Coolant change GX345 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 06-17-2010, 02:32 PM Thread Starter
Bill7's Avatar
I feel I should change the coolant in the 20 HP Kawasaki. I haven't changed it yet in the 2.5 years of ownership.
According to the OM, it looks like I need to drain the system from a spot not only hard to get to, but that requires taking the hood off as well (I realize this isn't the best description. I am hoping for GX345 owners to chime in as well).
Is it possible to drain from the reservoir? Or sucking the old coolant out?
Thanks.
Bill7 is offline
post #2 of 3 Old 06-17-2010, 07:57 PM
dragon7's Avatar
Images: 6
Re: Coolant change GX345
Thanks.
You just can't get at the hose on the head with the hood on. Take it off, pull the hose and take radiator cap off. It drains fast. You should flush it out before refilling it.
_____________________________
1997-JD 345 /1835 hrs
2000-JD 345 /2140 hrs
2005-JD GX345/255 hrs
42inch Snowblower
Pull behind- 25 gal. 12volt Fimco sprayer,thatcher,spreader, JD-80 cart, pull behind lawn sweeper.
dragon7 is offline
post #3 of 3 Old 06-17-2010, 08:18 PM Thread Starter
Bill7's Avatar
So once the hood is off, then it is not too hard?
Thanks!
Bill7 is offline
