425 home-built attachments? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 01-21-2010, 12:10 PM Thread Starter
Hello!
As my first post, I probably ought to introduce myself and my equipment. This fall we moved from our "starter" home to a place with a 2 acre lawn area. Being a tight-fisted person, I set out to find a tractor to mow and perform other duties, such as snow removal and a few other things. I'm also one of those "buy it once and buy it right" kind of guys, so I wound up with a used John Deere 425 with around 825 hours on it. It has some rust here and there, and I plan to restore it over the winter here.
I am fairly handy with restoration and fabrication; my primary hobby is probably motorcycling. I always do my own maintenance and have built and restored several motorcycles over the last few years. I have my own equipment and can cut, weld, do bodywork and paint. So, finding a mechanically excellent 425 AWS that needed restoration was exactly what I was looking for. I knew the reputation of the 425 (and it appears this one still has the plastic cam gear), so I knew I was getting a quality machine with great capabilities.
My question is about attachments. I saw at least one thread about a guy building his own loader- I PM'd him asking for details, since a loader would be great for snow removal. Being a fabricator I am interested in knowing what other attachments have been home-built, and if anyone has plans and/or pictures/measurements they'd be willing to share.
Also if anyone has good detail pictures of your model 40 loader, I'd love to see some detail pictures of the mounts and connections.
Thanks all- this looks like a great place!
CLAY is offline
post #2 of 13 Old 01-21-2010, 03:03 PM
bvp2000's Avatar
Re: 425 home-built attachments?
Hi Clay and welcome to the forum! The link below may answer a few questions on the loader for a 425. Sorry, can't help on any other attactments.
JD 425 requirements for 40 loader
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline
post #3 of 13 Old 01-21-2010, 03:08 PM
Jim_WV's Avatar
Images: 13
Clay, nice to have you aboard here with us .
Jim_WV is offline
post #4 of 13 Old 01-21-2010, 03:13 PM
5000 posts and climbing
m.jodrey's Avatar
Clay,glad to have you aboard.
Maynard
1963 Bolens 800,1972 Bolens 1256, 1972 Bolens 1886, 1973 Bolens H16, 1978 Massey 1655, 1961 Cub Cadet Original, 1979 Cadet 85, 1980 Cub Cadet 482, 1963 Gravely L, 1993 Ford 6640 4X4,2008 Kubota 2110 diesel,1970 Bolens 1053,2002 John Deere JE63S self propelled lawn mower
m.jodrey is offline
post #5 of 13 Old 01-21-2010, 03:37 PM
Altiman94's Avatar
Clay,
Welcome to the forum. The 425 for sure is a quality machine. The only issue you may have with a loader is the AWS. Most prefer a non-AWS machine for loaders. However, the Or-Bilt loader system would probably work for you and it's a quick attach. That's probably the loader I will put on my 318 this summer.
Post some pictures!
1987 John Deere 318
50" Deck
54" 4-way Snow Blade
Cat-0 Ruegg 3 PT
Rebuilt Onan and Fresh Paint
Altiman94 is offline
post #6 of 13 Old 01-21-2010, 03:56 PM
HookMan's Avatar
Good point on the AWS part...the 40 loader isn't designed for that unit. But as a fabricator, I'm sure you could make something work.
1995 JD 455, 40 Loader, mc519 cart
HookMan is offline
post #7 of 13 Old 01-21-2010, 06:52 PM
USMC
slkpk's Avatar
Images: 21
and enjoy the forum. If the 425 had regular oil changes and air filter kept clean you you get past 700 hours chances are it will last a good long time. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #8 of 13 Old 01-21-2010, 07:49 PM
Tech Exchange Moderator
Sergeant's Avatar
Kwik-way made a Loader for The JD 425 thru 455 All Wheel steer models as well as a Backhoe that will fit the 425 thru 455 All wheel steer models. http://www.kwmanufacturing.com/prod_load.htm
John Deere Models: 1025R TLB,X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is online now
post #9 of 13 Old 01-21-2010, 08:01 PM
The Magnificent
D-Dogg's Avatar
Welcome to the forum!
D-Dogg is offline
post #10 of 13 Old 01-21-2010, 08:49 PM
midnitetr8n's Avatar
Clay,
and your 425 is definitely a great machine.
Theo
Live Green or Die.
2008 JD-X500
JD 10P Cart, JD Integral Hitch, 40" Brinly Rear Blade, JBJR, 10" Brinly Moldboard Plow, 42" Brinly Lawn Sweeper, Brinly Cultivator, 1 Ton Winch
1984 & 1988 JD420
(Long Term Projects)
1988 JD332
1985 & 1988 JD318
3ph, #15 JD 3pt Moldboard Plow, 1 Ton Winch, Brinly 3pt Four Gang Disc Harrow, Brinly 3pt Cultivator w/ Hiller Discs, JD 54" 4 way Blade, 3pt Carry All, 4'-6' Telescoping Boom Pole, MCS
1972 & 1973 JD140 H3
Sleeve hitch, JD 54" 2 way Blade
1967 RF 112H
midnitetr8n is offline
post #11 of 13 Old 01-22-2010, 08:30 AM Thread Starter
Thanks for the welcome all- I'm excited to get to it! I have a couple motorcycle projects to get out of the way first, then I'll dig in to the 425 whole-hog. Here are some pictures:
You can see the rust on the fenders that will require some refinishing, but it's one of those "jobs" I look forward to and enjoy. I also have a new seat and an extra set of rear tires/rims. I'm figuring one set will be filled with chloride and weighted for winter/loader duties and one set will be just regular for mowing. Thanks for the welcome!
CLAY is offline
post #12 of 13 Old 01-22-2010, 08:35 AM
I color outside the lines
rrmccabe's Avatar
All in all I think it looks pretty good.Thats a heck of a machine.
I am not so sure you need two sets of rims. I run weight year round.
Looks like the rust damage started from someone having a cab installed?
1967 Original 110 Round Fender with model 80 cart
2010 2305 with 200cx loader
rrmccabe is offline
post #13 of 13 Old 01-22-2010, 12:02 PM Thread Starter
Yup- I bought it from a guy who was going to restore it, then found a better deal machine. He bought it from the original owner. It had a cab and a blower- the fuel pump went out so it sat for a few years till he bought it and fixed it up to running condition. The 60" deck is from a different 425 he had, so it's in pretty good condition (no bad noises and not much rust at all). I'm excited to start work on it and begin building some attachments.
The AWS is crazy- when you turn it feels like the back is sliding out- well, I guess in a way it is!
CLAY is offline
