Refurb: JD-400 with backhoe/front loader - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 225 Old 02-03-2017, 09:13 PM Thread Starter
ToasterTan's Avatar
Starting this thread after buying a 1980 JD-400 with both backhoe and front loader. Near as I can tell, this is the Holy Grail of attachment combo for this tractor. My intent is refurbish the rig to solid operational and cosmetic condition. Not a restoration, but bring it back to a really nice tractor without spending a stupid amount of money.
I was originally looking for a front loader which might fit my JD-318, which has a blade, mow deck and rototiller. I needed a Garden Tractor which was more Tractor than Garden. I stumbled across the 400, which was perfect for my needs. I had no knowledge of the attachments or how rare they were until posting this forum and asking if the price was reasonable. The seller is second owner and had it for 25 years. The asking was $4,900 and I purchased it for $4,200. Everything is functional with no alarming repairs or modifications except for the the 54" front blade, which he also gave me. It had been sitting outside unused and the cylinders/hoses are toast. It came with a new in the box, larger capacity, hydraulic pump to replace the undersized original. Also new plug wires, a rebuild kit for the glitchy steering control valve and original, 1979, Repair/Service manual.
The tractor is in good/fair condition for a rig often sitting outside for years. It looks a bit rough, but found no rusted out areas or severe weather damage. All the components, connections, operating linkages and running gear is in repairable condition. I only replaced the ignition switch, which failed while buying it. The motor runs amazingly well, starts right up with no funny noises. The starter Bendix hangs up occasionally, but a nudge gets it engaged. Tires are shot, but hold air.
The most obvious starting place is the hydraulic hoses. Most are original and rotted with the wire shield exposed in abrasion areas. Fittings are corroded, but only two are weeping a bit. All but one of the hydraulic cylinders are tight, which is on one of the stabilizing arms. Much to my delight, the next door neighbor has a hose crimping machine, which he will teach me how to use. The last couple days was spent identifying the required hose spec and fittings.
Hoses are 1/4" SAE 100R2-04AT (two wire shields) with appropriate fittings. Rating is 5,800 operating psi with a 4" bend radius.
I measured the hoses and logged the type fitting on each end. Preliminary pricing estimates are around $350-$400 for materials to replace every hose on the tractor!!
The next step is to drain the system and remove all hoses for use as a template, marking each for the new installation. Then the Backhoe will be disassembled in place, starting with the bucket, so the pivots and joints can be refurbished. The last piece being the attachment and control assembly. Some Zerk fittings are missing and nails used as cotter pins. Then painted and reinstalled in pieces.
ID:	1892305   Click image for larger version
ID:	1892313   Click image for larger version
ID:	1892321   Click image for larger version
ID:	1892337   Click image for larger version
ID:	1892345   Click image for larger version
ToasterTan is offline
post #2 of 225 Old 02-03-2017, 09:24 PM Thread Starter
ToasterTan's Avatar
Re: Refurb: JD-400 with backhoe/front loader
A few other things I forgot. The missing engine side cover and grill also came with it. The only modification is the oversized front loader cylinders, which had to have extended brackets to mount them. You can see the upper ones in the photo showing red cylinders on the bucket arm. They are made well and appear professional. Below are photos of the new hydraulic pump, along with the hoses and controls.
ID:	1892401   Click image for larger version
ID:	1892409   Click image for larger version
ID:	1892417   Click image for larger version
ID:	1892433   Click image for larger version
ID:	1892449   Click image for larger version
post #3 of 225 Old 02-03-2017, 09:38 PM
Rebuilding my First JD GT
N2 Tractors's Avatar
Other than the price that is awesome.
1979 John Deere 317 Kohler KT17QS II " Not Running "
1979 John Deere 317 Onan P218G
1990 John Deere 316
33 Tiller + 8" Extension
38" Brass Tag Mower
19xx Wheel Horse D250 / Arc FEL
N2 Tractors is offline
post #4 of 225 Old 02-03-2017, 09:53 PM
Deere 332's Avatar
Can't wait one of my favorite attachment combos!
Current Collection
1987 John Deere 165 Hydro with snow plow, 38" mowing deck and AG tires Restored
1991 John Deere 332 Redland hill 3pt hitch, Carlisle Tru Power AG tires, and V61s, 30 Hydraulic Tiller, Restored
1975 John Deere 212 Electric Lift, Sleeve Hitch, 33 Tiller, Restored
1987 John Deere 160 38" Mowing Deck aka "The Bush Hog"
1988 John Deere 318 aka "Old Smokey"
1957 Farmall 130 Fast Hitch 2 Bottom Plow, 1 Gang Disc, 2 Gang Disc, Sprayer,
Deere 332 is offline
post #5 of 225 Old 02-03-2017, 10:06 PM
Minding my P's & Q's
JP Savage's Avatar
Nice machine!
Wish I had it sitting at my place. You a lucky man.
Sent from my DELL WS650 Desktop PC, by tappity tap tap'n on the keyboard. And which not even once have I dropped down the hole in the outhouse.
Utility before aesthetics.
JP Savage is offline
post #6 of 225 Old 02-03-2017, 10:16 PM Thread Starter
ToasterTan's Avatar
The ONLY 400 tractor I found nationwide with a backhoe just had a blade on the front. I looked at ads over a wide geographic area around me for a LOT of other brands and none had both attachments with a price anywhere near this. Figure I'll spend $1,000 - $1,500 to bring it to great condition. I have a good shop, airless spray rig, large media blast booth, MIG welder, tire changer, steel bender, tube bender and other tools for this.
Can you show me where another one is? What can you show me for comparative pricing of a 400 with backhoe, front loader and front blade? I've had 3 offers in the last two weeks of over $3,000 for the backhoe, as-is.
I need it to dig up a septic tank with possible repair to the drain field. Also going to make drainage channels for runoff to a small holding pond. Clearing about 1/4 acre, moving some dirt to fill low areas and create landscaping. Regrade and expand a driveway, including new crushed rock. A contractor wanted $2,500 to dig up the septic, not counting any repairs. Landscaper wanted between $8-10,000 for the other work. It's $1,200/week to rent the equipment. With both JD-318 and 400 I can do everything myself - at my own pace.
The math works great when you consider resale price and money saved. That's not even considering the fun factor! http://www.mytractorforum.com/images..._face_grin.png
Name:	JD backhoe ad.png
ID:	1892521   Click image for larger version
ID:	1892545   Click image for larger version
post #7 of 225 Old 02-03-2017, 10:22 PM
Deere 332's Avatar
You're tractor makes me even more pi$$ed at myself for not buying the 400 my friend that had the loader and backhoe like yours for $2,000 and the even funnier thing is he would be making a $1,000 that is my lowest low in my John Deere garden tractor collecting carrier the even worse thing is I knew he wanted to sell it I even knew the price for a whole 6 years and then one night I was thinking about buying it next morning I found out that he sold it the day I was thinking about it.
Current Collection
post #8 of 225 Old 02-03-2017, 11:13 PM
TT don't get me wrong you got a good deal. I'm just a cheap skate LOL...
1990 John Deere 316
38" Brass Tag Mower
post #9 of 225 Old 02-03-2017, 11:58 PM
I have a loader fetish
nick4030's Avatar
I still want that....
Sent from my SM-G920V using Tapatalk
2015 John Deere 1025R
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is offline
post #10 of 225 Old 02-03-2017, 11:59 PM
Deere 332's Avatar
You still can't have it Nick it's mine!
Current Collection
post #11 of 225 Old 02-04-2017, 07:08 AM
15,000+ Posts & Climbing
The maximum pressure rating for anything that is likely to be installed for that hydraulic system will be 3500 psi. The system will not see pressures that high. At 2000 psi, the loader will lift about 1200 lb at the ends of the arms or about 900 lb of payload in the bucket. A 900 lb payload will load the front tires to about 2500 lb.
You don't need 5800 psi 2 wire hose. A set of 4100 psi single wire hoses, with terminations to match, will be more than adequate and a bit easier on the pocket book.
TUDOR is online now
post #12 of 225 Old 02-04-2017, 08:57 AM
AOW162435's Avatar
Very cool setup. Looking forward to seeing the clean up.
Andreas
2003 John Deere x595
54c deck / 54 Quick Hitch blade / hydraulic MCS / CTC loader / Warn XT30 winch / joystick conversion / QHDL
AOW162435 is offline
post #13 of 225 Old 02-04-2017, 09:36 AM
Love the x738
Paul Y.'s Avatar
Love the 400. Looking forward to watching this "rehab". I've looked, they're never for sale with the goodies in any condition. Great find.
Love the x738
Paul Y. is offline
post #14 of 225 Old 02-04-2017, 09:38 AM
1K poster
donbowman14's Avatar
you passed on a 400 with loader and backhoe for $2K......I think you need to get your head checked Deere332 and don't give me any of this "I'm a teenager stuff"
Keepers
2001 John Deere 445
Cat 0/1 3pt. hitch
60" Mower Deck
42" Hydraulic Tiller
48" NorTrac Box Scraper
40 Gallon 3pt. Sprayer
1987 John Deere 430
Cat 0/1 3pt. hitch
60" Mower Deck
1978 John Deere 316
Johnson 12 FEL
(ongoing project, http://www.mytractorforum.com/12-joh...ct-begins.html
1970 John Deere 140 H3
Cat 0 3pt. hitch
41" Mower Deck
Gone, but missed
2003 John Deere GT235
1983 John Deere 420
donbowman14 is offline
post #15 of 225 Old 02-04-2017, 09:43 AM
1K poster
yes $4200 is a lot of money, but separate, those items are way more than that and that's if, if you can even find them. I would have found the money too, some way some how for that combo. I'm always looking for backhoes and never finding any. Loaders are rare enough, but backhoes, they just didn't make that many I guess, or the owners are holding on. I'll be eagerly awaiting your posts on this threat with every ounce of jealousy I have
Keepers
2001 John Deere 445
Cat 0/1 3pt. hitch
60" Mower Deck
1987 John Deere 430
Cat 0/1 3pt. hitch
60" Mower Deck
1978 John Deere 316
Johnson 12 FEL
Cat 0 3pt. hitch
41" Mower Deck
Gone, but missed
1983 John Deere 420
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
scottybilt, rcguyfarms
