GX At Work - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 03-17-2017, 09:05 PM Thread Starter
GX At Work
A few years back I rented a 6000 lb mini excavator and dug up some huge stumps. I put them in the back corner of my lot and waited for nature to do it's thing. Recently I have been able to break off some of the good sized roots and take them down to the burn pile. Today I decided to see if I could get the rest moved. I did have to make 2 cuts on the biggest stump which didn't do my chain any good. Had to resharpen 1/2 way through.
I have done a couple of threads on the "boom pole" or "wrecker boom" which uses an Invacare Hoyer Patient lift upright and cylinder section. It's incredibly handy. A couple of the stump sections were still wet and too heavy to carry so I just hooked a rope to them and started dragging. The GX didn't even groan. No problem at all.
rayjay is offline
post #2 of 8 Old 03-18-2017, 06:24 AM
Re: GX At Work
Nice!
I'm curious...Did you have to make any special provisions or brackets to run just the upper hood and grill? I have an upper hood and grill for my 345 but I'm just too cheap to buy a lower. Your "half plastic" setup looks much better then my "no plastic" look.
Thanks
IbeinNC is offline
post #3 of 8 Old 03-18-2017, 07:38 AM Thread Starter
Re: GX At Work
I call it the Hot Rod Hood. I have done 2 of these. On the second I did use 1" angle alum and I think that is the way to go. The 3/4" just doesn't have enough area left where it has holes drilled in it. Even so the original Hot Rod Hood is still doing just fine. I like to over engineer everything
Hot Rod Hood Mk1
rayjay is offline
post #4 of 8 Old 03-18-2017, 08:26 AM
Ericjr16's Avatar
Re: GX At Work
Awesome Rayjay! It sure did work a treat! I have that same lift, I should look up your thread on it, could use it more if mobile in bad weather like now. The tiny wheels make it hard to move with bad back.
Challenge Met
John Deere 180 with two bin bagger
1971 Bolens 1256 snow caster
1996 Craftsman GT6000 snow blower
1980 Wheel Horse C-85
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is offline
post #5 of 8 Old 03-18-2017, 08:33 AM Thread Starter
Re: GX At Work
Eric, the thing is a life saver if you have physical issues.
John Deere Wrecker Boom
rayjay is offline
post #6 of 8 Old 03-18-2017, 08:48 AM
Ericjr16's Avatar
Re: GX At Work
I now do my friend! The lift could really help me if used more often. Need to make it more mobile as it moves too hard for me right now.
Now I wonder if I could rig it up to the three point hitch of my Sears Suburban?
Challenge Met
Ericjr16 is offline
post #7 of 8 Old 03-18-2017, 08:23 PM
Re: GX At Work
Thanks for the tip on the hood. Installed my upper today. Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1489882976.658700.jpg
Now I need to fix the crack that runs down the middle...
IbeinNC is offline
post #8 of 8 Old 03-18-2017, 08:35 PM
Ericjr16's Avatar
Re: GX At Work
Remembered I could mount it to my WheelHorse as well. Got a couple options now. The lift is buried in over 2' of snow after storm. Got time to plan it out I guess!
Thanks for reminder rayjay! Very happy you did it, makes my back happy just thinking of the help!
Challenge Met
Ericjr16 is offline
