John Deere Paint - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 25 Old 04-09-2010, 09:17 AM Thread Starter
John Deere Paint
Hello all, I'm a newbie here on this forum and in the garden tractor world. I purchased a 1978 John Deere 212 that I'm in the process of redoing and using it as a lawn and garden tractor around my house to mow and push snow. I was wondering what kind of paint you guys recommend? What are your thoughts of the strength and quality of the John Deere Green paint you can get at the local dealership or do I go to the local paint shop and have them mix me John Deere Green and use a clearcoat then on it? I have all panels primed and ready to go. Thanks everyone in advance. I have to get some pictures on here soon.
212Rookie is offline
post #2 of 25 Old 04-09-2010, 09:29 AM
wally2q's Avatar
Re: John Deere Paint
depends if you want to make a show-piece, or just paint a "working machine"?....
if show-piece, go to a base / clear-coat product. If working machine, I'd use the regular enamel or whatever the standard paint is....
I use basic spray-can for all my implements... surface finish is acceptable, but highly dependent on quality of the prepped surface.... for implements I am not too picky.... but a well prepped surface can look quite-good when painted with a spray can. Mind you, that is usually steel framework (narrow, convoluted-shape pieces) etc... on a large flat surface (like a front hood), paint uniformity imperfections will be more visible.
Spray-can paint durability is quite good - as long as you give the paint 2-3 days to dry good and well.
wally2q is offline
post #3 of 25 Old 04-09-2010, 09:45 AM
mikestoy's Avatar
I don't know how fussy you are about the paint matching but even if you could use original JD paint, after 32 years there has to be some fading.
The best would be to show your local paint shop a original painted part, and let them match the green.
Mike
My 2011 X720 Tractor: "The spirit of a race horse....but the body and pulling power of Clydesdale."
2011 X720 54c" mower deck/ 47" snow thrower / 2 bag vacuum System....SWEET
Other Toys:
2012 Honda Goldwing Trike Touring Cycle ......SWEET
2009 18' Lund w/200 hp Boat
2015 Toyota Highlander
Married for 51 years.
1 adopted son, married and lives in Florida
mikestoy is offline
post #4 of 25 Old 04-09-2010, 11:43 AM Thread Starter
Well I'm not looking to show the tractor, but I want it to look good. I'm painting everything that is green on the tractor. I'm pretty happy with my prep work and I will be spraying the pieces with an HVLP (High Volume Low Pressure) spray gun. I want a really durable paint that will look good after years of use and tree branches and things possibly rubbing against the tractor. Just looking for what you guys have experience with.
post #5 of 25 Old 04-09-2010, 11:55 AM
wally2q's Avatar
HVLP is usually good for painting latex paint on dry-wall, or on wood - where you need high volume due to absorbtion...
for metals surfaces, you may end up with runs, as it will be difficult to overlap spray patterns, without putting too much paint down....
be careful.
As for what type of paint to use?... the best I know for what you are talking about is Endura. The paint remains somewhat soft - like a plastic-coating, that allows the substrate (metals or plastics) to flex, or be impacted, without causing the paint to crack or chip...
http://www.endura.ca/
but it's not cheap, and it's an epoxy paint... meaning you have to mix it, paint it, and clean out our spray-gun before it "sets"... but for this I honestly wouldn't bother... but that's just me...
wally2q is offline
post #6 of 25 Old 04-09-2010, 12:39 PM
grnspot110's Avatar
Images: 21
I'll go against the grain here! I use "off-the-shelf" John Deere Ag green, after all they're tractors not "show cars". Unless you want to spend a lot of $$$! Beware of anything but John Deere brand (or Valspar Restoration Series) as other brands don't hold up as well. ~~ grnspot110
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is offline
post #7 of 25 Old 04-09-2010, 12:50 PM
Tractor Supply will sell you the Valspar Restoration mentioned above for $44 per gal. OR you can have the Valspar Tractor & Implement paint for $29 per gal. Both are available in J.D.G. I used the T & I in A.C. Orange and was pleased with the results. I Did add the optional Valspar hardner. JMO
99flhr is offline
post #8 of 25 Old 04-09-2010, 01:57 PM
This tractor rocks
jeep63's Avatar
x2 on Tractor Supply Valspar paint. I used it for my cart paint job and it turned out great.
2009 x320
JD-esq 17 cf dump cart
jeep63 is offline
post #9 of 25 Old 04-09-2010, 05:08 PM
70chevelle's Avatar
be careful.
HVLP guns have been the industry standard in the autobody shops for years. They are more efficient with product and do a fantastic job, but need a good compressor to keep up with them as these guns are CFM hogs. If you want a durable finish the automotive acrylic urethanes are excellent, as well as the catalyzed enamels (Valspar from TSC). I find the acrylic urethanes easier to spray, but did cut my teeth spraying enamels back in the '80's. Regardless of the paint or gun you choose, the most durable paint is crap with out meticulous prep work. Good Luck!
Cub Cadet 70, 1862, and 982SGT, 442 PTO tiller, Ruegg 3 point hitch, 450 Snowblower, and 44" & 50" Decks.
John Deere 212, Tiller, Snow Thrower, Trip Blade & Wheel Weights SOLD
70chevelle is offline
post #10 of 25 Old 04-09-2010, 10:01 PM
KATT's Avatar
I just used JD rattle cans on my 318 and it looked fine the valspar rattle cans have worked for other too.
IT IS GOING TO GET SCRATCHED ( actually more scuffed from boots and attachments) it's a tractor. Don't get me wrong i still wax my JD. but she has work to do..
KATT is offline
post #11 of 25 Old 04-09-2010, 10:23 PM
John Snykus's Avatar
318 side panels are TSC restoration rattle can and trailer is TSC valspar green brush paint and rattle can yellow. Side panels are a shade lighter than rest of 318. Looks good from 20 feet.
Everyone should have some toys. Mine happen to be green.
John Snykus is offline
post #12 of 25 Old 04-10-2010, 05:52 AM
USMC
slkpk's Avatar
Images: 21
When I restored my 64 110 I used the JD enamel from the dealer. That way I can use the rattle cans for touch up when needed. Mine is a worker also but looks fantastic! The wagon in my avatar was done with rattle cans from JD. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #13 of 25 Old 04-12-2010, 01:15 PM Thread Starter
Hey, I just thought that'd I'd let you guys know that I started painting some of the smaller panels this weekend (it was way too windy out to do much painting). I went with the JD Ag Green from JD and mixed in the hardener. So far, what I did paint I'm pleased with. Thanks for all the help. Once I get it done I'll have to post some pics.
post #14 of 25 Old 04-12-2010, 01:33 PM
Likes Vintage JDs
UrbanTractor's Avatar
Originally Posted by 212Rookie View Post
...Once I get it done I'll have to post some pics.
Definitely. I think we'd all like to see those.
Good luck on the project!
UrbanTractor is offline
post #15 of 25 Old 04-14-2010, 09:54 PM
toscani's Avatar
Images: 3
hvlp is top of line gun of todays body man,it will be perfect for your job,i dont know what wally is talking about,i've been in painter for 24 years,i used john deere paint from dealer and hvlp to restore my 430,everyone thinks it has clear coat,u have to be very careful how u thin the paint,if to much,it can die back and look dull u will have to experiment,its a straight or synthetic paint so u should get the right hardener too,very important ,i just got some from the local runnings or fleet farm,its tricky itl look rough and u will think u need to hose more on but dont it will flow out,but then again ive done it for so long i could do it with my eyes closed i swear.hope this helps
toscani is offline
