front PTO shaft for x758 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 02-14-2017, 09:24 PM Thread Starter
Question front PTO shaft for x758
I have a 455 that I use a rotary broom and snow blower. I don't think the 455's PTO will work on the x758. Is there such a thing as a PTO shaft extension?
Thanks.
iowguy is offline
post #2 of 15 Old 02-14-2017, 10:03 PM
Re: front PTO shaft for x758
if the outer part of the shaft is on the broom.. u may get a longer inner part that will fit the X758..
Whirly is offline
post #3 of 15 Old 02-15-2017, 08:49 AM
Are you referring to this shaft or mid pto shaft? May depend on which quick hitch you are using. 455 hitch or x7 hitch. Are you using the broom and snowblower from the 455 on the x758? Noticed parts catalog also specs 2wd and 4wd up to serial 040000.
47" Snowblower Driveshaft Issue
JD x749, Curtis Hard Cab, 3pt, rear PTO, 62 deck, quick hitch, 54" blade.
JD 455 3pt, rear pto, Ruegg drawbar, QH, 47 2S blower 54 deck
JD 425 54 deck
JD 425 for parts, fire, 3pt, rear pto
JD 425, seized, 54 deck, 450 tiller, 3pt, rear pto
JD 332, 3pt, pto tiller, QH, 47 2S blower
JD 316, 46 deck
Cockshutt 1465 Fiat Diesel 77HP, Loader, 60" bucket,
Howard 6' Rotovator Tiller
84" Avco 2 stage 3pt blower
JD 1610 Chisel plow
3 pt flail mower
King Kutter One Row Cultivator
pipsqueek is offline
post #4 of 15 Old 02-15-2017, 10:47 AM Thread Starter
My mistake, it is the approximately 5' long pto shaft that runs from under the seat to just below the grill on a 455. Would that be the mid-pto?
The quick hitch fits a 455.
iowguy is offline
post #5 of 15 Old 02-15-2017, 11:04 AM
The 4x4 uses a completely different front shaft.
110Driver is offline
post #6 of 15 Old 02-15-2017, 11:31 AM
Yes mid pto. 455 mid pto won't work on a x758.
x758 is a 4x4? Parts catalog show 2wd and 4wd up to serial 040000. Also 4x4 mid pto has 2 versions, before 040000 serial and after 040000.
JD 425 54 deck
JD 316, 46 deck
JD 1610 Chisel plow
3 pt flail mower
post #7 of 15 Old 02-15-2017, 01:33 PM Thread Starter
Is there somewhere online I can go to look for parts numbers? I'd like to buy a used mid-pto if possible.
iowguy is offline
post #8 of 15 Old 02-15-2017, 02:51 PM
ggsteve's Avatar
JD Parts should have the numbers, and I think Mutton Power had a useful chart explaining what goes with what.
You can look on ebay, but those driveshafts are a tough find, and when you do you might find it would be cheaper to smelt one out of gold. That is why I grabbed my model 47 blower with the right drive shafts for my x748 when I found it. The blower was ridden hard and put away wet but I had to do it. That deal is still the only match I've found to my machine in a year of looking.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #9 of 15 Old 02-15-2017, 03:00 PM
Used John Deere 47" & 54" Snow Blower Buying Guide
JD 425 54 deck
JD 316, 46 deck
JD 1610 Chisel plow
3 pt flail mower
post #10 of 15 Old 02-15-2017, 05:36 PM Thread Starter
I wonder why the mutton site doesn't have a mid-pto column.
iowguy is offline
post #11 of 15 Old 02-15-2017, 06:04 PM
X748SE's Avatar
iowguy,
It would very hard to find a used mid to front PTO shaft for a 4WD/AWD as the pass-through shaft which goes through the front axle usually will stay with the machine once it is installed. The original plugs/seals (M810730) that need to be taken out in order to install the pass-through shaft are usually misplaced or discarded.
The current John Deere part number for the Front PTO kit for your X758 is BM25305 and is called a Universal Driveshaft.
Roger
File Type: pdf John Deere - X758 Universal Driveshaft.pdf (97.4 KB, 34 views)
X748SE is offline
post #12 of 15 Old 02-16-2017, 09:27 AM Thread Starter
Originally Posted by X748SE View Post
iowguy,
Roger
How involved is it to take off and put on the shaft?
iowguy is offline
post #13 of 15 Old 02-16-2017, 07:08 PM
X748SE's Avatar
iowguy,
Once the pass-through shaft is installed in your front axle (which you don't remove) the mid PTO shaft is very easy to install.
1) Align the splines and slide the front part of the mid PTO shaft onto the pass-through shaft.
2) Pull back on the rear locking ring and slide the rear part of the mid PTO shaft onto mid PTO shaft that is on the rear transaxle.
3) Release rear locking ring.
It should take less than 30 seconds to install this shaft.
Roger
X748SE is offline
post #14 of 15 Old 02-17-2017, 01:29 PM Thread Starter
I guess it's safe to assume that the pass through shaft is much more difficult to install.
What tools do I need to install that?
iowguy is offline
post #15 of 15 Old 02-17-2017, 01:50 PM
VT JD's Avatar
iowguy,
Here is a link that may be helpful.
X749 Mid to front pto kit install with photos
VT JD is offline
