Getting gas and spark, still not starting - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 12-29-2009, 08:13 AM Thread Starter
Hi, my JD LX172 is getting gas and a spark but still will not start. A new spark plug, new gas, and a cleaned up carb didn't help. It cranks but will only backfire. The last time it ran was in September. Any suggestions would be greatly appreciated! Thanks
heylevi is offline
post #2 of 20 Old 12-29-2009, 08:28 AM
THE TRACTOR HUNTER
Glockem's Avatar
Talking Re: Getting gas and spark, still not starting
Pull the plugs, and drip a little fuel directly into the spark plug hole. Reinstall the spark plug, and try to start it then. If that doesn't start it, then you have an electrical/spark or air issue.
Assuming you didn't mess with engine timing somehow then it should start right up. How are you confirming that you are getting fuel and spark?
Remember it takes the following to make an engine run:
Fuel
Spark
Air
WORK HORSE
1986 John Deere 430
Future Restoration Project
1971 John Deere 140 H1, 54C Hydro Blade & Brinly Guard-N-Cart, 33 Tiller
Trailer Queen
1992 John Deere 420 FOR SALE
Current Restoration Project
1970 140 H3 FOR SALE
TRACTORS FOR SALE SOON
1987 John Deere 318 What The Heck
1990 John Deere 318 Dirty Bird
1970 John Deere 140 H3
Glockem is offline
post #3 of 20 Old 12-29-2009, 08:29 AM
Senior MTF Poster
"Any suggestions would be greatly appreciated! Thanks"
Post what ENGINE you are talking about.
Walt Conner
Walt 2002 is online now
post #4 of 20 Old 12-29-2009, 08:56 AM Thread Starter
The engine is a 14 hp Kawasaki. The plug is wet after cranking it. When holding the plug next to a screw, a spark is present. I tried a little starting fluid in the plug hole, and received a nice backfire.
heylevi is offline
post #5 of 20 Old 12-29-2009, 09:10 AM
SonnyT's Avatar
Images: 26
Sounds like it is flooding it out.
RIP Sonny T.
1954-2015
SonnyT is offline
post #6 of 20 Old 12-29-2009, 09:29 AM
eastonct124's Avatar
try tapping on the bowl with a wrench, float could be stuck.
Then open the trottle wide open, with choke open, and crank it over.
Flyfishing isn't a sport, it's a way of life.
eastonct124 is offline
post #7 of 20 Old 12-29-2009, 09:35 AM
Remove the plug and verify that it actually has compression.
rscurtis is offline
post #8 of 20 Old 12-29-2009, 09:39 AM
An engine won't create vaccuum to suck the gas in, without comression.
post #9 of 20 Old 12-29-2009, 09:51 AM
How old is the gas?
Will it burn on the driveway?
Gas does go bad......
x534Bruce is offline
post #10 of 20 Old 12-29-2009, 09:53 AM
Living the Dream Again!
steddy's Avatar
It will create enough to suck fuel, just not compress it enough to fire. However, since the engine is backfiring, he's probably got sufficient enough compression.
I've had some engines (Honda motorcycles) where the plugs couldn't be simply dried off after flooding, but rather had to be replaced. OP said he did replace the plug, so we can rule that out. I second the flooding out due to carb issue, or possibly "weak spark" i.e. from bad connection, weak coil, or decroded plug wire. Whatever it is, it's probably going to be a simple solution. Finding the problem is the hard part.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is online now
post #11 of 20 Old 12-29-2009, 10:00 AM
THE TRACTOR HUNTER
Glockem's Avatar
Thumbs up Re: Getting gas and spark, still not starting
It is likely flooding. Is the choke lever on the carb stuck open? However, backfiring is typically a sign that the engine timing is off, or your plug wires are routed improperly from the Distributor to the spark plug.
I assume you are getting sufficient air, so it has to be a fuel issue or the weak spark, condensor, coil, etc.
WORK HORSE
1986 John Deere 430
Trailer Queen
Glockem is offline
post #12 of 20 Old 12-29-2009, 10:16 AM
lahkota's Avatar
If the engine is backfiring, it has spark, compression, fuel, and air so my guess would be the timing. I would check the flywheel key.
lahkota is offline
post #13 of 20 Old 12-29-2009, 11:02 AM
Certified Master Tinkerer
Herd of Deeres's Avatar
The 14HP Kawasaki FC 420V has an odd electrical connector that attaches to the carb float bowl on my 175. Since mine fired right up with fresh gas after 2+ years in a barn I never bothered to find out what it does.
Herd of Deeres is offline
post #14 of 20 Old 12-29-2009, 11:27 AM
Camaniac
Yup sounds like timing is off.
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
post #15 of 20 Old 12-29-2009, 11:42 AM
If you can shut the fuel off all together, that is make sure the engine will get no fuel what so ever, Remove the plug and crank it over several times to clean out the cylinder. Get a fresh plug. I can't tell you how many times I have seen a plug get wet and fire outside of the cylinder, but not fire under compression. Install new plug, and try to start with starting fluid. Don't overdo it on the starting fluid, it can be hard on an engine if used too much. Being that it is a gas instead of liquid you can eliminate the fouling. See if it will fire on the starting fluid. If it does you have a flooding problem. If it backfires on the fluid then you have a timing problem. If it will start or attempt too, then you know its flooding itself. I have had several engines that were stored, where the float was sticking and flooding, therefore fouling the plug causing backfires. I always change out a plug that has gotten excessively "wet" with fuel. Plugs don't last like they used too.
like'mall is offline
