deere 210? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 06-07-2010, 09:51 PM Thread Starter
Case Nut
CASE MAN's Avatar
Images: 15
deere 210?
getting free 210 can anyone tell me specs? Hp? engine type? hydro? deck size? Any tips?
Case 1845 Skidsteer
72" Grapple Bucket
1974 Case 646 FEL
Repowered with 1986 B43M-GA016
HH-34 3-Point hitch
F-27 Sleeve hitch adaptor
LT-17 Hydraulic Pto
LL-9 Holding valve
J-70-78 Tiller
1983 Case 446
J-17 Pto
J-24 Sleeve hitch
K-10 Wheel weights
N-9 Holding valve
J-54 Utility blade
K-46 Mower deck
1962 Cub Cadet Original
1984 Cub Cadet 882 Diesel
50" Mower deck
1995 John Deere F925 Diesel
60" Rear Discharge Mower Deck
CASE MAN is offline
post #2 of 5 Old 06-07-2010, 10:04 PM
AKA Moses Lawnagan
KHodges's Avatar
Images: 6
Re: deere 210?
The 200 series had the 200 (8hp, only made one year), 210 (10hp Kohler single), 212 (12 hp Kohler single), 214, (14 hp Kohler single), and the 216 (16 hp Kohler single)
They all have the same Peerless 4 speed manual transmission with variator drive, no hydrostatic tranny available (They came in the 300 series). You could get a manual, electric, or hydraulic deck lift, standard was the manual lift. The biggest deck I believe was a 46".
They are bulletproof, good basic machines, sort of a much upgraded 110/112. The same implements fit the 110/112 and 200 series.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 FEL
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
I've always had a problem with kleptomania.
When it gets really bad, I take something for it.
KHodges is offline
post #3 of 5 Old 06-08-2010, 09:08 AM Thread Starter
Case Nut
CASE MAN's Avatar
Images: 15
Re: deere 210?
Thanks. I was told it needs a carb, not sure if its missing or if it needs a rebuild. Hope its easily repairable, my 8 year old daughter would love it!
Case 1845 Skidsteer
72" Grapple Bucket
1974 Case 646 FEL
HH-34 3-Point hitch
LT-17 Hydraulic Pto
LL-9 Holding valve
J-70-78 Tiller
1983 Case 446
J-17 Pto
J-24 Sleeve hitch
K-10 Wheel weights
N-9 Holding valve
J-54 Utility blade
K-46 Mower deck
50" Mower deck
CASE MAN is offline
post #4 of 5 Old 06-08-2010, 12:06 PM
Mr. Picky
Wrangler447's Avatar
Re: deere 210?
If the 210 has a carb on it, it might be either the original Kohler carb with an adjustable high speed idle jet, or it could be a Walbro replacement with a non-adjustable jet. The Kohler is the better carb and can be identified by that top high speed adjustment screw. Both carbs have rebuild kits still available through JDparts.com, or if you find you have no carb at all you can still purchase the complete Walbro (Kohler no longer available). If you do have the Kohler carb, inspect the throttle shaft and make sure it doesn't have an over abundance of play, because it will never idle correctly at all speeds. Post your results when you get started, and we can give you some tips on how to get that Kohler purring again.
1979 John Deere 216
-46 Deck (Replacement style)
-37A Snowblower
-38 Deck with Bagger
-43 Plow Blade
-38 Dethatcher
-JD Cast Weights
-Goodyear Turfs / Goodyear Narrow Ag's / JD Chains
2 1967 John Deere RF 110's with Hydraulic Lift
-39 Deck
-30 Tiller
-42 Plow Blade
-JD Chains
-Custom Hydraulic Plow
-John Deere 80 Dump Cart
-1973 Sears Craftsman RER
-1983 Gilson YT16 *For Sale*
Wrangler447 is offline
post #5 of 5 Old 06-11-2010, 01:54 AM
Wink Re: deere 210?
You don't really want the 210! Get your daughter a nice new tractor to play with....I'll just come pick up that old klunker. Now then, what part of IL are you in?
rdartist is offline
