Experience with Firestone Turf/Pulling Tires? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 04-20-2017, 09:04 AM Thread Starter
Red Plaid is Timeless
grandpajay's Avatar
I'm looking at options for replacing the aging 26-12-12 turf tires on my 400 with loader. I'm not sure I want to go all the way to HDAP. I noticed these Firestone Turf tires advertised as pulling tires and have an interesting tread pattern. Anybody have any experience with these? Jay
Name:	firestone pulling tire.png
1981 JD 400 K582. 60 deck, SSQA 50 snowblower, suspension seat, left side brakes, 2 pedal foot control, H5 with separate deck lift and 3PH. Home made 3PH, mini SSQA loader, landplane, 10 weight capacity hitch, stacking starter weights, fender extensions, LED lighting.
grandpajay is offline
post #2 of 11 Old 04-20-2017, 06:35 PM
15,000+ Posts & Climbing
Re: Experience with Firestone Turf/Pulling Tires?
I've been happy with the Carlisle Multi Trac CS turfs and a set of 2-link chains for my loader MF1655 for 22 years of service. The same tires on my SCUT TLB don't wear chains, but I do have a set available.
Sixty percent of the hours on the clocks of both tractors is at subfreezing temperatures. Those Firestones don't have the sipes necessary for best traction on hard packed snow. They may be good on dirt, though.
TUDOR is online now
post #3 of 11 Old 04-20-2017, 06:38 PM
TJR345's Avatar
Images: 8
You maybe the first.I like the wider spacing.
2002 X595 with 62" deck and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow in the making
98 345 with 54" deck and powerflow
30" tiller,JD 18 cart, Front and rear thatcher
JD 40" spike aerator, Agifab 3 gang (9') aerator
42" JD Thrower,70 lb wheel weights,6 suit case weights
48" roller,JD T105 trimmer
15 gal. tow sprayer,175lb tow spreader
(2) JD JS63C walk-behind mowers
TJR345 is offline
post #4 of 11 Old 04-20-2017, 08:51 PM
AndrewOliver's Avatar
Pulling tires are sold "uncut", and the buyer is expected to cut the tread the way he/she thinks will work best on whatever surface they usually pull on. I'm not sure how those would be left uncut. Looks sort of like a turf tire with taller tread. I would think HDAP or Ags would be better in dirt, but ags would get tough on the lawn with a tractor as heavy as yours, and HDAP are usually 2 ply, so they aren't all that stable for loader work.
If you buy them, make sure you report how they work. I've never seen a set in person.
Herd of Deeres:
445 with 54" & 60" decks, 54 Power Flow, 47 snow blower, 54 blade, Curtis hard cab, weights, chains, loaded turfs, v61 fronts.
445 with 40 FEL, cat. 0 3pt, rear pto, 4ft bush hog, heavy hitch, loaded Tru Powers, v61 fronts.
140 H3 with 48 deck, 54 front blade, 54C grader blade, loaded Firestone 23 deg. rear ags, loaded tri-rib fronts
140 H3 Spruce Blue Custom Color with Haban Sickle-Mow. Restorations in progress.
265 with 48" deck, Power Flow with JRCO cart, 30 mech tiller.
AndrewOliver is offline
post #5 of 11 Old 04-20-2017, 09:12 PM
Profound Ag's Avatar
Dad had a craftsman with what looks to me those exact tires. My opinion is that they are worthless, BUT part of the worthlessness may have been the craftsman haha. That thing had a tough time driving on slick grass (dew in the mornings) and on grassy inclines even when dry. The rubber just seemed to be way to hard of compound.
There is no substitute for hard work- Thomas Edison
Profound Ag is offline
post #6 of 11 Old 04-20-2017, 10:38 PM
I don't care for the turf tires on my 455. I am changing over to a set of bar tires soon. Anyone know where the best pricing is on bar tires?
STEINERZTR200 is offline
post #7 of 11 Old 04-21-2017, 03:21 AM
The big part of the problem is lack of weight coupled with high flotation tires.
Aggressive tires reduce the problem with fewer points of contact with the ground. That doesn't really cure the problem, but it does make it something that can be lived with.
Optional methods of reducing the problem are narrower tires and more weight. LT's from 50 years ago did not have the same problems with slippage, but they usually had narrower tires and weighed several dozen pounds more than the current crop.
A 375 lb NFL tackle is not going to have the same traction problems with his LT as his 105 lb daughter.
TUDOR is online now
post #8 of 11 Old 04-21-2017, 08:35 AM
royalton10's Avatar
Miller Tire is an advertiser on this site m. e. MILLER tire I bought my V61 for the x720 here. Great service and fast shippping. They are in NW Ohio.
Some use Summit Racing https://www.summitracing.com/ Summit has a warehouse in Akron, OH (I think). I believe they can ship from several locations or you go to the store.
Good luck!
2009 x720 62" Deck 214 hours and brand new deck (surprise birthday present from my wife)
2005 GX 335 54" Deck
48" blade with Thompson 4" stroke 1200# actuator
2003 Scag Tiger Cub 48"
10' tilt trailer
Actuator video
https://www.youtube.com/watch?v=tzf3qXQ075o
Wiring harness video:
https://www.youtube.com/watch?v=e--k39BszDo
royalton10 is offline
post #9 of 11 Old 04-21-2017, 11:01 AM
I understand what your saying but Dad isn't exactly little. He's probably pushing 285 ish
post #10 of 11 Old 04-21-2017, 03:05 PM
All things are relative. The load per inch of tread width on my GT can exceed 100 lb, depending on ballast configuration, and I can spin the chained rear wheels at my discretion on compacted earth, and dig a pair of 12" wide holes in the process.
Your dad's Craftsman has a load of about 30 lb per inch of tread width with him in the seat and no chains on the tires.
That's another option, install 2-link tire chains. Cheaper than a new set of tires that may or may not work better than the turfs.
TUDOR is online now
post #11 of 11 Old 04-21-2017, 04:47 PM
Eh, he sold it to a guy who lives in town and bought a Deere a year or so ago. He's much happier now haha.
