JD 425 3 pt hitch capabilities - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 03-18-2010, 11:25 PM Thread Starter
Cool JD 425 3 pt hitch capabilities
I just bought a JD 425 AWS w/ a 3 pt hitch. My ?? is how much weight is realistic to put on that hitch. Can I pull a disc harrow? I dont see many category 0 discs out there. If anyone knows of a place that sells one, let me know. My deere dealer has one on the lot ( he claims was "made for this tractor) but wants almost 700$ for the disc. Ouch.
THanx.
stfiacregapp is offline
post #2 of 6 Old 03-19-2010, 01:39 AM
crawler's Avatar
Re: JD 425 3 pt hitch capabilities
brinly-hardy makes them. As for capabilities, quite a bit. My 318 lifts the front of my bolens 1250 without front weights.
'90 JD 318 - 50" deck, 54" blade, H3, 3pt
'68 Bolens 1250-02 48" deck, tiller
Bolens HT 20/23 54" deck, 54" blade
Bolens HT 23 - loader in work, 60" deck
crawler is offline
post #3 of 6 Old 03-19-2010, 09:12 AM
Tech Exchange Moderator
Sergeant's Avatar
Weight limit for lifting 450Lbs. Save your self some money and Buy a (A) frame 3point to sleeve Hitch adapter which is $99.00 avaliable directly from Brinly-Hardy Then you can use sleeve hitch implements on your 425. Cat 0 equipment has always been expensive That is why I was so happy when Deere came out with the LImited Cat 1 3point hitches Because the Cat 1 implements cost alot less than the cat 0 implements because there are so many Implement manufacturers who make cat 1 implements for tractors 25hp and under.
John Deere Models:X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is online now
post #4 of 6 Old 03-19-2010, 12:40 PM Thread Starter
Cool Re: JD 425 3 pt hitch capabilities
I'll have to look into the adapter idea- I kind of like it. I checked w/ Brinly about the cat 0 3 pt harrow, plow and cultivator on their website and they indicated they haven't made them for a couple years except for direct sales to Deere. Maybe I'll find something used..... Craigslist here I come
post #5 of 6 Old 03-19-2010, 12:45 PM
jwill1776's Avatar
I bought a JD 425 last fall, recently installed a Ruegg 3 pt (combo CAT 0 / CAT1). Defiantly keep an eye on Craigslist.
In the last two weeks I bought a Brinly spring tooth cultivator and a 12 plow just like the ones they make for Deere, $80 each. Lightly used, slight rust.
Jeff
John Deere 425 54 Deck
Ruegg Cat 0 / Cat 1 Combo 3-Point Hitch
Brinly Cultivator
Brinly 12" Single Bottom Plow
Brinly 60" Rear Blade
jwill1776 is offline
post #6 of 6 Old 03-19-2010, 12:46 PM
coldone's Avatar
Images: 3
Some Cat 1 implements will just need the pins changed over to Cat 0 pins. TSC has a disk that will fit with the pins changed.
coldone is offline
