Hit a small stump, now engine wont start - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 05-02-2010, 05:59 PM Thread Starter
I went over a small bush stump (4" wide). The blade hit into it and the engine cut out. But now I can't even start the engine. Everything looks ok as far as I can see. Is there a safety mechanism that I can reset or something? I turn the key and get nothing at all.
Bodine is offline
post #2 of 13 Old 05-02-2010, 06:02 PM
standard issue neuralyzer
LLigetfa's Avatar
Re: Hit a small stump, now engine wont start
You don't say what model. Does it have a clutch interlock that prevents it from being started while engaged?
LLigetfa is offline
post #3 of 13 Old 05-02-2010, 06:12 PM Thread Starter
It is a GT-235. It has a button to press to engage the blades. I could see maybe the blades not engaging but why wont the engine even start?
Bodine is offline
post #4 of 13 Old 05-02-2010, 06:50 PM
Just Have a Little Faith!
It may have damaged the flywheel key which throws off the timing.
LilysDad is offline
post #5 of 13 Old 05-02-2010, 06:53 PM Thread Starter
Would that make it where I couldnt even start the engine?
Bodine is offline
post #6 of 13 Old 05-02-2010, 07:02 PM
Do you mean it won't turn over? It will make it so it fires at the wrong time. It may run badly or not run at all.
LilysDad is offline
post #7 of 13 Old 05-02-2010, 07:04 PM Thread Starter
I turn the key and nothing happens. The oil light comes on. But not a sound when I turn the key.
Bodine is offline
post #8 of 13 Old 05-02-2010, 07:09 PM
SonnyT's Avatar
Images: 26
Sounds like you have a wire that got knocked off or at least real loose someplace.
RIP Sonny T.
1954-2015
SonnyT is offline
post #9 of 13 Old 05-02-2010, 07:14 PM
deeretek's Avatar
did you remember to push in the yellow pto button after it died?If that is still pulled out it wont crank.
deeretek is offline
post #10 of 13 Old 05-02-2010, 07:56 PM Thread Starter
Tried that, no luck.
I was going slow too. Is there's a safty mechanism, like a pin or something, that breaks when the blade hits a solid object? Must not be too uncommon to hit something like that. Not sure why it would affect the engine.
Certainly the idea would be to role the tractor away from the object. But even if the blade mechanism was broke, I would think it would allow me to drive it.
It seems like there should be a reset button, like a breaker switch of some kind, that tripps to protect the cams or something, and allows you to inexpensively get it back running.
Bodine is offline
post #11 of 13 Old 05-02-2010, 08:01 PM
LLigetfa's Avatar
Again, I will ask, does it have a clutch interlock that prevents it from being started while engaged? Do you need to have it in neutral with the clutch disengaged?
LLigetfa is offline
post #12 of 13 Old 05-02-2010, 09:09 PM Thread Starter
There is a peddle that has to be pressed in order to start it. It's next to the forward and reverse pedels.
Bodine is offline
post #13 of 13 Old 05-02-2010, 09:26 PM
I had a neighbor that hit a large stump several years ago......he had to by a new short block. I'm not saying you have that much damage but it is possible.
IRDEERE is offline
