Deere 26 broom for X749 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 39 Old 03-15-2017, 09:29 PM Thread Starter
badgerland01's Avatar
I am considering purchasing a used Model#26 broom for my X749. This appears to be meant for the 4200-4400 scut tractors, but the PO says it works perfectly on his x748. Does anyone have any feedback, positive or negative, regarding the 26 broom. It appears to be a 60" wide broom.
X749 "H-3 EDITION"
GX345
badgerland01 is online now
post #2 of 39 Old 03-15-2017, 10:53 PM
MTF mile high club member
Diesel Powered's Avatar
Re: Deere 26 broom for X749
Did somebody put the correct X series adapter plate and pto shaft on it or is it just some backwoods engineering to make it fit? Pics?
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is offline
post #3 of 39 Old 03-15-2017, 11:14 PM Thread Starter
Not sure DP. Here are the crummy pics he has posted. What do you make of them? It sure looks like a heavy duty broom.
ID:	1923969   Click image for larger version
X749 "H-3 EDITION"
GX345
post #4 of 39 Old 03-15-2017, 11:19 PM
Just based on those bad pics, it looks like somebody used the proper parts to put it on an X. It looks like a nice unit, has the bonus deflector, and should work just fine on your X.
2011 JD X748
2004 JD 4410 TLB
post #5 of 39 Old 03-15-2017, 11:27 PM Thread Starter
Thanks a bunch DP. Now I just need your help convincing my wife it's a "necessary" purchase. Haha
X749 "H-3 EDITION"
GX345
post #6 of 39 Old 03-16-2017, 01:09 AM
I have a loader fetish
nick4030's Avatar
It doesn't look all that different that the 60hd
Sent from my SM-G920V using Tapatalk
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is offline
post #7 of 39 Old 03-16-2017, 01:10 AM
nick4030's Avatar
BTW, that deflector is like a 400 dollar option
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
post #8 of 39 Old 03-16-2017, 08:23 AM
martincom's Avatar
I have a 51 Broom. To be honest, I don't utilize it very often. I have a fairly large area concrete driveway, so the broom can only move the snow so far and it starts back dropping behind the broom. So I'm typically limited to less than an inch of the fluffy snow. You have to be careful coming up to a snow bank with it, as if you get into it at all, you'll snap a sheer bolt on at lest one section.
It is kind of a hassle pulling the snow thrower off and putting the broom on or vice-versa. The worst part is unbolting the chute deflector cable from the snow thrower, although.
I have one of those Stihl chest pack leaf blowers that I typically utilize when we have less than an inch of the fluffy snow. It gets the drive and sidewalks whistle clean---provided I get to them before someone drives over the snow. I utilize it far more for blowing snow than leaves.
Driven over snow is probably where the broom shines, as it will cut through freshly packed snow fairly well.
I obtained my broom at a bargain price, though I did have to drive 3 hours each way. Even at the bargain price, if I had to do it over again, I wouldn't purchase it.
2001 455 AWS, with Rear PTO & Halogen Headlight Kit
1999 455 AWS, with Rear PTO, Rear Hydraulic Outlets & Halogen Headlight Kit
3*60" Mower Decks, one with mulch kit, one with powerflo
MC519 Cart
2*46 Snow Throwers
54" Blade w/Superior Scoop Kit
647 Tiller
Quick Hitch Grappler
51" Rotary Broom
2*JD (Femco) Hard Side Cabs
2017 1025R TLB
54 Mower deck
47 Snow blower
Cozy Cab
martincom is online now
post #9 of 39 Old 03-16-2017, 11:12 AM Thread Starter
My main reason for wanting to purchase the broom is for flood cleanup. I am building a cabin in a flood plain. The cabin is lifted 8' off the ground and there is a 2000 sq ft concrete floor under it and also side walks, driveway, and patio. It is likely this will flood 1 per year bringing in unwanted sediment. I'm thinking a broom might be the best way to deal with this. I have a gx345 for snow blowing so the x749 could wear the broom in the winter. Sometimes use the loader/snow pusher, but the new neighbor complains about the location of the snow piles left behind.
X749 "H-3 EDITION"
GX345
post #10 of 39 Old 03-16-2017, 11:28 AM
nick4030's Avatar
The broom would do great at that. I had a 51 broom and although I never used it, when it was sitting next to the 60hd, it was easy to see which one would do a better job. The larger diameter bristles makes all the difference from what I understand. Diesel powered can verify that, he seems to be the resident broom man. The one your looking at also has the larger bristles
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
post #11 of 39 Old 03-16-2017, 12:05 PM Thread Starter
Thanks for the feedback Nick. I know next to nothing about brooms, so I appreciate any advice.
X749 "H-3 EDITION"
GX345
post #12 of 39 Old 03-16-2017, 12:08 PM
nick4030's Avatar
To show you what they'll do...
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
post #13 of 39 Old 03-16-2017, 12:09 PM
nick4030's Avatar
Notice how wet and muddy that broken up area is. It pulled it all right out! I was wishing I had the deflector that day...
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
post #14 of 39 Old 03-16-2017, 12:50 PM Thread Starter
I like it!!! Do you use weight on the rear?
X749 "H-3 EDITION"
GX345
post #15 of 39 Old 03-16-2017, 12:52 PM
nick4030's Avatar
I have, but it doesn't seem to need it really. Tires are loaded in that pic
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
