'15 X738 Lift Arms- Need Help - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 05-17-2017, 09:45 PM Thread Starter
Reaching-out to the community for help here.
I need my lift arms to raise my deck a little higher and drop it a little lower.
Is there an adjustment to allow me to do this?
When my deck is raised all the way up, the deck stops are over an inch away from touching the frame. Makes it a little difficult loading it on my trailer.
When I lower my deck to remove it, it won't go down enough to lay flat on the garage floor even after releasing the front bracket. It's still held-up a little off the ground by the rear bracket.
It's under warranty and I brought it to the dealer. They replaced the lift arms but didn't level the deck correctly so when I cut grass at a 4 1/2" tractor setting, it was cutting grass at 3" to 3 1/2" height! When I leveled the deck per the plastic tool, now the deck won't come off w/o wrestling with it.
Please help. If I could make the arms drop the deck another 1", I think it would work as it should.
'88 Yanmar 187D, loader, shuttle-shift, turfs (what a great little tractor)
'13 Kubota B3200, loader, R4's (talk about a perfect fit)
'15 John Deere X738, 25.5hp Kawasaki, 4X4, 54" auto-connect mower, 47" JD snowblower w/quick hitch, JD snowplow, LP41114 all-weather cab, 42 lb rear suitcase weights, JD front plastic fenders, JD seat cover (nice all-around riding lawnmower)
'17 SCAG Turf Tiger II, 61", 26hp Kohler (Mowing Animal! Almost Perfection!)
MTPockets is offline
post #2 of 14 Old 05-18-2017, 02:00 AM
AOW162435's Avatar
Re: '15 X738 Lift Arms- Need Help
Amazing that the dealer would chose to replace those robust lift arms instead of diagnosing the issue and resolving it.
Andreas
2003 John Deere x595
54c deck / 54 Quick Hitch blade / hydraulic MCS / CTC loader / Warn XT30 winch / joystick conversion / QHDL
AOW162435 is online now
post #3 of 14 Old 05-18-2017, 03:32 AM Thread Starter
You guys are my last resort. Please help anyone?
post #4 of 14 Old 05-18-2017, 05:58 AM
10,000 +posts!
mrbeef's Avatar
There is only so much travel in the hangers. Make sure nothing is binding somewhere. To get more lift, tighten up the hangers all the way which will also require the front draft arms to be tightened up to relieve the deck.
Tractors:
'08 JD 1445
'07 JD X748
'99 JD 3215A Fairway Mower
'88 JD 318 "The Golden Child"
'83 JD 214
'74 JD 140
'57 JD 820
The Round Fenders: '67 JD 112H, '67 JD 112H, '67 JD 110H "The Frog", '66 JD 110, '66 JD 110H, '65 JD 110
Former Machines:
60's Power King, '64 JD 110, '65 JD 110, '65 JD 110, '66 JD 60, '66 JD 110, '66 JD 110, '66 JD 110H, '67 JD 112, '67 JD 112, '69 JD 112, '69 JD 140H3, '72 140 H1, '77 JD 212, '79 JD 212, '80 JD 317, '80 JD 317, '80 JD 317, '83 JD 318, '84 420, '86 JD 318, '86 JD 420, '87 JD 430, '87 JD 318, '88 JD 318, '88 JD 318, '88 JD 855, '89 JD 318, '91 JD 430, uk Cab Cadet 2140, '92 JD 320, '93 JD 320, '96 JD 445, and '01 LX277
Kohler Light Plant
mrbeef is online now
post #5 of 14 Old 05-18-2017, 08:29 PM
motorcycle cowboy
rooster shooter's Avatar
The deck stops on my x750 are about 1/4 of an inch from touching the frame when the deck is all the way up. You'll probably have to adjust the deck adjustment bolts to get the deck where you want it.
2013 x750 w/auto connect, rear PTO, 3 pt. hitch, brush guard, 4 suitcase weights, rear HDAP's, 54'" HC deck, mulch kit, Power Flow with MC 519, boom pole lift, JD Model 35A Tiller, 10P cart, round point shovel, mattock, axe and a swing sickle
Scag Liberty Z handles mowing duty
rooster shooter is offline
post #6 of 14 Old 05-18-2017, 09:58 PM Thread Starter
The kit to level my deck is in the glovebox. It includes a t-wrench and a black plastic round piece.
Left-Right-Front level procedure sliding the plastic piece under the rear left, then rear right, then the notch upfront.
Raising the deck higher or lower defeats the use of the plastic measuring tool and the leveling process.
I can't get the deck to lay flat on the garage floor so I can back off of it so why would I adjust the deck even higher?
I can't go lower because setting the deck at 3" I would be mowing at 2". What's the sence in the leveling procedure at that point?
post #7 of 14 Old 05-19-2017, 06:49 AM
motorcycle cowboy
The numbers on my dial do not correspond in inches either. As I was told by my dealer, either rightly or wrongly, it's just a guide. Not sure why the deck on yours will not go all the way to the floor. The plastic guide that came with your mower is useless. My experience using that piece was frustrating, I couldn't get my hand under the deck to use it at the recommended setting. Deere also sells this gauge.
post #8 of 14 Old 05-19-2017, 07:13 AM Thread Starter
I'm thinking the problem is in the dial-height knob?
There must one more notch to lower it one more notch?
Does that dial height adjuster get installed at the Dealer or factory installed?
post #9 of 14 Old 05-19-2017, 07:37 AM
motorcycle cowboy
I'm sure that part is installed at the factory. The knob is connected to a cam under the floor/fender panel. Attached is a photo of what happened to mine. As you can see, it's pretty buggered up. It was replaced under warranty. If you can get the deck off, see what kinda shape yours in in. I really have empathy for you as I have been less that pleased with my x750.
post #10 of 14 Old 05-19-2017, 03:07 PM
have a 758 that I think has the same adjustments . I sent the cut height knob at three inches lower the deck place a small wood 1x4 4 inches long on end under the blade(to the side) and mark the bottom of the 1x4 at the blade at the cutting edge . Now you know how far off the height gage is to high or to low . Raise or lower the deck with the adjusters both sides one turn each at a time until it is three inches the same as your height knob . The height knob should turn lower way past the numbers to lower the deck to the floor . If the deck still does not raise to the stops you will need to make a choice use the numbers on the cut height knob or have the deck not raise that high .
FARMER KEITH is offline
post #11 of 14 Old 05-20-2017, 06:32 AM Thread Starter
If the numbers are not correct on the height twist nob, then John Deere shouldn't have numbers on it!
My Exmark numbers are spot-on accurate. 3" cuts at 3".
It really makes no sense to me to set the dial cut height to 3" and then be cutting your grass at 2". That's something I'd expect from a Chinese built junk product that sells for 1/2 the price of a Deere.
Thank you for the picture Rooster. I'm going to take a look under there today or tomorrow. I wonder if I could grind that wheel at the lowest setting to make the notch deeper allowing the deck to lower more?
post #12 of 14 Old 05-20-2017, 10:38 AM
Sorry but you just do not understand how the knob and adjusting bolts work . The dealer will not let the shop take the time to do it right . It would take a good hour to fix . My x-758 has a 60 inch deck and after adjusting it if the knob is on 2 it cuts at 2 inches if it is on 3 it cuts 3 inches . Do as you like it is your mower .
post #13 of 14 Old 05-24-2017, 09:32 PM Thread Starter
Quick update:
I tried placing a 2X4 under my deck then lowering it. Didn't work because when I tried to back off the deck, the gearbox strikes the bottom of the frame.
Btw, tire pressures front are 8, rear 10.
post #14 of 14 Old 05-27-2017, 07:19 AM
motorcycle cowboy
Quick update:
Hope you are able to resolve your problem. As I said earlier, I have been less than pleased with the performance of my x750. I've never been happy with the quality of cut with this thing. My solution was to purchase a zero turn. John Deere was never in that equation.
