: Cab Heaters
Kawasaki VTwin? It absolutely will circulate the coolant, Deere offers heaters for tractors with Kaw twins.
X748 Ultimate,
Photos
Former Fleet:
Photos
Photos
Photos
post #7 of 10 Old 09-03-2010, 09:53 AM
Images: 3
Re: Cab Heaters
They used to sell 12V heaters for dune buggies years ago. Might want to look into that?
Would a heated seat cover do the trick? If the butts warm the rest is warm.
Victory is offline
post #8 of 10 Old 09-04-2010, 09:15 AM
Re: Cab Heaters
maybe one of these will work for you.
http://www.utvpartsandaccessories.co...ab_heaters.htm
1984 318 b43g
50 inch deck
loaded tires
deereguy58 is offline
post #9 of 10 Old 09-04-2010, 09:21 AM
Re: Cab Heaters
here is another one.
http://www.rubicon4x4.com/product_in...ducts_id=42439
1984 318 b43g
50 inch deck
loaded tires
post #10 of 10 Old 09-04-2010, 09:51 AM Thread Starter
enzminger's Avatar
Re: Cab Heaters
Thanks for the links deereguy58. I like the second link heater. I went outside to the garage and looked at the engine. I am going to have to try and figure out which coolant lines to try and tap into.
