JD 316 (w onan) p218G - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 01-10-2010, 05:12 PM Thread Starter
Help JD 316 (w onan) p218G
has anyone swapped a 2 spool hydraulic valve body and handles off from a 318 to a 316? it this possible without troubles? also the dual breaks. i think i can get a good deal on the set. also what model rototiller fits on this tractor? do I need the rear pto gearbox? thanks.
blkdge996 is offline
post #2 of 16 Old 01-10-2010, 06:12 PM
ryankrizan's Avatar
Re: JD 316 (w onan) p218G
As I recently found out, no you don't need a rear PTO, you can get a hydraulic tiller for your tractor.
1992 JD 318 23hp Vanguard v-twin
ryankrizan is offline
post #3 of 16 Old 01-10-2010, 07:10 PM Thread Starter
thanks do you have any info on it?
post #4 of 16 Old 01-10-2010, 10:44 PM
The Magnificent
D-Dogg's Avatar
It's a 30 inch tiller which mounts with a set of plates under your hitch plate, and onto your rockshaft. You can mount the pump under the tractor to run off the front PTO or on the rear if you have the rear PTO. I believe there was an extension available for it to make it a 42".
There is a gentleman who makes a 3PH adapter to make mounting and unmounting easier.
D-Dogg is offline
post #5 of 16 Old 01-10-2010, 11:25 PM Thread Starter
really....... How do i talk to that gentleman? these tillers seem hard to find? do any of the 200 series use this tiller? thankyou
Adam
78 JD 316 (Kohler)
mower deck,snowblower
84 JD 316 (Onan)
mower deck ,smowbloer, AG tires
91 polaris trailboss two stroke
post #6 of 16 Old 01-11-2010, 02:10 AM
Tech Exchange Moderator
Sergeant's Avatar
No none of the 200 series use the Hydraulic tiller.
John Deere Models: 1025R TLB,X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is online now
post #7 of 16 Old 01-11-2010, 03:09 AM
ryankrizan's Avatar
http://seattle.craigslist.org/skc/grd/1535880957.html
Not sure if it's correct, but according to that post, he says it will fit some of the 200 series.
Here's the ad:
this is the hard to find in good working order jd hydraulic tiller that fits the legendery 318 lawn and garden tractor it was just serviced new hydraulic oil, oil filter bearing and bushing tills like a dream get ready for spring now this will also fit john deer 316 onan 322 330 332 420 430 and also the 208 210 212 214 and 216 give me a call 206-498-2269
post #8 of 16 Old 01-11-2010, 09:19 AM
Heres the 30" hydraulic tiller with a 12" extension on it. The brackets for the tractor are shown in the last picture. The top part is a rod to stabilize the pump, the 2 triangular castings mount on the rockshaft and the bottom 2 mount on the rear axles. No rear pto and no 3 pt hitch required. Really nice attachment!
Chadsden is offline
post #9 of 16 Old 01-11-2010, 01:04 PM Thread Starter
Those tillers look great. I'd like to get my hands on one some
how. how dose it raise and lower?
Adam
78 JD 316 (Kohler)
84 JD 316 (Onan)
post #10 of 16 Old 01-11-2010, 01:16 PM
The Magnificent
D-Dogg's Avatar
Via the rockshaft.
I could not find the post of the 3PH tiller adapter, but it was on weekendfreedomachines.com
My neighbor has this tiller, and told me it is about a 20-30 minute one man job.
D-Dogg is offline
post #11 of 16 Old 01-11-2010, 01:53 PM
ryankrizan's Avatar
Originally Posted by D-Dogg View Post
Via the rockshaft.
Do all 318s have rockshafts on them? Was it an option?
post #12 of 16 Old 01-11-2010, 02:33 PM
The Magnificent
D-Dogg's Avatar
Yes, a rockshaft is standard on the 318.
If you get a hydraulic tiller, you want to print the IPL from the John Deere part site and make sure you get all the mounting hardware.
D-Dogg is offline
post #13 of 16 Old 01-11-2010, 03:06 PM
Sergeant's Avatar
The above tiller will fit al the tractors listed as far as the 316 onan, thru 430 will run off either front or Rear PTO's on the 300 series and Rear PTO only on 420 and 430. But looking at that one above I think it only set up right now to work off the 316onan thru 332 front PTO. The 200 series he is listing have a diffrent PTO setup where this tiller would not work not to metion the weight of the tiller when it has Hydraulic fluid in it.
White Model: GT2055
post #14 of 16 Old 01-12-2010, 01:49 PM
sts25straight's Avatar
Images: 17
There is an adapter kit for the 200 series tractors.
John
sts25straight is offline
post #15 of 16 Old 04-05-2010, 11:35 AM
hi, new here i just got a 42" hydraulic tiller that came off a 445. i want to mount it on my 318. my problem is i need a pump bracket AM100388 i can't get one. can you give the specs on the bracket so i can make one. how do i add a picture.
specie is offline
