455 + box blade/scraper -- dealer says don't do it? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 04-20-2017, 11:24 AM Thread Starter
Dave88LX's Avatar
Deere 455 w/ Ruegg Cat 1 limited hitch
I have some work in my yard where I think a box blade would be the answer. I've been calling around local dealers and farm equipment suppliers looking to see what 48" options are available.
One gentleman said that he's owned a 455 before and that I might be setting myself up for disappointment. I thought people here had used them fine though, but now I am second-guessing what I thought I've seen.
The Frontier BB5048L is in the $750 range. Waiting for callbacks on the other options (Worksaver), and to look at other ones available.
Another dealer told me I would be disappointed too -- that I should use a tiller or pulverizer, and a bucket loader. :/
1999 Deere 455 | Ruegg Cat 1 3-point | Rear PTO Kit | 15 Cart | 47 Snowthrower | Super-Duty Heavy Hitch
Dave88LX is offline
post #2 of 22 Old 04-20-2017, 11:33 AM
Deere 332's Avatar
Re: 455 + box blade/scraper -- dealer says don't do it?
You will be more than fine the worst thing you could do is spin the tires due to lack of traction which shouldn't be a problem if ballast it properly. I would recommend a set or two of wheel weights or maybe liquid ballast in the rear tires or a combination of both. These tractors can handle that size box blade easily they where designed to do this kind of work.
Current Collection
1987 John Deere 165 Hydro with snow plow, 38" mowing deck and AG tires Restored
1991 John Deere 332 Redland hill 3pt hitch, Carlisle Tru Power AG tires, and V61s, 30 Hydraulic Tiller, Restored
1975 John Deere 212 Electric Lift, Sleeve Hitch, 33 Tiller, Restored
1987 John Deere 160 38" Mowing Deck aka "The Bush Hog"
1988 John Deere 318 aka "Old Smokey"
1957 Farmall 130 Fast Hitch 2 Bottom Plow, 1 Gang Disc, 2 Gang Disc, Sprayer,
Deere 332 is offline
post #3 of 22 Old 04-20-2017, 11:46 AM
MTF mile high club member
Diesel Powered's Avatar
What type of yard work are you wanting to do and what type of soil do you have?
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is offline
post #4 of 22 Old 04-20-2017, 12:03 PM
Key questions! My 455 will pull a 4 footer to move loose dirt/gravel/etc. But with the rippers down it will not
effectively dig into heavy sodded or clay areas.
OTOH, I have a little 36" Gannon, originally sold by Sears with the weird 'almost 3 pt'. I modded it for use on a
Cat 0 hitch. With it rolled into ripping position, and with multiple passes, I can loosen most anything. I really wish that was a 42 or 48" version but they are hard to find.
One other observation: tires and weight can make a HUGE difference. I now have 27x12-12 ATV tires on the 455. With 70 lbs of weights on the wheels, it works really well. With the original turfs, it was almost useless as a dirt mover.
antiqueetc is offline
post #5 of 22 Old 04-20-2017, 12:45 PM
rcguyfarms's Avatar
If u have a tractor supply or a farm type store nearby. They carry 4ft boxes designed for the limited cat 1. Also it could be cheaper then the frontier box. I bought mine a king kutter xb 4ft box blade on sale for $200 but normall listed for over $400. I use on Deere 400 with cat 0 hitch just fine.
2011 Z645
1979 400 w/ 20 loader
1979 35 tiller
1965 110 round fender
rcguyfarms is online now
post #6 of 22 Old 04-20-2017, 12:46 PM
Deere 332's Avatar
How did you get that quick hitch to work on your Cat 0 3pt?
Current Collection
post #7 of 22 Old 04-20-2017, 12:47 PM
Profound Ag's Avatar
I don't have a box blade but I do have a 5ft 3pt blade for the 445. Handles it wonderfully. I do not have loaded tires and did not add wheel weights and only running turfs. I use the blade to grade the gravel drive in the spring, spread new loads of gravel, and some light dirt work. I have bigger equipment if I really need to tear things up haha.
There is no substitute for hard work- Thomas Edison
Profound Ag is offline
post #8 of 22 Old 04-20-2017, 12:55 PM
rcguyfarms's Avatar
Its a harbor freight cat 1 quick hitch that narrowed up 6" out of the width. I moved the top link down to front of the hitch
2011 Z645
1979 35 tiller
post #9 of 22 Old 04-20-2017, 01:08 PM
Deere 332's Avatar
Oh ok I thought it looked narrower.
Current Collection
post #10 of 22 Old 04-20-2017, 01:51 PM Thread Starter
Dave88LX's Avatar
That's a good question, I probably should have addressed. It's "normal" soil. Not compacted, not sandy.
There is a pointless hump/swale that is perpendicular to a drainage area I'm looking to knock the hump into the hole.
I was thinking of using my ripper/subsoiler to break up the ground and the box blade to drag it over.
I'll get a picture when I get home.
Dave88LX is offline
post #11 of 22 Old 04-20-2017, 03:50 PM Thread Starter
Dave88LX's Avatar
Not sure if the pic helps, the hump running down the middle there. Want to blend that whole area straight across as it goes down the hill into that pit area behind it. Pending Township approval. The hump and valley serve no purpose, since the water all runs to the same area, and the yard is completely unusable with the massive hump/valley there.
Dave88LX is offline
post #12 of 22 Old 04-20-2017, 03:55 PM
Deere 332's Avatar
It may do it but you'll have to do something about the grass I'm not sure if it will pull all of the scarifies through the grass or not you might could just use a few of the scarifiers and not pull with all of them. Also did you notice what the dog is doing in the background!
Current Collection
post #13 of 22 Old 04-20-2017, 03:56 PM Thread Starter
Dave88LX's Avatar
Dave88LX is offline
post #14 of 22 Old 04-20-2017, 04:19 PM
AndrewOliver's Avatar
Not sure what kind of tree that is, but if the roots are near the surface, they'll stop you dead in your tracks. If you hit one, you could try and cut it with an axe, wrap a chain around it, and pull it out of the ground. I think other than that, you should be able to get it done no problem. I can drag my heavy hitch ripper up to the hilt through my rocky clay hardpan without too much issue. It'll pull up some pretty big rocks, but I have all kinds of ballast. The front blade for a 445 is 54 inches, and can be locked out for dirt work, and I've used mine to good effect, so I don't see why a 4' box would be so bad. The loader bucket is also 4' and designed for dirt work, so I think you're safe.
Herd of Deeres:
445 with 54" & 60" decks, 54 Power Flow, 47 snow blower, 54 blade, Curtis hard cab, weights, chains, loaded turfs, v61 fronts.
445 with 40 FEL, cat. 0 3pt, rear pto, 4ft bush hog, heavy hitch, loaded Tru Powers, v61 fronts.
140 H3 with 48 deck, 54 front blade, 54C grader blade, loaded Firestone 23 deg. rear ags, loaded tri-rib fronts
140 H3 Spruce Blue Custom Color with Haban Sickle-Mow. Restorations in progress.
265 with 48" deck, Power Flow with JRCO cart, 30 mech tiller.
AndrewOliver is offline
post #15 of 22 Old 04-20-2017, 04:19 PM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
Looks like that swale prevents the water from creating little 'rivlets' or hillside erosion down the hill when it rains.. If it were me I'd knock the high hill side down a bit but still leave some of the swale intact to prevent the direct flow of all the water.. Changing your property's landscape can have devastating results if not done correctly..
My neighbor didn't like the way the land was laid out when he moved in and did his own 'solution'... The next spring water was coming through his foundation and into his basement.. Then the real work began! He put a lot of work into it and now everything works & works better.. But it was after A LOT of time and effort!
Just my 2¢...
Can You see the Real me?
WNYTractorTinkerer is online now
