45 loader conversion project - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 138 Old 03-16-2017, 08:45 PM Thread Starter
OK, I happened to stumble on a really nice used 45 loader and I picked it up. Issue is I have an X738. I looked at this very carefully and I'm going to rework the mounting system to accommodate the 45! First off the loader is in really nice condition. Only thing that may be an issue are some leaks from the seals on 2 rams but I'm not sure if it's just from sitting. Quick test on the tractor and I didn't get sprayed
I looked carefully at the frame and I noticed something with the holes. There are two holes that seem to be on the exact angle that the bar should be on and the holes are spaced exactly as the bar bracket. I have to check a bunch of things out. Just quick observations.
If they are on the correct angle this will make things much easier to align.
My initial plan is to have 2 3/8" steel plates made. One for each side of the frame just to double it up and then cut the existing mounting tube and weld it to the outer frame and then bolt it all together as a sandwich for extra strength. I've studied the CTC mount and it looks really weak. I'll also add some triangle gussets to the tube.
I'll post some pics when I get more done.
ID:	1924473   Click image for larger version
ID:	1924481   Click image for larger version
YardBch is offline
post #2 of 138 Old 03-16-2017, 08:55 PM
badgerland01's Avatar
Re: 45 loader conversion project
Subscribed
X749 "H-3 EDITION"
GX345
badgerland01 is offline
post #3 of 138 Old 03-16-2017, 09:29 PM
TJR345's Avatar
Images: 8
I would look to see if the bar would fit through the frame by cutting the frame of the tractor like the old ones mount.I would think just mounting to the frame would put a lot of stress on the tractor frame.
2002 X595 with 62" deck and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow in the making
98 345 with 54" deck and powerflow
30" tiller,JD 18 cart, Front and rear thatcher
JD 40" spike aerator, Agifab 3 gang (9') aerator
42" JD Thrower,70 lb wheel weights,6 suit case weights
48" roller,JD T105 trimmer
15 gal. tow sprayer,175lb tow spreader
(2) JD JS63C walk-behind mowers
TJR345 is offline
post #4 of 138 Old 03-17-2017, 07:59 AM
AOW162435's Avatar
Agree. You would need to get the hole placement (for the square tube to pass through) dead on.
Not sure what you mean about the CTC mounting - my CTC loader uses a very stout square tube that goes through the frame. Just like the JD version.
BTW, if you decide not to adapt the loader to your tractor, let me know. My neighbor was quite interested in that listing for his x595.
Andreas
2003 John Deere x595
54c deck / 54 Quick Hitch blade / hydraulic MCS / CTC loader / Warn XT30 winch / joystick conversion / QHDL
AOW162435 is offline
post #5 of 138 Old 03-17-2017, 08:11 AM Thread Starter
Cutting the frame is out of the question for me. I couldn't see destroying the frame for a loader. Plus, there are hard hydraulic lines that run directly in the way of where the tube would go. The CTC mount I was talking about is the adapter for the newer X series. It's just a stub tube bolted to the frame but it seems like it's very far forward of the bolts to me but I don't have one in hand so maybe it's not so bad
YardBch is offline
post #6 of 138 Old 03-17-2017, 08:42 AM Thread Starter
FYI, Here's a pic of the CTC mount
ID:	1924681   Click image for larger version
YardBch is offline
post #7 of 138 Old 03-17-2017, 11:23 AM
mikgran's Avatar
Just out of curiosity, is the tractor under warranty? Hate to see you run into issues down the road and have JD say you voided it when you modified the frame.
Aside from that, I'm looking forward to your loader project.
2004 X485- 54 deck, 47 blower, Buford Bucket
2001 345
1977 210
1970 110H
1976 Bolens H14
mikgran is offline
post #8 of 138 Old 03-20-2017, 06:56 PM Thread Starter
Ok, worked on some templates this weekend and got everything looking and fitting good. should have some steel pics and a fit-up test by the weekend. When I'm done it will look stock and be in same position as it was meant to be. I decided to build new support tubes instead of cutting the old one. Simple thing to copy and it allows me to have the original mount in case I ever sell it. Here's a pic of one of the templates..
YardBch is offline
post #9 of 138 Old 03-20-2017, 08:00 PM
X748SE's Avatar
YardBch,
Looks great!
Can't wait to see how your brackets turn out.
Roger
Current Machine: 2012 X748SE "H7" Edition, 60" 7-Iron Deck, 45 Loader, 54" Blower, Curtis Hard Cab
Former Machines: JD 140 H3, JD 345,
Ford 1710, Ferguson 2085
YouTube Channel: --> X748SE
Build Threads: Hard Cab & 45 Loader, H5 Conversion, 45 Loader to JDQA, 45 Loader JDQA Forks
X748SE is offline
post #10 of 138 Old 03-22-2017, 05:36 AM
Red Cap Club
nick4030's Avatar
Subscribed!
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is offline
post #11 of 138 Old 03-23-2017, 01:20 PM
motorcycle cowboy
rooster shooter's Avatar
I must be getting old as the subject of this thread really excites me.
2013 x750 w/auto connect, rear PTO, 3 pt. hitch, brush guard, 4 suitcase weights, rear HDAP's, 54'" HC deck, mulch kit, Power Flow with MC 519, boom pole lift, JD Model 35A Tiller, 10P cart, round point shovel, mattock, axe and a swing sickle
rooster shooter is offline
post #12 of 138 Old 03-23-2017, 01:51 PM
whx595's Avatar
Hi - the 45 loader support beam thru the frame takes a lot of the abuse of loader operation. I have a #45 on my x595. Do you have the cross-braces that span the bottom channel of the frame? I think the x-braces keep the frame from flexing. The old #40 FEL mount bolted to the side - similar to your case , but for added strength - the bar curved back under the foot boards and bolted to the frame via the bolts that hold the rear axle giving you a second support point. ( 40 loader see a pic). Maybe if you ran a channel back to the rear it would support the mount and take some of the twist of the contact area on the frame. Just a thought? Great project. it's a great loader!!
[/SIGPIC][/SIGPIC]
John deere x595
No 45 FEL
6 ft snow plow & cab
R4 tire upgrade
6 ft. Backhoe
whx595 is offline
post #13 of 138 Old 03-23-2017, 05:40 PM Thread Starter
I hopefully will have an update soon but the steel was just picked up so I didn't have time to do any assembly just yet.
Just a few notes to clarify:
There will be no modifications to the tractor. This is strictly a bolt on.
I have 4 steel plates. 2 outer plates that the loader mount is welded onto and 2 inner plates as doublers to make a steel sandwich of the frame.
I feel this will make for a much stronger mount than having the possibility of a bolt pulling through the frame even though I don't think that would happen.
The forces I see on the mounting bar would mostly be up and down not forward or back since it can't move that way due to the front frame mount. I would think mostly pulling up from weight on the bucket.
I have 4 grade 8 flange head bolts to hold this on and one of the bolts will be threaded into a welded block inside the tube. Should be super strong.
The frame has a welded "X" on the bottom and I believe a bracket on top creating a box structure.
Pics soon!
YardBch is offline
post #14 of 138 Old 03-24-2017, 06:55 AM
whx595's Avatar
Hi - most "planned" stresses will be vertical from loads in the bucket. Damage is usually caused by un-expected events. I was nearly thrown off the seat when I was moving large snow banks back and the tooth bar on the bucket snagged the asphalt curb!!!! It actually spun the tractor to the side! Machine was ok -curb has a big chunk out of it! LOL.
Looks like you have addressed the potential issues. Yes progress pics are a must! good luck! As an aside - if you plan to do any digging -a bolt-on tooth bar works great. If you find the need for on - look for one that has a steel frame with actual excavator style replaceable teeth. I found a fabricator in Mass. who built one for me. The tooth "caps" are hardened. I've had mine for years, digging and moving stone/gravel (smashing into curbs) and there is minimal or no wear? good luck!
[/SIGPIC][/SIGPIC]
John deere x595
No 45 FEL
R4 tire upgrade
6 ft. Backhoe
whx595 is offline
post #15 of 138 Old 03-24-2017, 12:04 PM
gt275's Avatar
whx595,
I just want to know how you got that 6 ft backhoe to work on your tractor? Looks like a nice addition.
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 w/124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
Deere 10P poly Cart
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is offline
